GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Infinity Chinese Miracle-2 MTK/MediaTek v2.24 - UniversalBoot and other features (https://forum.gsmhosting.com/vbb/f296/infinity-chinese-miracle-2-mtk-mediatek-v2-24-universalboot-other-features-2971725/)
rebainoor 06-10-2021 15:33
If possible to add direct Mount and Access to partitions (ext4;f2fs) to edite partitions content (add+delete+modify...) In memory tool
Thinks
JayDi 06-10-2021 15:38
Thinks
If you check older versions, we made all that in 2015 or so, when there was no any codes on github.
we will make something with fde decrypt.
rebainoor 06-10-2021 15:43
Yes i know
But need only mount unencrypted parts full Access (r/w) to edit some files without Root Access
It will be great and avanced feature for adv users
mbiborna 06-13-2021 01:02
Possible to write Samsung pit file via Brom mode to repair deadboot via memory tool ?
If possible please advise how to.
khanzada606 06-15-2021 21:58
allow me to know that what force BROM option and when to used it
mortal90210 06-16-2021 06:39
Kindly add this model
Dear team
log
Card found : ******** , v0148
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.24
Load IDBase v524190 Ok!
Update configuration ...
Update Ok!
Load IDBase v67213 Ok!
Operation : Identify [ v2.24 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM22)
MODE : BOOTROM
PORT : 22
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6885 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
CODE : Petrus
TYPE : MODERN RAPHAEL
BROM : MEID : C106A8F47341A8AD2A98FF3482FAA1C4
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2112 | Manual : Disabled
BROM : SOCID : 3D52060B0D322C6DAEB160BEAF12E781599A0255DFDEE4BFF2 57D11CC5F36096
BROM : SLA : Local Auth
BROM : Unsupported device : Report required!
BROM : Report generated!
INFO : Report sent!
BROM : Local AUTH failed! Device not supported yet!
>>> Send log and report.log (if exists) to support! Include device info also!
thank you
JayDi 06-16-2021 12:02
Originally Posted by mortal90210 (Post 14411301)
Dear team
log
Update Ok!
Mode : FLASH
MODE : BOOTROM
PORT : 22
BROM : Init BROM
BROM init passed!
CODE : Petrus
BROM : BOOTROM
INFO : Report sent!
thank you
Hello!
We hope to put test version today.
InfinitySupport 06-17-2021 08:08
New Infinity CM2MT2 version released - https://infinity-box.com/support/?r=100153
Muhriddinbek 01-01-2022 13:04
Always roking good update keep it up....
Page generated in 0.14336 seconds with 6 queries
