Old 05-25-2021, 08:58   #1 (permalink)
Member: 1043909
Thanks Meter: 57,697
Infinity Chinese Miracle-2 MTK/MediaTek v2.24 - UniversalBoot and other features
As ordinary, unique functions and methods released
Core
Changed: Protocol updated ( Raphael/Legacy )
Changed: BootHelper updated
Changed: MT8172/MT8173 support improved
Changed: MT6580/MT6752 support improved
Changed: MT6735/MT6737/MT6753 support improved
NewFeature UniversalBoot:
EMI Engine
! Allow boot device without need of preloader or whatever else, all settings got from device
! Feature support generic and secure devices as well from MT6580 up to MT6799 , MT81xx line also supported
! Some device may NOT work : Fully ERASED or RE-MARKED CID
! Feature ovveride default EMIDB , from Firmware and BootHelper
! Disable/Enable : Settings -> FireFly : AutoEMI ( Enabled by Default )
NewFeature UniversalBoot: AutoDA select
! At wrong base DA selection software will automatically change DA base for connected device
! Feature will select most correct, well tested and usable DA for target
! Must be installed complete bootPackage ( before v2.21 ) for correct work!
!With UniversalBoot feature work with most devices will reduce just to operation select and device connecting ( BROM mode prefered )
!No other optional steps required
Flasher
Changed: UltraFlash engine updated
Changed: Legacy FlashCore rebuild
! Optimized for modern/old DA versions and different targets on OLD CHIPs
! Use of latest version for service LEGACY lines is strongly recommended
Changed: Default FlashSettings updated
MemoryTool
Changed: "Init GPT/PMT with resize" feature improved
Service
Changed: "SmartReset" updated
Changed: "SmartReset Extra" updated
Firmware Reader
Changed: New types supported
Changed: Internal Database updated
Other
Changed: Some general changes and fixes
Download link #1
Download link #2
Download link #3
Infinity-Box as nobody else since year 2005
The Following 61 Users Say Thank You to YellowBoss For This Useful Post:
Old 05-25-2021, 09:18   #2 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 343
good working
plz update
remove screen lock without data lost
thanx
The Following 8 Users Say Thank You to alimobile279 For This Useful Post:
Old 05-25-2021, 09:19   #3 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 183
Seems to be working on LG K40
With 2.23
Operation : Read Firmware [ v2.23 ]
ExtSparse   : Enabled
ForceRead   : Disabled
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM87)
MODE : BOOTROM
PORT : 87
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Cervino
     TYPE : MODERN RAPHAEL
BROM : MEID : 4EB149F506D8384703F2618C54A020E7
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+EXT
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2112 | Manual : Disabled
BROM : SOCID : 43E67320DF95AF1B393BACD48FC9DBEAA529D247E00D632E8DA6C44B9E8473CF
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : INFINITY
     EMI : SRC : PRELOADER_INFINITY_3
     EMI : CNT : 0005
     EMI : Init EMI from INTERNAL DB
     DA : SETUP EMI PARAMS FAILED!
  ERROR : ABORT
Boot done!
Done!
Elapsed: 00:01:04
2.24
Operation : Identify [ v2.24 ]
Mode : FLASH
MODE : BOOTROM
PORT : 87
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : SLA : Look for cookies
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : SRC : preloader_muse6762_mh4_p.bin
     EMI : CNT : 000A
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x0003A000 [ 232,00 KB ]
        DRAM: 0x80000000 [ 2,00 GB ]
        EMMC: 150100515836334D420300D9C6963683
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QX63MB
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x747C00000 [ 29,12 GB ]
        CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 1AC084E3505C2A62DAEB2124B8921E5
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : PKQ1.190522.001
Display ID     : PKQ1.190522.001
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2020-09-01
Build Time     : 25.08.2020
Product Model  : LM-X420
Product Brand  : lge
Product Name   : mmh4
Product Device : mmh4
Product Manfct : LGE
Product Info   : mmh4
Product Board  : mt6765
Board Platform : mt6765
USERDATA : FILESYSTEM : EXT4
NVRAM check : Passed!
NVRAM : SEC NORMAL  [ No extra security ]
Backup sensetive data [ 14 ]
Backup path : Backup\MT6765__1AC084E3505C2A620DAEB2124B8921E5\
[6] Read : NVRAM
[4] Read : NVDATA
[2] Read : PROINFO
[3] Read : NVCFG
[14] Read : PROTECT1
[15] Read : PROTECT2
[17] Read : PERSIST
[0] Read : PRELOADER
[16] Read : SECCFG
Backup done!
STORAGE : LifeStatus : eMMC : OK!
PRELOADER : DEVICE :
DEV : MT6765
NME : preloader_muse6762_mh4_p.bin
CNT : 000A
 EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX     | DEV : HBG4a2 : RAM : [ 3,00 GB ]
 EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX     | DEV : hB8aP> : RAM : [ 3,00 GB ]
 EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX     | DEV : HAG4a2 : RAM : [ 2,00 GB ]
 EMI : [03] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG   | DEV : QE63MB : RAM : [ 2,00 GB ]
 EMI : [04] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX     | DEV : HCG8a4 : RAM : [ 4,00 GB ]
 EMI : [05] : eMMC : DDR3 : ID : 150100515836334D42 : VEN : SAMSUNG   | DEV : QX63MB : RAM : [ 2,00 GB ]
 EMI : [06] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG   | DEV : GD6BMB : RAM : [ 3,00 GB ]
 EMI : [07] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG   | DEV : QD63MB : RAM : [ 2,00 GB ]
 EMI : [08] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX     | DEV : hB8aP> : RAM : [ 2,00 GB ]
 EMI : [09] : eMMC : DDR3 : ID : FFFFFFFF46414B4565 : VEN : UNKNOWN   | DEV : ˙FAKEe : RAM : [ 2,00 GB ]
Done!
Elapsed: 00:00:55
But i can't read full firmware. Any way to force it? (i know it can't be restored back, need it for other purposes)
Operation : Read Firmware [ v2.24 ]
ExtSparse   : Enabled
MODE : BOOTROM
PORT : 87
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : CNT : 000A
        EMMC:
Boot done!
MT6765__LGE__LM-X420__9__PKQ1.190522.001__PKQ1.190522.001__mmh4
Unsupport : 0x000000000D380000 : 0x0000000000480000 : spare1
Error : Device NOT supported for SAFE READ!
>>> Send log and report.log (if exists) to support! Include device info also!
Reconnect Power/Cable!
The Following User Says Thank You to KrzychuG For This Useful Post:
Old 05-25-2021, 09:24   #4 (permalink)
Zaki Bouzidson's Avatar
Member: 2287326
Thanks Meter: 46
As usual, nobody’s gonna beat you guys keep it up.
Infinity team releases a unique feature:
Customers: yes
Copy-pasters: yes
Old 05-25-2021, 10:01   #5 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 962
Smile
With 2.23
ExtSparse   : Enabled
MODE : BOOTROM
PORT : 87
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0005
  ERROR : ABORT
Boot done!
Done!
Elapsed: 00:01:04
2.24
Mode : FLASH
MODE : BOOTROM
PORT : 87
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : CNT : 000A
        EMMC:
Boot done!
Ver. CodeName  : REL
Ver. Release   : 9
Product Brand  : lge
Product Name   : mmh4
Product Info   : mmh4
[6] Read : NVRAM
[4] Read : NVDATA
[2] Read : PROINFO
[3] Read : NVCFG
[17] Read : PERSIST
[16] Read : SECCFG
Backup done!
DEV : MT6765
CNT : 000A
Done!
Elapsed: 00:00:55
ExtSparse   : Enabled
MODE : BOOTROM
PORT : 87
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : CNT : 000A
        EMMC:
Boot done!
Need backup via memtool :
PGPT
PRELOADER
BOOT
RECOVERY
NVDATA
or this one
[6] Read : NVRAM
[4] Read : NVDATA
[2] Read : PROINFO
[3] Read : NVCFG
[17] Read : PERSIST
[16] Read : SECCFG
Backup done!
Pack, and upload for check.
The Following User Says Thank You to yuranc8 For This Useful Post:
Old 05-25-2021, 10:17   #6 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 183
PGPT
PRELOADER
BOOT
RECOVERY
NVDATA
or this one
[6] Read : NVRAM
[4] Read : NVDATA
[2] Read : PROINFO
[3] Read : NVCFG
[17] Read : PERSIST
[16] Read : SECCFG
Backup done!
Uploaded, see attachment.
Old 05-25-2021, 10:19   #7 (permalink)
akash48's Avatar
Member: 1588653
Sonork: imran_Gill
Thanks Meter: 80
NewFeature UniversalBoot: EMI Engine
AutoDA select
CM2 allway Rocke big update
Old 05-25-2021, 10:27   #8 (permalink)
Crazy Poster
Member: 1930966
Thanks Meter: 12
nice good update ...but we are all expect xiaomi,vivo,oppo imei repair function also if paid solution thats not matter.
The Following 2 Users Say Thank You to rawjezh For This Useful Post:
Old 05-25-2021, 10:46   #9 (permalink)
Crazy Poster
Member: 706781
Thanks Meter: 9
great update team .....plz add huawei mtk like mrd lx1 jat l29 imei repair solution
Old 05-25-2021, 11:19   #10 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 19,450
Not need care anymore about correct preloader for 90% of supported models.
Old type :
Mode : FLASH
PTFN : MediaTek USB Port_V1633 (COM6)
MODE : BOOTROM
PORT : 6
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : BOOTROM
BROM : EMI : DevInit
BROM : EMI : DevInit Ok!
AGENT : Found MT6580
BROM : DA sent
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 44000145303034476BDxxxxxxxxxxxx
DAInf: 4 : 2 : 156
eMMC : OK
eMMC : 45010044473430303801xxxxxxxxxxxxxxx
DRAM : 0x0178
     EMI : DEV : FireFly
     EMI : SRC : preloader_bird_o1mp2_k80_bsp_512m.bin
     EMI : CNT : 0001
INIT : 0xBC : DRAM [ 0x00000000 :  [ 0 B ] ]
DRAM : DRAM: 0x20000000 [ 512,00 MB ]
     DA : DRAM ready!
        EMMC: 450100444734303038xxxxxxxxxxxxxx
        EMMC: VEN : SANDISK | OEM : 01 | DEV : DG4008
        EMMC:
              USER   : 0x1D21D0000 [ 7,28 GB ]
        SRAM: 0x00020000 [ 128,00 KB ]
        CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM14)
MODE : PRELOADER PORT
PORT : 14
Boot done!
Patch Level    : O11019
Display ID     : 7130D_S8020K_E.A1.20180808.AD80.V21.WVGA.DS84.B18.MP.RU
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2018-07-05
Build Time     : 08.08.2018
Product Info   : Impress_Funk
Product Model  : Impress_Funk
Product Brand  : Vertex
Product Name   : Impress_Funk
Product Device : Impress_Funk
Product Board  : Impress_Funk
Product Manfct : Vertex
Board Platform : mt6580
USERDATA : FILESYSTEM : F2FS  with FDE ( Full Disk Encryption ***)
IMEI[0] : 35xxxxxxxxxxxxxxx
IMEI[1] : 35xxxxxxxxxxxxxxx
Backup path : Backup\MT6580__xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\
Backup done!
DEV : MT6752
NME : preloader_bird_o1mp2_k80_bsp_512m.bin
CNT : 0001
Done!
Elapsed: 00:00:52
Modern :
ExtSparse   : Enabled
MODE : BOOTROM
PORT : 6
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
     CODE : Merlot
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
AGENT : Found MT6761
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : SRC : preloader_k61v1_32_bsp_hdp.bin
     EMI : CNT : 0003
        SRAM: 0x0003A400 [ 233,00 KB ]
        EMMC: 150100514531334D420xxxxxxxxxxxx
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB
        EMMC:
              USER   : 0x3A3E00000 [ 14,56 GB ]
        CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
Boot done!
Product Brand  : Ulefone
Product Device : Armor_X7_Q
Product Model  : Armor X7
Product Name   : Armor_X7_Q_EEA
Patch Level    : QP1A.190711.020
Display ID     : P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0114.V3.03
Ver. CodeName  : REL
Ver. Release   : 10
Sec. Patch     : 2020-12-05
Build Time     : 14.01.2021
Product Info   : Armor_X7_Q
Product Board  : Gotron-GQ3087SH2
Board Platform : mt6761
Product Manfct : Ulefone
Display ID     : P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03
MT6761__10__P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03__QP1A.190711.020__Armor_X7_Q
Read : preloader.bin
Read : proinfo.img
Read : recovery.img
Read : vbmeta_system.img
Read : vbmeta_vendor.img
Read : seccfg.img
Read : persist.img
ExtSparse : Compression ratio : 100%
Read : md1rom.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : tinysys-sspm.bin
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : dtbo.img
Read : tz.img
Read : super.img
ExtSparse : Compression ratio : 45%
Read : vbmeta.img
Read : cache.img
Read : userdata.img
FW Size  : 2,42 GB
Android Info saved : _Android_info.txt
Scatter  : MT6761_Android_scatter.txt
Saved to : C:\MTK\MT6761__10__P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03__QP1A.190711.020__Armor_X7_Q\
Done!
Elapsed: 00:07:28
New :
Mode : FLASH
MODE : BOOTROM
PORT : 6
BROM : Init BROM
BROM init passed!
     CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Krug
BROM : SecLevel : 0x000000E7
BROM : SecMode  : SBC+SLA+SDA+EXT
BROM : BOOTROM
AGENT : Found MT6785
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : SRC : preloader_begonia.bin
     EMI : CNT : 000A
        SRAM: 0x00080000 [ 512,00 KB ]
        DRAM: 0x180000000 [ 6,00 GB ]
        UFS: AD014839485131364145434D4D444152
        UFS:
             VEN  : 0x01AD
             VID  : H9HQ16AECMMDAR
             IFW  : A107
             LU0  : 0x00400000 [ 4,00 MB ]
             LU1  : 0x00400000 [ 4,00 MB ]
             LU2  : 0x1DCB000000 [ 119,17 GB ]
             FSN  : xxxxxxxxxxxx
             REG  : 0x101010000
        CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
Boot done!
Patch Level    : PPR1.180610.011
Display ID     : PPR1.180610.011
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-12-01
Build Time     : 07.01.2020
Product Model  : Redmi Note 8 Pro
Product Brand  : Redmi
Product Name   : begonia
Product Device : begonia
Product Info   : begonia
Product Manfct : Xiaomi
Product Board  : begonia
Board Platform : mt6785
NVRAM check : Failed! NVRAM damaged!
NVRAM : SEC SIGNED  [ IMEI RSA SIGNED ]
Backup path : Backup\MT6785__xxxxxxxxxxxxxxxxxxxxxxxx\
Backup done!
STORAGE : LifeStatus : UFS : OK!
DEV : MT6752
NME : preloader_begonia.bin
CNT : 000A
 EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ]
 EMI : [01] : eUFS : LP_DDR4X : DEV : H9HQ53ACPMMDAR : RAM : [ 4,00 GB ]
 EMI : [02] : eUFS : LP_DDR4X : DEV : H9HQ53AECMMDAR : RAM : [ 6,00 GB ]
 EMI : [03] : eUFS : LP_DDR4X : DEV : KM5H7001DM-B424 : RAM : [ 4,00 GB ]
 EMI : [04] : eUFS : LP_DDR4X : DEV : KM2H7001CM-B518 : RAM : [ 6,00 GB ]
 EMI : [05] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ]
 EMI : [06] : eUFS : LP_DDR4X : DEV : MT064GASAO2U21 : RAM : [ 4,00 GB ]
 EMI : [07] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ]
 EMI : [08] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6,00 GB ]
 EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ21AFAMZDAR : RAM : [ 8,00 GB ]
Done!
Elapsed: 00:00:29
The Following 8 Users Say Thank You to JayDi For This Useful Post:
Old 05-25-2021, 11:20   #11 (permalink)
JayDi's Avatar
Member: 462970
@KrzychuG, why it can't? Ultra will put back whatever we want.
Need backup, as @yuranc8 told + PGPT and all "spareX" ( x-1,2,3,4 should be, up to 6 ) from memtool.
I can make remote update for 10-15 minutes. But need make sure about vendor-specific stuff isnt touched or processed correct during read/write.
Prefered in PM to not miss them.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 05-25-2021, 11:32   #12 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 183
PGPT
PRELOADER
BOOT
RECOVERY
NVDATA
or this one
[6] Read : NVRAM
[4] Read : NVDATA
[2] Read : PROINFO
[3] Read : NVCFG
[17] Read : PERSIST
[16] Read : SECCFG
Backup done!
Sorry, attachment was missing. https://mega.nz/file/a4Y3QaRJ#ldf8HZ...NR4HRsdsWJN-74
Old 05-25-2021, 11:43   #13 (permalink)
Member: 1649546
Thanks Meter: 121
good update team
Infinity Chinese Miracle,.
Old 05-25-2021, 12:22   #14 (permalink)
Crazy Poster
Member: 2175506
Sonork: 100.1605750
Thanks Meter: 10
Core
EMI Engine
Flasher
MemoryTool
Service
Firmware Reader
Other
Download link #1
Download link #2
Download link #3
BRO Need imei repair for MediaTek Helio P60 MT6771
The Following User Says Thank You to gsm_xpert For This Useful Post:
Old 05-25-2021, 12:23   #15 (permalink)
Crazy Poster
Member: 2175506
Sonork: 100.1605750
Thanks Meter: 10
Bro ,...
Need imei repair for MediaTek Helio P60 MT6771 devices
do somthing Team
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.28656 seconds with 8 queries
