Old 07-31-2020, 16:50   #76 (permalink)
nduka's Avatar
Member: 1943439
Sonork: 100.1669578
Thanks Meter: 214
after reset setting tab losses light
now display inside
----- > Phone/Tablet :
1. Power Off device
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable! Press 'POWER_ON' button for a few second!
----- > IoT/Box :
1. Reset device power
2. PRESS and HOLD 'RESET' KEY!
3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second!
Wait for device ...
Device Connected!
Interface test : Passed
Device mode : 0x0006
Device : RKM755_3126
#RECOVER_KEY: 1,1,0,20,0
ExtInfo : 4.4.2
SoC CPU : 312A
SoC PDT : 2014
SoC SWN : 0429
SoC REV : V100
Flash CSx : 0x00
Flash Type : ADDE14A742 [ NAND ]
Flash Vend : HYNIX
Flash Size : 0x0000000212000000 ( 8.28 GiB )
Flash Info : 4194304/16384/32/40/1
Connect Ok!
Wiping UserData ...
Wipe DATA Ok!
Done!
Elapsed: 00:00:02
Old 08-01-2020, 08:23   #77 (permalink)
Member: 148515
Thanks Meter: 19,534
now display inside
What do you mean "losses light" ?
Old 08-01-2020, 08:27   #78 (permalink)
Member: 148515
Originally Posted by aminbr25 View Post
hi, sir please waiting your reply?
Hi,
yes, checking it but can't say any results yet.
Old 08-01-2020, 23:16   #79 (permalink)
nduka's Avatar
Member: 1943439
Sonork: 100.1669578
Thanks Meter: 214
it shows or displayed inside
you cannot see on screen unless flash light
like when light ic of device is bad
thanks
Old 08-02-2020, 08:38   #80 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
thanks
Software sends default comands to device for make reset and rest work. It like factory/user reset from settings method.
Make sure you have left device for 10-15 minutes and reboot/check again. That not should affect anything at all, except some HW fault, like water or short circuit on led high power line.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 08-09-2020, 18:16   #81 (permalink)
Member: 2171849
Sonork: no
Thanks Meter: 110
Hi,
hi please any update about my issue?
Old 08-11-2020, 10:39   #82 (permalink)
Member: 2203464
please make support for latest QLM.. thanks infinity team
Old 08-11-2020, 10:45   #83 (permalink)
Member: 148515
Thank you for your advice ! We will keep it in mind !
Your request has been forwarded to qlm research department
Old 08-11-2020, 14:07   #84 (permalink)
Member: 100918
Thanks Meter: 13
Aoc A741 Frp
Operation : Identify [ v2.02 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
Device mode : 0x0100
SoC CPU : 312A
Flash CSx : 0x00
Flash Type : 2C644432A5 [ NAND ]
Flash Vend : MICRON
Flash Size : 0x000000020C000000 ( 8.19 GiB )
Flash Info : 8388608/16384/32/60/1
Connect Ok!
Board Platform : rk3126c
Patch Level : NHG47K
Display ID : A741_20180322
Ver. Incmt : user.liuh.20180322.182614
Ver. CodeName : REL
Ver. Release : 7.1.2
Sec. Patch : 2018-03-01
Build Time : 1521714374
Product Model : A741
Product Brand : AOC
Product Name : A741
Product Device : A741
Product Board : rk30sdk
Product Manfct : AOC
Product Info : rk3126c
Done!
Elapsed: 00:00:18
Operation : Reset Settings [ v2.02 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
SoC CPU : 312A
Flash CSx : 0x00
Flash Vend : MICRON
Connect Ok!
Remove FRP 0 ...
FRP removed!
Wiping UserData ...
Wipe DATA Ok!
Done!
Elapsed: 00:00:08
frp not removed
https://drive.google.com/file/d/1S84...ew?usp=sharing
The Following User Says Thank You to maxcer24 For This Useful Post:
Old 08-14-2020, 16:22   #85 (permalink)
Member: 100918
Thanks Meter: 13
Reading Flash Err0r Leotec LETAB731 Pulsar Qi
Operation : Read Firmware [ v2.02 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
SoC CPU : 312A
Flash CSx : 0x00
Flash Type : 2C64643CA5 [ NAND ]
Flash Vend : MICRON
Flash Size : 0x000000020A000000 ( 8.16 GiB )
Flash Info : 8388608/16384/32/40/1
Connect Ok!
Reading Flash Content ...
Error : Failed to convert data! Erased/Damaged device???
Send log and report.log to support! Include device info also!
Old 08-14-2020, 19:31   #86 (permalink)
Member: 1043909
Thanks Meter: 60,926
@maxcer24
Thanks for report, it was forwarded to research department
Old 08-19-2020, 23:31   #87 (permalink)
Member: 2171849
Sonork: no
Thanks Meter: 110
Hi,
hi sir any update about my request?
Old 08-21-2020, 23:02   #88 (permalink)
Member: 797068
Thanks Meter: 75
sw say: update firmware
[IMG][/IMG]
after donwload and install and run update firmware
[IMG][/IMG]
Old 08-28-2020, 13:15   #89 (permalink)
Member: 2171849
Sonork: no
Thanks Meter: 110
Hi,
Sir please waiting your reply please?
Old 08-28-2020, 13:37   #90 (permalink)
Member: 148515
Originally Posted by rochater View Post
[IMG][/IMG]
[IMG][/IMG]
Hello,
Probably your dongle support period is expired.
How to check - https://www.infinity-box.com/doc/?r=17
If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/
Page generated in 0.24350 seconds with 9 queries
