07-12-2017, 08:11 | #121 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Did u install emergency drivers Cm2 works with emergency drivers,,, how to install see this http://forum.gsmhosting.com/vbb/f296...video-2160627/ | |
07-12-2017, 12:48 | #122 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | xiaomi 4c lose phone how to know mi cloud off Quote:
The Following User Says Thank You to nahidroman For This Useful Post: |
07-12-2017, 16:17 | #123 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Lenovo k33a42 Andriod 7.0 Frp remove done Code: Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 10F366D4 ID_BLOCK_I : 0004F0E1 ID_BLOCK_E : 00007A2A ID_BLOCK_L : 84EADB2315511CF5F8B99349C255661F ID_BLOCK_L : 575A18F7849BC049D074A96FEBE56BA5 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Brand : Lenovo ProdName : karate ProdModel : Lenovo K33 Device : K33 AndroidVer: 7.0 Manufact. : LENOVO SysPatch : NRD90N QLMxCPU : MSM8937 QLMxPRJ : K33_USR_S223_1706101140_Q00440_ROW Done! Elapsed: 00:00:40 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 10F366D4 ID_BLOCK_I : 0004F0E1 ID_BLOCK_E : 00007A2A ID_BLOCK_L : 84EADB2315511CF5F8B99349C255661F ID_BLOCK_L : 575A18F7849BC049D074A96FEBE56BA5 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:16 |
07-12-2017, 19:56 | #124 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | ooops Code: Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 75925F62 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : 5E44B181831935B2FB10B1AB2D0CD123 ID_BLOCK_L : 121E49CBF122CE89E3FE0CE742967F48 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Brand : Nokia ProdName : TA-1003_00WW ProdModel : TA-1003 Device : D1C AndroidVer: 7.1.1 Manufact. : FIH SysPatch : NMF26F QLMxCPU : MSM8937 Done! Elapsed: 00:00:07 |
The Following 16 Users Say Thank You to JayDi For This Useful Post: |
07-12-2017, 22:00 | #125 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Quote:
I am waiting for an update | |
07-13-2017, 10:54 | #131 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1411141 Status: Offline Thanks Meter: 7 | Operation: Reset Pattern Lock Selected model: SM-J710F Software version: 28.7 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... not found With Z3X ??? |
07-13-2017, 16:17 | #133 (permalink) | |
driver installed ? pc not detected your phone! plaese check this post http://forum.gsmhosting.com/vbb/6501392-post11.html | |
07-17-2017, 05:46 | #134 (permalink) | |
Member: 2443283 Status: Offline Thanks Meter: 518 | mi 5 mi accaount reset done Quote:
The Following 2 Users Say Thank You to nahidroman For This Useful Post: |
07-17-2017, 18:13 | #135 (permalink) | |
Member: 2443283 Status: Offline Thanks Meter: 518 | OPPO CPH1701 Read PatternLock FAIL Quote:
