04-03-2017, 23:57 | #151 (permalink) |
Junior Member Join Date: Oct 2015 Location: tunisia
Member: 2478867 Status: Offline Thanks Meter: 0 | please help for this Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100534A533030410A53422B7E5FCD Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! |
04-05-2017, 07:21 | #155 (permalink) | |
No Life Poster Join Date: Sep 2009
Member: 1109337 Status: Offline Thanks Meter: 197 | pls include in next update Quote:
04-06-2017, 20:02 | #158 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Molakalmuru (KARNATAKA) {INDIA
Member: 1891452 Status: Offline Thanks Meter: 29 | Vivo V3 Max reading error Phone is working correctly Just I wanted to backup file but be getting error... Infinity team please fix this issue in next update... Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 00B5DF04 ID_BLOCK_I : 009900E1 ID_BLOCK_L : 816319E550DECBC6A1967E67A0FB7B53 ID_BLOCK_L : 6CE7A900F59CCE477AB51ED7DDD0CE0D Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : vivo ProdName : V3Max ProdModel : vivo V3Max Device : V3Max AndroidVer: 5.1.1 Manufact. : vivo QLMxCPU : MSM8952 DevInfo : MSM8952__vivo__vivo__ANDR_v5.1.1__vivo_V3Max__V3Ma x__V3Max Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : oem.img [Read Ok] : mdtp.img Error : Failed to convert data! Erased/Damaged device??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
04-07-2017, 13:19 | #160 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | MI Redmi_3S FLASH DONE BUT LONG TIME Quote:
04-07-2017, 18:03 | #161 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 47
Member: 205157 Status: Offline Sonork: 100.1574537 Thanks Meter: 82 | OnePlus One(A0001) Hang On Logo Done By Just Formatting Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 801 [MSM8974] ID_BLOCK_S : 10777B15 ID_BLOCK_I : 007B40E1 ID_BLOCK_L : 925208F661CDFAF5D287495691E86860 ID_BLOCK_L : 5221EF3E33A20C993CFBDC151F9680CB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8974 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/00020000/00001000/00001000 Boot Ok! Brand : oneplus ProdName : bacon ProdModel : A0001 Device : A0001 AndroidVer: 5.0.2 Manufact. : OnePlus QLMxCPU : MSM8974 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Reset Settings [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 801 [MSM8974] ID_BLOCK_S : 10777B15 ID_BLOCK_I : 007B40E1 ID_BLOCK_L : 925208F661CDFAF5D287495691E86860 ID_BLOCK_L : 5221EF3E33A20C993CFBDC151F9680CB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8974 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/00020000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following User Says Thank You to cellncare For This Useful Post: |
04-09-2017, 07:16 | #162 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | CM Superion Scope 3G MSM8610 Read Fw Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0128180A ID_BLOCK_I : 008140E1 ID_BLOCK_L : 9F6903FB5AC0CDF8A79C7459A6FD7555 ID_BLOCK_L : E3923C8F8013BBC8CD286D5AA847517A Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : qcom ProdName : Superion Scope 3G ProdModel : B180 Device : msm8610 AndroidVer: 4.3 Manufact. : unknown QLMxCPU : MSM8610 DevInfo : MSM8610__unknown__qcom__ANDR_v4.3__B180__msm8610__ Superion_Scope_3G Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : boot.img [Read Ok] : tz.mbn [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : userdata.img [Read Ok] : usbdisk.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 1763 MiB Done! Elapsed: 00:03:50 |
04-09-2017, 18:04 | #163 (permalink) | |
Member: 2443283 Status: Offline Thanks Meter: 518 | xiaomi max mi accaount reset fail need next update Quote:
04-10-2017, 10:10 | #164 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | LYF Ls5009 Frp Reset done Operation : Reset Settings [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 03733307 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 9C641EF857C3C8FBA4997B64A3FE7656 ID_BLOCK_L : 2E25EB4237DE008538F7D81113928CCF Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
