Infinity Chinese Miracle-2 MTK/MediaTek v2.23 - New models and features Infinity Chinese Miracle-2 MTK/MediaTek v2.23 - New models and features As ordinary, unique functions and methods released Core Changed: Protocol updated ( Raphael/Legacy ) NewSOC: ChipConfig for MT6833 activated ( under test ) Changed: BootHelper updated Changed: Fixed SW reaction to conenction/power issues ( lags/stuck removed ) Changed: META core updated ! Allow connect from now to device, which already in META mode ! Identify by default not reboot device, other operations - reboot Changed: Fixed Preloader mode handling on some driver versions Changed: Fixed META init on some devices Changed: SLA: Development feature to generate and send error reports automatically for unsupported devices ! No any data will be sent without user request Flasher Changed: UltraFlash engine updated MemoryTool Feature: Activated "Init GPT/PMT with resize" option ! Allow in some cases fix: Stuck/freeze/Rebooting issues on cheap encryption-enabled devices with cheap memory installed ! Issue found on MiPlay, some Infinix and other devices ( should work on more models range ) ! Feature work by decrease UserData space size to avoid "bad blocks" Service Changed: SmartReset updated Changed: SmartReset Extra mode updated ! SmartReset Extra acts like ordinary ones, but make additional, brand-required operations : - Reset MiAcc for XIAOMI ( non-permanent ) - Reset FlyMe acc for MEIZU - Reset DEMO mode on VIVO devices ( under test ) ! Other, vendor-specific scripts can be included by users requests Changed: "Restore Backup" option updated ! Clean and prepare files for correct restore in secure devices revised Firmware Reader Changed: New types supported Changed: Internal Database updated Other Changed: Some general changes and fixes Changed: Connection mode fixes Download link #1 Download link #2 Download link #3 How to upload files to support Infinity-Box as nobody else since year 2005 https://cdn.infinity-box.com/ico/tg48.png https://cdn.infinity-box.com/ico/yt48.png https://cdn.infinity-box.com/ico/fb48.png https://cdn.infinity-box.com/ico/fb48.png https://cdn.infinity-box.com/ico/tw48.png https://cdn.infinity-box.com/ico/discord48.png https://cdn.infinity-box.com/ico/ios2-48.png https://cdn.infinity-box.com/ico/j48.png https://cdn.infinity-box.com/ico/inst48.png https://cdn.infinity-box.com/ico/file-folder_48t.png |
What is it: Professional people know a lot about damaged and semi-damaged flash chip. In most case the onlybway to repair phones with semi-damaged flash chip is SOLDERING. Not so many people ready to make this work. But now you can try to fix phone with semi-damaged flash chip WITHOUT SOLDERING! The idea is: set limit for flash chip space usage. So f.e. if your phone has 16Gb flash and part of it is damaged you can set a limit and use only 10Gb instead of 16Gb. In this case phone will have less memory but phone WORKS! During last days it was done many tests and result is: 6 out of 11 completely dead phones become alive WITHOUT SOLDERING! Yes yes, I know, you are very smart and you may say "and what?" The amswer is: make your phone alive without soldering and see result after some time! HowTo : 1. Init MemoryTool 2. By clicking right mouse button, select in context menu Extra -> Init GPT/PMT with resize 3. Select scatter for your device ( you always can read it from this device ) 4. In new menu, by moving track, select desizer user size. Left - decrease, right - increase. 5.1 In order of TEST try recommend set left corner with smaller User Size. 5.2 In case of success test - operation can be repeated with bigger value. 6. Close MemoryTool. Make SmartReset to accept changes. https://cdn.infinity-box.com/man/mem...ze/1-where.png https://cdn.infinity-box.com/man/mem...ze/2-how-a.png |
Virustotal report Be careful and select only really working antivirus tools. Tools marked RED COLOR gives false alert and can not be treated and trusted. https://cdn.infinity-box.com/virustotal/CM2MT2-223.jpg |
1. NAND smart for 6580 like devices? 2. IMEI repair while flash full? 2. Dead NAND substitution to sd card in sdcard slot? |
Code: 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after |
@Z_Felix Have you tried anyting? |
Verry good update ... |
Card found : 860027B7 , v0148 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.23 Load IDBase v428174 Ok! Update configuration ... Update Ok! Load IDBase v429178 Ok! Operation : HW Report [ v2.23 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM73) MODE : BOOTROM PORT : 73 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 1F4ABAAD0FFF1A9D987B13366EE1016E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 54A07055ADBFA60889510FBDE4174EDC723FB28BEE8CDC0229 6E3A7176483262 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514436334D42038E1B9056B633 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 659992CDD680F51285EB1061F87654B6 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 150100514436334D42038E1B9056B633 MEM : VEN : SAMSUNG | OEM : 01 | DEV : QD63MB DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 8100 ms Secure trim timeout : 5100 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 300 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 26214400 ns Sector count : 3a3e000h Min. WR Perf. (52MH,8b): 0h Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 0h Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 0h Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 2h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 14h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 747h (15261696 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE] Done! Elapsed: 00:00:16 |
but same SP while flash 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM73) MODE : BOOTROM PORT : 73 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 1F4ABAAD0FFF1A9D987B13366EE1016E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 54A07055ADBFA60889510FBDE4174EDC723FB28BEE8CDC0229 6E3A7176483262 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_oppo6762_18540.bin EMI : CNT : 0009 EMI : [00] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514436334D42038E1B9056B633 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 659992CDD680F51285EB1061F87654B6 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002188000 Erase : 0x000000000AA88000 : 0x0000000001D00000 ERR : 0xC0040030 ERR : MMC ERROR ERR : 0x00000000|0x00000000 [DEBUG] : ERASE_BREAK , Skip erase |
other SP same model flash done 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM71) MODE : BOOTROM PORT : 71 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 2FD2DBD8221C119810D6DBC7758EB7BA BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : B85BDA627D9A5B493388C52CF0F13EA1464CFA1E2ACD88AC0F C005A902F87CEB BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_oppo6762_18540.bin EMI : CNT : 0009 EMI : [00] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514436334D4203636290D5B6D7 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E4B90040F56BFC584C01D7147C36DDEB DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002188000 Erase : 0x000000000AA88000 : 0x0000000001D00000 Erase : 0x000000000E788000 : 0x0000000006000000 Erase : 0x0000000015800000 : 0x0000000000800000 Erase : 0x0000000019000000 : 0x0000000000200000 Erase : 0x0000000019500000 : 0x0000000008900000 Erase : 0x0000000025E00000 : 0x0000000595A00000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : OPPORESERVE2 FAIL : SEC : IMG TYPE MISMATCH Write : VBMETA Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : ODM Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA Ultra : OK! [ All failed parts successfully flashed ] SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:04:03 Reconnect Power/Cable! |
What a Fast update.... Alwayes give care for customer thank you much much respect for Dev and the all team BR || Baya |
Any ideas how to detect whats is wrong with flash ic ? and whats is "FAIL : SEC : IMG TYPE MISMATCH" ? |
ultra flashing will take care care of this error in last |
imei 0 repair for huawei y9a cpu helio g80 |
