07-17-2021, 14:45 | #106 (permalink) |
No Life Poster Join Date: Jan 2009 Location: obamas village
Member: 952862 Status: Offline Thanks Meter: 48 | after driver update i get this issue 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.26 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.26 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
07-18-2021, 19:54 | #111 (permalink) | |
Junior Member Join Date: Apr 2005 Age: 39
Member: 136020 Status: Offline Thanks Meter: 2 | I have same problem. Reinstall driver and reboot dont fix problem. ((( SPFlashtool work - flash firmware with it. Quote:
07-19-2021, 11:39 | #112 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity CM2MT2 v2.27 released https://infinity-box.com/support/?r=100157 |
07-23-2021, 13:52 | #113 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | 0PPO A93 (CPHCPH2121) BOOTROM switch auto done Quote:
Code: Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Read Firmware [ v2.27 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2124 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1633 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN [RAPHAEL] BROM : MEID : A42EC3EE51118BCB3D92DF6C0A4D9F8E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CA51AEAB57ADFACDB0E3A07666E38DC3C62B4A18DA48FD8585357A7D04AAFA54 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2124 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 1200 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 3cd96ea72f02 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 469F372F1DD7A42492DC63631400240E DA : USB : HIGH-SPEED Boot done! Patch Level : QP1A.190711.020 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-10-05 Build Time : 29.09.2020 MT6779__10__QP1A.190711.020 Read : preloader.bin Read : recovery.img Read : opporeserve1.img Read : opporeserve2.img ExtSparse : Compression ratio : 91% Read : oppo_custom.img Read : vbmeta.img Read : persist.img ExtSparse : Compression ratio : 98% Read : proinfo.img Read : nvram.bin Read : ocdt.img Read : cdt_engineering.img Read : md1rom.img Read : spmfw.img Read : audio_dsp.img Read : tinysys-scp.bin Read : sspm.img Read : cam_vpu1.img Read : cam_vpu2.img Read : cam_vpu3.img Read : gz.img Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : special_preload.img ExtSparse : Compression ratio : 99% Read : my_custom.img ExtSparse : Compression ratio : 99% Read : vbmeta_system.img Read : vbmeta_vendor.img Read : super.img ExtSparse : Compression ratio : 20% Read : cache.img Read : userdata.img FW Size : 6,70 GB Android Info saved : _Android_info.txt Scatter : MT6779_Android_scatter.txt Saved to : H:\OPPO\MT6779__10__QP1A.190711.020\ Done! Elapsed: 00:11:54 | |
The Following 2 Users Say Thank You to rebainoor For This Useful Post: |
11-27-2021, 10:04 | #115 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Product Brand : Infinix Product Device : Infinix-X657B Product Model : Infinix X657B Product Name : X657B-OP-S2 Patch Level : QP1A.190711.020 Display ID : X657B-H6117EI-QGo-OP-S2-210415V138 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-04-05 Build Time : 14.04.2021 Product Info : x657b_h6117 Product Board : Infinix-X657B Board Platform : mt6761 Product Manfct : INFINIX MOBILITY LIMITED BootLoader State : Failed! INFO : Reflash device first! Done! Elapsed: 00:00:53 Reconnect Power/Cable! |
