05-25-2021, 08:58 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 MTK/MediaTek v2.24 - UniversalBoot and other features As ordinary, unique functions and methods released Core Changed: Protocol updated ( Raphael/Legacy ) Changed: BootHelper updated Changed: MT8172/MT8173 support improved Changed: MT6580/MT6752 support improved Changed: MT6735/MT6737/MT6753 support improved NewFeature UniversalBoot: EMI Engine ! Allow boot device without need of preloader or whatever else, all settings got from device ! Feature support generic and secure devices as well from MT6580 up to MT6799 , MT81xx line also supported ! Some device may NOT work : Fully ERASED or RE-MARKED CID ! Feature ovveride default EMIDB , from Firmware and BootHelper ! Disable/Enable : Settings -> FireFly : AutoEMI ( Enabled by Default ) NewFeature UniversalBoot: AutoDA select ! At wrong base DA selection software will automatically change DA base for connected device ! Feature will select most correct, well tested and usable DA for target ! Must be installed complete bootPackage ( before v2.21 ) for correct work! !With UniversalBoot feature work with most devices will reduce just to operation select and device connecting ( BROM mode prefered ) !No other optional steps required Flasher Changed: UltraFlash engine updated Changed: Legacy FlashCore rebuild ! Optimized for modern/old DA versions and different targets on OLD CHIPs ! Use of latest version for service LEGACY lines is strongly recommended Changed: Default FlashSettings updated MemoryTool Changed: "Init GPT/PMT with resize" feature improved Service Changed: "SmartReset" updated Changed: "SmartReset Extra" updated Firmware Reader Changed: New types supported Changed: Internal Database updated Other Changed: Some general changes and fixes Download link #1 Download link #2 Download link #3 Infinity-Box as nobody else since year 2005 |
The Following 61 Users Say Thank You to YellowBoss For This Useful Post: |
05-25-2021, 09:18 | #2 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | good working plz update remove screen lock without data lost thanx |
The Following 8 Users Say Thank You to alimobile279 For This Useful Post: |
05-25-2021, 10:01 | #4 (permalink) | |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Quote:
PGPT PRELOADER BOOT RECOVERY NVDATA or this one Backup path : Backup\MT6765__1AC084E3505C2A620DAEB2124B8921E5\ [6] Read : NVRAM [4] Read : NVDATA [2] Read : PROINFO [3] Read : NVCFG [14] Read : PROTECT1 [15] Read : PROTECT2 [17] Read : PERSIST [0] Read : PRELOADER [16] Read : SECCFG Backup done! Pack, and upload for check. | |
The Following User Says Thank You to yuranc8 For This Useful Post: |
05-25-2021, 10:17 | #5 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Online Thanks Meter: 253 | Quote:
Uploaded, see attachment. | |
05-25-2021, 10:19 | #6 (permalink) |
Freak Poster Join Date: Jun 2011 Location: jahanian punjab pakistan
Member: 1588653 Status: Offline Sonork: imran_Gill Thanks Meter: 83 | Infinity Chinese Miracle-2 MTK/MediaTek v2.24 NewFeature UniversalBoot: EMI Engine ! Allow boot device without need of preloader or whatever else, all settings got from device ! Feature support generic and secure devices as well from MT6580 up to MT6799 , MT81xx line also supported ! Some device may NOT work : Fully ERASED or RE-MARKED CID ! Feature ovveride default EMIDB , from Firmware and BootHelper ! Disable/Enable : Settings -> FireFly : AutoEMI ( Enabled by Default ) AutoDA select ! At wrong base DA selection software will automatically change DA base for connected device CM2 allway Rocke big update |
05-25-2021, 11:19 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Not need care anymore about correct preloader for 90% of supported models. Old type : Code: Operation : Identify [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : EMI : DevInit BROM : EMI : DevInit Ok! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 44000145303034476BDxxxxxxxxxxxx DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 45010044473430303801xxxxxxxxxxxxxxx NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_bird_o1mp2_k80_bsp_512m.bin EMI : CNT : 0001 INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x20000000 [ 512,00 MB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 450100444734303038xxxxxxxxxxxxxx EMMC: VEN : SANDISK | OEM : 01 | DEV : DG4008 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x1D21D0000 [ 7,28 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x20000000 [ 512,00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Boot done! Patch Level : O11019 Display ID : 7130D_S8020K_E.A1.20180808.AD80.V21.WVGA.DS84.B18.MP.RU Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-07-05 Build Time : 08.08.2018 Product Info : Impress_Funk Product Model : Impress_Funk Product Brand : Vertex Product Name : Impress_Funk Product Device : Impress_Funk Product Board : Impress_Funk Product Manfct : Vertex Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) IMEI[0] : 35xxxxxxxxxxxxxxx IMEI[1] : 35xxxxxxxxxxxxxxx NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 14 ] Backup path : Backup\MT6580__xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\ Backup done! PRELOADER : DEVICE : DEV : MT6752 NME : preloader_bird_o1mp2_k80_bsp_512m.bin CNT : 0001 Done! Elapsed: 00:00:52 Code: Operation : Read Firmware [ v2.24 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : EMI : DevInit BROM : EMI : DevInit Ok! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k61v1_32_bsp_hdp.bin EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514531334D420xxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Product Brand : Ulefone Product Device : Armor_X7_Q Product Model : Armor X7 Product Name : Armor_X7_Q_EEA Patch Level : QP1A.190711.020 Display ID : P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0114.V3.03 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 14.01.2021 Product Info : Armor_X7_Q Product Board : Gotron-GQ3087SH2 Board Platform : mt6761 Product Manfct : Ulefone Display ID : P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03 MT6761__10__P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03__QP1A.190711.020__Armor_X7_Q Read : preloader.bin Read : proinfo.img Read : recovery.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : seccfg.img Read : persist.img ExtSparse : Compression ratio : 100% Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : super.img ExtSparse : Compression ratio : 45% Read : vbmeta.img Read : cache.img Read : userdata.img FW Size : 2,42 GB Android Info saved : _Android_info.txt Scatter : MT6761_Android_scatter.txt Saved to : C:\MTK\MT6761__10__P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03__QP1A.190711.020__Armor_X7_Q\ Done! Elapsed: 00:07:28 Code: Operation : Identify [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for cookies BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_begonia.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] UFS: AD014839485131364145434D4D444152 UFS: VEN : 0x01AD VID : H9HQ16AECMMDAR IFW : A107 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : xxxxxxxxxxxx REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-12-01 Build Time : 07.01.2020 Product Model : Redmi Note 8 Pro Product Brand : Redmi Product Name : begonia Product Device : begonia Product Info : begonia Product Manfct : Xiaomi Product Board : begonia Board Platform : mt6785 NVRAM check : Failed! NVRAM damaged! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] Backup sensetive data [ 14 ] Backup path : Backup\MT6785__xxxxxxxxxxxxxxxxxxxxxxxx\ Backup done! STORAGE : LifeStatus : UFS : OK! PRELOADER : DEVICE : DEV : MT6752 NME : preloader_begonia.bin CNT : 000A EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : H9HQ53ACPMMDAR : RAM : [ 4,00 GB ] EMI : [02] : eUFS : LP_DDR4X : DEV : H9HQ53AECMMDAR : RAM : [ 6,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : KM5H7001DM-B424 : RAM : [ 4,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM2H7001CM-B518 : RAM : [ 6,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : MT064GASAO2U21 : RAM : [ 4,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ21AFAMZDAR : RAM : [ 8,00 GB ] Done! Elapsed: 00:00:29 |
The Following 8 Users Say Thank You to JayDi For This Useful Post: |
05-25-2021, 11:20 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @KrzychuG, why it can't? Ultra will put back whatever we want. Need backup, as @yuranc8 told + PGPT and all "spareX" ( x-1,2,3,4 should be, up to 6 ) from memtool. I can make remote update for 10-15 minutes. But need make sure about vendor-specific stuff isnt touched or processed correct during read/write. Prefered in PM to not miss them. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
05-25-2021, 11:32 | #11 (permalink) | |
Sorry, attachment was missing. https://mega.nz/file/a4Y3QaRJ#ldf8HZ...NR4HRsdsWJN-74 | |
05-25-2021, 12:22 | #13 (permalink) | |
Insane Poster Join Date: Apr 2014
Member: 2175506 Status: Offline Sonork: 100.1605750 Thanks Meter: 10 | Quote:
The Following User Says Thank You to gsm_xpert For This Useful Post: |
