08-30-2017, 11:03 | #151 (permalink) |
Freak Poster Join Date: Jul 2015 Location: douala cameroun
Member: 2425737 Status: Offline Thanks Meter: 7 | this is my fault file https://drive.google.com/file/d/0B2x...ew?usp=sharing |
09-02-2017, 08:25 | #154 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 48
Member: 205157 Status: Offline Sonork: 100.1574537 Thanks Meter: 82 | RedmiNote4 Always Shows Low Space Solved By Infy RedmiNote4 Always Shows Low Space Solved By Infy Flashed Many Times With Different Versions, HardReset,Format Nothing Changed BY REPAIR DATA/MSC/CACHE SOLVED THE PROBLE 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 09D40D2D ID_BLOCK_I : 009180E1 ID_BLOCK_L : BA4A20DE79E5121DCABF51BE79C05078 ID_BLOCK_L : 8FC648E3D47FEF64995439F6FC332D2E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! MSC format Ok! USERDATA format Ok! CACHE format Ok! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
09-04-2017, 12:45 | #155 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1050365 Status: Offline Thanks Meter: 210 | Vivo Y55L Flashing successfully Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 014D4167 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : D00F34CF5ADD1230CC2C4CAE4A71C59E ID_BLOCK_L : 064BC134CC363D860F58B8C966AE83D9 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Flash Chain : 133 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : sec.dat Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : system_1.img Flashing : system_2.img Flashing : system_3.img Flashing : system_4.img Flashing : system_5.img Flashing : system_6.img Flashing : system_7.img Flashing : system_8.img Flashing : system_9.img Flashing : system_10.img Flashing : system_11.img Flashing : system_12.img Flashing : system_13.img Flashing : system_14.img Flashing : system_15.img Flashing : system_16.img Flashing : system_17.img Flashing : system_18.img Flashing : system_19.img Flashing : system_20.img Flashing : system_21.img Flashing : system_22.img Flashing : system_23.img Flashing : system_24.img Flashing : system_25.img Flashing : system_26.img Flashing : system_27.img Flashing : system_28.img Flashing : system_29.img Flashing : system_30.img Flashing : system_31.img Flashing : cache_1.img Flashing : cache_2.img Flashing : cache_3.img Flashing : persist_1.img Flashing : oem_1.img Flashing : oem_2.img Flashing : mdtp.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : survival.img Flashing : dp_AP_signed.mbn Flashing : dp_MSA_signed.mbn Flashing : apps_1.img Flashing : apps_2.img Flashing : apps_3.img Flashing : apps_4.img Flashing : apps_5.img Flashing : userdata_1.img Flashing : userdata_2.img Flashing : userdata_3.img Flashing : userdata_4.img Flashing : userdata_5.img Flashing : userdata_6.img Flashing : userdata_7.img Flashing : userdata_8.img Flashing : userdata_9.img Flashing : userdata_10.img Flashing : userdata_11.img Flashing : userdata_12.img Flashing : userdata_13.img Flashing : userdata_14.img Flashing : userdata_15.img Flashing : userdata_16.img Flashing : userdata_17.img Flashing : userdata_18.img Flashing : userdata_19.img Flashing : userdata_20.img Flashing : userdata_21.img Flashing : userdata_22.img Flashing : userdata_23.img Flashing : userdata_24.img Flashing : userdata_25.img Flashing : userdata_26.img Flashing : userdata_27.img Flashing : userdata_28.img Flashing : userdata_29.img Flashing : userdata_30.img Flashing : userdata_31.img Flashing : userdata_32.img Flashing : userdata_33.img Flashing : userdata_34.img Flashing : userdata_35.img Flashing : userdata_36.img Flashing : userdata_37.img Flashing : userdata_38.img Flashing : userdata_39.img Flashing : userdata_40.img Flashing : userdata_41.img Flashing : userdata_42.img Flashing : userdata_43.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:03:30 Reconnect Power/Cable! But Read Error Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 014D4167 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : D00F34CF5ADD1230CC2C4CAE4A71C59E ID_BLOCK_L : 064BC134CC363D860F58B8C966AE83D9 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Brand : vivo ProdName : PD1613F_EX ProdModel : vivo 1603 Device : msm8937_32 AndroidVer: 6.0.1 Manufact. : vivo QLMxCPU : MSM8937 DevInfo : MSM8937__vivo__vivo__ANDR_v6.0.1__vivo_1603__msm89 37_32__PD1613F_EX ReportFile : C:\InfinityBox\CM2QLM\QLM_5report.log Send report to mail : [email protected] with title "QFW" ! Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
09-09-2017, 12:06 | #157 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, If u have EDL Cable then connect it,, if not then see this theard http://forum.gsmhosting.com/vbb/f296...-2246357/,,and also dont forget to install emergency drivers |
The Following User Says Thank You to princesaddam For This Useful Post: |
09-09-2017, 16:32 | #159 (permalink) | ||
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | MR JayDI what happened Huwei Y530-U00 Flashing Poblem Quote:
09-13-2017, 05:37 | #164 (permalink) | |
No Life Poster Join Date: Jul 2011
Member: 1613469 Status: Offline Thanks Meter: 192 | Quote:
Phone eMMC Name : SEM04G Phone eMMC CID : 45010053454D30344728F0E3FC7CD0C6 Phone eMMC SCD : D00F00320F5903FFFFFFFDFF8A4040A6 ??? | |
09-13-2017, 06:17 | #165 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,353 | Quote:
But, if there were enabled encryption ( it enabled from factory by default, until you not switch it off ) - then dumping wilm give you just encrypted file ( AES with some other stuff ) , sw show partition state in memory tool window - BINARY under userdata mean inlt encrypted. | |
