Old 09-12-2020, 18:55   #91 (permalink)
Member: 2171849
Sonork: no
Thanks Meter: 110
Originally Posted by aminbr25 View Post
Sir please waiting your reply please?
hi sir any upadate about me?
Old 09-30-2020, 13:28   #92 (permalink)
soulgsm's Avatar
Member: 1872225
Sonork: 100.1668729
Thanks Meter: 32
not working
https://forum.gsmhosting.com/vbb/f64...-02-a-2905785/
Old 10-13-2020, 16:58   #93 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
Have you tried to make format FS ?
Does it helps ?
Old 10-15-2020, 09:24   #94 (permalink)
Member: 2652531
Thanks Meter: 66
Originally Posted by soulgsm View Post
Operation : Reset Settings [ v2.02 ]
----- > Phone/Tablet :
1. Power Off device
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable! Press 'POWER_ON' button for a few second!
----- > IoT/Box :
1. Reset device power
2. PRESS and HOLD 'RESET' KEY!
3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second!
Wait for device ...
Device Connected!
Interface test : Passed
Device mode : 0x0100
Machine : RK312X
Device : RK3126C
ExtInfo : 7.0.0
SoC CPU : 312A
Flash CSx : 0x00
Flash Type : ADDE14AB42 [ NAND ]
Flash Vend : HYNIX
Flash Size : 0x0000000210000000 ( 8.25 GiB )
Flash Info : 4194304/16384/32/40/1
Connect Ok!
Remove FRP 0 ...
FRP removed!
Wiping UserData ...
Wipe DATA Ok!
Done!
Elapsed: 00:00:10
the same as me still locked...with frp
The Following User Says Thank You to proglak For This Useful Post:
Old 10-16-2020, 20:40   #95 (permalink)
Member: 2171849
Sonork: no
Thanks Meter: 110
Originally Posted by YellowBoss View Post
Hi,
Does it helps ?
hi, sir thanks for reply. i do it but its same. i alreday sent you read firmware also.
Old 11-26-2020, 12:24   #96 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hey supporters.
is there any chance to repack readed file to *.img..? ( all in one )
Old 11-26-2020, 12:25   #97 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Originally Posted by LoveLess View Post
hey supporters.
or can u add MASKROM flashing for totally dead devices..?
Old 12-15-2020, 10:16   #98 (permalink)
Member: 2973928
Thanks Meter: 260
Best tool in the world thnx again
Old 01-23-2021, 05:40   #99 (permalink)
Member: 1026005
Sonork: seaheng
help me please donggle not open
nfinity Chinese Miracle-2 RKT/Rockchip v2.02 - New chips and latest Android support
As ordinary, unique functions and methods released
Core
BugFix : Connection stack updated
BugFix : Compatibility with latest drivers releases
Changed : Core rebuild for support modern SoC's and old SoC's revisions with Fuse/SecureBoot support
Support RK29xx series ( NAND )
Support RK30xx series ( NAND, eMMC )
Support RK31xx series ( NAND, eMMC )
Support RK32xx series ( NAND, eMMC )
Support RK33xx series ( NAND, eMMC )
Support RKPX5 series ( NAND, eMMC )
Service
Changed : Identify procedure rebuild. Complete info reading and parameters detection
!*If Identify CAN NOT display SWVersion details it may means device can not be serviced for FWRead operations
Changed : FRP reset revised to support latest Android versions and Modern SoCs
Changed : FS format revised to support latest Android versions and Modern SoCs
Firmware flasher
New Feature : Modern RK UnionImage flashing supported
New Feature : Combined Sparse image flashing supported
New Feature : Repartition for RK-PARA and RK-GPT supported
New Feature : Factory (UnionImage) Firmware flashing for latest Rockchip SoCs versions/revisions
Changed : Support Infinity Firmware Flashing ( Old and Modern SoCs revisions )
Firmware Reader
New Feature : Android 7 devices supported
New Feature : Android 8 devices supported
New Feature : Android 9 devices supported
Unique : Firmware read allow read FW from "unreadable" Android 8/9 devices
!*Feature support eMMC and NAND devices which can not be dumped by any tools over native protocol ( No Root / ADB need )
!*Feature support some "slow" NAND cases on modern SoC's
!*Feature may not work on some NAND devices with FTL/ECC errors and Flash Faults
Changed : Improved structure identification
Changed : Support more different types
Other
BugFix : Minor changes and bugfixes
Drivers : New driver package with Win8/Win10 x86/x84 can be found on support area
Info : SW may work not correct in some cases with RK29xx and RK31xx OLD NAND 4.x devices
Info : New driver installation is REQUIRED for correct work !
password for files: 12345678
Old 02-03-2021, 11:37   #100 (permalink)
Member: 1043909
What is your dongle Serial Number (S/N) ?
Old 02-04-2021, 16:37   #101 (permalink)
Member: 148515
Thanks Meter: 19,534
Originally Posted by zeeshan ali 786 View Post
thanks for update infinity team...plz update QLM module
Work about more QLM software features is in progress. New software will be released as soon as it will be finished and well tested.
Please write here list of required supported CPU types, hardware configurations and software features that you want to see released in future Infinity QLM update. Waiting for your information !
Facebook - Telegram - Twitter
Old 02-14-2021, 23:01   #102 (permalink)
Y Michael's Avatar
Member: 2947987
Sonork: Null
Thanks Meter: 72
Pls add oppo Qualcomm phones
Sent from my CPH1727 using Tapatalk
Old 02-15-2021, 12:17   #103 (permalink)
Member: 1043909
Ok Sir, your request has been forwarded to dev team
Old 02-25-2021, 18:15   #104 (permalink)
Registered User
Member: 657419
Thanks Meter: 5
Please add vivo qualcomm
Sent from my SM-A307FN using Tapatalk
Old 02-25-2021, 21:49   #105 (permalink)
Member: 2704296
Sonork: 100.1677478
Thanks Meter: 30
Please add qualcom xiaomi and huwaie device
Best regards
The Following User Says Thank You to zakaria70 For This Useful Post:
Page generated in 0.22512 seconds with 10 queries
