01-27-2017, 09:16 | #16 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | |
01-27-2017, 10:33 | #18 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Code: Operation : Read Memory [ v1.10 ] Reading selected partitions [1] [0] Read partition : FSC Saved to : C:\InfinityBox\CM2QLM\phdata\FSC.bin Operation finished! Operation : Read Memory [ v1.10 ] Reading selected partitions [1] [0] Read partition : FSG Saved to : C:\InfinityBox\CM2QLM\phdata\FSG.bin Operation finished! | |
01-27-2017, 11:45 | #21 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Also - if make GS backup for model - make new dir and select is as work dir. Save a lot of time and make things clear. | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
01-27-2017, 13:09 | #23 (permalink) |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | OPPO 3001 done Identify Code: Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0583E7A5 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 22C2B846F17D6A654237D9C60158D8F0 ID_BLOCK_L : 5E359B3227AE10952887C80103E2FCDF Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : 3006 ProdModel : 3006 Device : 3006 AndroidVer: 4.4.4 Manufact. : OPPO QLMxCPU : MSM8916 Done! Elapsed: 00:00:11 Code: Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0583E7A5 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 22C2B846F17D6A654237D9C60158D8F0 ID_BLOCK_L : 5E359B3227AE10952887C80103E2FCDF Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0583E7A5 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 22C2B846F17D6A654237D9C60158D8F0 ID_BLOCK_L : 5E359B3227AE10952887C80103E2FCDF Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : 3006 ProdModel : 3006 Device : 3006 AndroidVer: 4.4.4 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v4.4.4__3006__3006__3006 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : misc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : driver.iso [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 1710 MiB Done! Elapsed: 00:02:30 Reconnect Power/Cable! |
The Following User Says Thank You to tsabila For This Useful Post: |
01-27-2017, 13:28 | #25 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Mi note 3 kenzo Read info Code: Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 0435D8B9 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 551271AD1F16DA9D3448184FC3B34B8C ID_BLOCK_L : FFF973D2E534DE0CCB5277720D79A518 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Brand : Xiaomi ProdName : kenzo ProdModel : Redmi Note 3 Device : kenzo AndroidVer: 5.1.1 Manufact. : Xiaomi QLMxCPU : MSM8952 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 0435D8B9 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 551271AD1F16DA9D3448184FC3B34B8C ID_BLOCK_L : FFF973D2E534DE0CCB5277720D79A518 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Memory Tool Init [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 0435D8B9 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 551271AD1F16DA9D3448184FC3B34B8C ID_BLOCK_L : FFF973D2E534DE0CCB5277720D79A518 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Set default path : C:\InfinityBox\CM2QLM\phdata\ Ready! Operation : Read Memory [ v1.10 ] Reading selected partitions [5] [0] Read partition : MODEM Saved to : C:\InfinityBox\CM2QLM\phdata\MODEM.bin [1] Read partition : FSC Saved to : C:\InfinityBox\CM2QLM\phdata\FSC.bin [2] Read partition : MODEMST1 Saved to : C:\InfinityBox\CM2QLM\phdata\MODEMST1.bin [3] Read partition : MODEMST2 Saved to : C:\InfinityBox\CM2QLM\phdata\MODEMST2.bin [4] Read partition : FSG Saved to : C:\InfinityBox\CM2QLM\phdata\FSG.bin Operation finished! Close MemoryTool session Done! Elapsed: 00:01:06 Reconnect Power/Cable! |
The Following User Says Thank You to princesaddam For This Useful Post: |
01-27-2017, 17:06 | #29 (permalink) |
No Life Poster Join Date: Nov 2006 Location: turkey
Member: 384775 Status: Offline Sonork: 100.1605469 Thanks Meter: 159 | ---------- Process started: 27.01.2017 19:04:20 ---------- DongleManager [Infinity-Box] v1.67 [27.01.2017 19:04:20] PC HWID: AFCEE083A Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: 0004283 Type: Main Infinity-Box/Dongle S/N: 149Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! but program say need update dongle. how can i solve this problem? |
01-27-2017, 17:16 | #30 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2043843 Status: Offline Thanks Meter: 39 | Finally redmi note 4g (dior) supported Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 09154F34 ID_BLOCK_I : 009180E1 ID_BLOCK_L : B1B329D580EE1B16F1A6AEB770CB4B83 ID_BLOCK_L : CC8709A0953CAE27DA157EB7BD706E6D Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 09154F34 ID_BLOCK_I : 009180E1 ID_BLOCK_L : B1B329D580EE1B16F1A6AEB770CB4B83 ID_BLOCK_L : CC8709A0953CAE27DA157EB7BD706E6D Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:17 Reconnect Power/Cable! but i have to reflash after all opration.. NOw see how fast other copy cat copy our lovely one and only "INFINITY_CM2" |
The Following User Says Thank You to vishal110094 For This Useful Post: |
