07-19-2021, 18:31 | #31 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Will provide server-side update. | |
07-19-2021, 18:33 | #32 (permalink) | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
07-19-2021, 23:54 | #33 (permalink) |
Junior Member Join Date: Dec 2011 Location: ask Age: 34
Member: 1705765 Status: Offline Sonork: marvinmegamind Thanks Meter: 11 | Thanks for the great work team please add support to memory tool to be able to backup and format the following partitions rpmb secondary_partition_table region-0x47800000 region-0x1a00 region-0x0 preloader2 partition_table Especially this partition rpmb it stores KG state data please team help and add this support in the next update it will help us unlock kg state permanetely thanks team |
The Following 2 Users Say Thank You to saad100 For This Useful Post: |
07-20-2021, 02:45 | #35 (permalink) |
Registered User Join Date: Jan 2012 Location: Above the earth
Member: 1711578 Status: Offline Sonork: 100.1606127 Thanks Meter: 51 | oppo a12 data lock how to solved Card found : 5B3B30BB , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : SP Unlock [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 25EFED5BC7E5C7A0834344686B0D0F90 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 0A64023E51065F80724CDB974435EB4FA7DC2BA0377DB7C700 DA4EEAB161753D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E03003CA19A87F1 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 3973530 ( 0x003CA19A) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DB1DCE054AFE210592FDEBB5357BC4DE DA : USB : HIGH-SPEED Boot done! Error : SPLock : Unlock failed! >>> Repeat operation in META mode [ Platform -> Global -> Meta ] Reconnect Power/Cable! Operation : SP Unlock [ v2.27 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 25EFED5BC7E5C7A0834344686B0D0F90 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 0A64023E51065F80724CDB974435EB4FA7DC2BA0377DB7C700 DA4EEAB161753D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Thu Nov 26 01:52:05 CST 2020 AP_SWVR : CPH2083_11_A.49_201126_248b7f61 MD_CHIP : MT6765 MD_SWVR : OPPO_P0MP3_K65V1_64_BSP_HW IMEI[1] : 863114052696478 ID0 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 SPLock Info : Not locked! IMEI[2] : 863114052696460 ID0 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 SPLock Info : Not locked! Done! Elapsed: 00:00:56 |
07-20-2021, 06:32 | #36 (permalink) |
Freak Poster Join Date: Jun 2013 Location: bangladesh
Member: 1957555 Status: Offline Thanks Meter: 10 | === DongleManager [Infinity] v1.87 [7/20/2021 11:30:16 AM] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000026AA12534082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): AD0D26AA Firmware version: 0149.02 === Started: 7/20/2021 11:30:17 AM === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0007] No update available Why? 1.Smart-Card has latest firmware version. Update is not required. OR 2.Support period is expired, check it here - https://www.infinity-box.com/doc/?r=17 If support expired contact to any seller and renew - https://www.infinity-box.com/buy/ notwork |
07-20-2021, 10:51 | #37 (permalink) | |
07-20-2021, 11:09 | #38 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | dear JayDi please move your MTK based Samsung feature on to SM platform other wish why we buy already your SM activation. if you can move it with SM tool then team can earn for your massive development helping fund. also for your assistance. others SM platform is too useless. thanks |
07-20-2021, 11:23 | #39 (permalink) | |
Unforntunately - have no any relation to SM at all. If "update it" = mean write from scratch. In current situation it mean freeze all current ones and build it from zero. There is already pending too much stuff in other modules, which we want, can and will update in near time. | |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
07-20-2021, 17:38 | #42 (permalink) |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | oppo A1k Cph 1923 one click patern+frp done Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 80F622F89964564D7F5FD5887E03F0EB BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 32F49451302E5EDD9688A57FFF367041D98CDA703CFA230999 B6CAAE08E47B6D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_1 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D42034E05DEB41645 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2A5CA85B6DA237C1CF9ABB887BA8FDB1 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to bilal khan12345 For This Useful Post: |
07-20-2021, 17:47 | #43 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 49
Member: 90058 Status: Offline Thanks Meter: 97 | REALME 3 BOOTLOADER UNLOCK DONE Card found : ******* , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Unlock BootLoader [ v2.27 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN [RAPHAEL] BROM : MEID : D5643EEB4E952360736C33E01273FCAC BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D401E7F790D14470548AB8FDF5686C8DF3025BC6AA0BDA293A 433C16835095FD BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v03.02.03 on MT6771 FireFly : eMMC init passed! EMMC: CSD : D02701328F5903FFFFFFFFEF8A400027 EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 90014A484347386134A24D67D2CB16BD EMMC: VEN : HYNIX : OEM : 74 : ID : 484347386134 EMMC: VEN : HYNIX : HCG8a4 EMMC: SNN : 1298649803 ( 0x4D67D2CB) , MF : 1/2019 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x00 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE8F800000 [ 58.24 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-06-05 Product Manfct : Realme Build Time : 29.06.2019 Product Brand : Realme Product Model : RMX1821 Product Info : RMX1821 Product Device : RMX1821 Product Name : RMX1821 SW OTA Version : RMX1821EX_11.A.18_0180_201906292146 Display ID : RMX1821EX_11_A.18 Kernel Info : 4.4.146-G201906292146 BootLoader State : Locked! BootLoader State : Unlocked! Done! Elapsed: 00:01:08 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to shivram For This Useful Post: |
07-20-2021, 19:23 | #44 (permalink) | |
Junior Member Join Date: Apr 2005 Age: 39
Member: 136020 Status: Offline Thanks Meter: 2 | Good day! Can you help me? I cant Identify phone with 2.26 and 2.27 version. It stuck at bootrom init passed Code: Card found : XXXXXXXX , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! Quote:
Code: Card found : XXXXXXXX , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.25 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Identify [ v2.25 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : EA86BA8D56E697CD5AE3CD055CAD8FB8 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 487B25228635D508BA597E26E6560A110472401722D00124BC33AEDA3022469A BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI not found BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! What i can do wrong, dont understand. | |
07-20-2021, 20:43 | #45 (permalink) |
Member: 2266425 Status: Offline Thanks Meter: 58 | Add screen lock reset only without data lost kindly . . . (( jayDi sir )) Last edited by bilal khan12345; 07-20-2021 at 20:49. |
