03-26-2017, 15:39 | #123 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2261183 Status: Offline Thanks Meter: 7 | my Qlm version is 1.11 now. i remeber i had been run it with 1.09 version.but in thi s new update i have this problem. thanks infinity team |
The Following User Says Thank You to safajan For This Useful Post: |
03-27-2017, 12:06 | #124 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Tétouan Age: 38
Member: 2377800 Status: Offline Sonork: nono Thanks Meter: 48 | Pleas what about oneplus 3/3t ect And xiaomi new cpu 830 ? Not supported ? And when will be supported ? Thk u |
The Following User Says Thank You to mohacraft For This Useful Post: |
03-27-2017, 16:18 | #125 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | when i run new qualcom 1.11 exe it says update firmware....previous version was running smoothly ....already updated firmware but still same Box/Dongle Serial No (S/N): 0639DFF2 Firmware version: 0134.02 |
The Following User Says Thank You to ASHIF For This Useful Post: |
03-27-2017, 16:26 | #126 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2681131 Status: Offline Thanks Meter: 2 | gallery photo/video/ Thanks infinity team,Please add gallery photo/video/... next update enabeld photo/gallery/video/... |
The Following User Says Thank You to aftabnadeem For This Useful Post: |
03-27-2017, 21:14 | #127 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 04DEE3E4 ID_BLOCK_I : 009600E1 ID_BLOCK_E : 00040000 ID_BLOCK_L : BA56B3706178AB5DCD71BA58055D019D ID_BLOCK_L : C493462FF6B30152605CB0E731D3E14E Pickup loader from firmware package FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! |
The Following User Says Thank You to bananin For This Useful Post: |
03-28-2017, 06:10 | #128 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | Next update need yelloboss Qualcomm MSM8996 Snapdragon 820 Last edited by nahidroman; 03-28-2017 at 06:18. |
The Following User Says Thank You to nahidroman For This Useful Post: |
03-28-2017, 06:46 | #129 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Can you send me loader in pm from that FW for check it? | |
03-29-2017, 05:00 | #131 (permalink) |
Freak Poster Join Date: Nov 2010
Member: 1445590 Status: Offline Thanks Meter: 70 | 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : C388A0BF ID_BLOCK_I : 000460E1 ID_BLOCK_L : 988B4BC39CF07904A135C6B516198F30 ID_BLOCK_L : 8BCCA0542D5C13393043B535305FFBB9 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to vishal kapoor For This Useful Post: |
03-29-2017, 06:41 | #133 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1321621 Status: Offline Sonork: [email protected] Thanks Meter: 4 | All Mi Phone mi account remove plese update urjent |
The Following User Says Thank You to YOGENDRA KUSHWA For This Useful Post: |
03-29-2017, 08:07 | #135 (permalink) |
Member: 1445590 Status: Offline Thanks Meter: 70 | 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : C388A0BF ID_BLOCK_I : 000460E1 ID_BLOCK_L : 988B4BC39CF07904A135C6B516198F30 ID_BLOCK_L : 8BCCA0542D5C13393043B535305FFBB9 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! oppo r9s cph1607 |
