Old 08-12-2020, 06:27   #1 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,420
Smile Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.06 - Android 10, FastRead, FastFlash !
Core
Changed : FlashCore Protocol updated
Changed : DiagCore Protocol updated
Changed : NAND protocol adaptation
Changed : Operations speed increased
Flasher
Changed : Flash Engine updated
Changed : Handling for 64bit files optimized
Changed : Activated FastFlash V1 protocol *
Changed : Activated FastFlash V2 protocol *
!* FastFlash protocol allow increase flashing speed for big unsparsed images
!* FastFlash protocol reduce flashing time up to 4-6 times, depend on device configuration ( 3-4 minutes against 20-25 )
!* FastFlash activated automatically, if can be performed
!* GOOD USB cable and GOOD USB port must be used - do not use USB HUBs !
Changed : Support for new PAC formats activated ( v2.x.x line )
Service
Changed : Identify scheme : Read more accurate and complete info *
!* Include modern Android 9 and Android 10 devices
Changed : Precise FileSystem settings detection ( Type and Encryption algo )
Changed : Better security detection
Changed : Format FS / Reset settings updated
Firmware Reader
Changed : Reading speed up to 30% faster! *
!* Test feature, support modern UniSoc devices ( SC7731E, SC9832E, SC9863 )
!* Test feature, only RS-featured loaders supported!
Changed : Android 10 support activated! *
!* Support latest Android 9 and modern Android 10 devices from now!
!* Allow read complete firmware image from Android 10 devices without loss any ota/vendor abilities
Changed : X64 devices/loaders native support activated for complete reading
Changed : SW now create Android-version depend images for better compatibility
Changed : SW now create correct FileSystems bundle according device settings *
!* Almost reducing "hang" case after flashing
Changed : Improved structure identification
Changed : Support more different types
Changed : Structure identification and NAND reader more stable now ( complete E-series NAND adaptation will follow )
Model DB
Changed : New loaders included for various set of devices
Changed : New Generic loaders included and updated existing ones
Other
Changed : Removed outdated options from platform tab, many options changed to atomatic mode
BugFix : Minor changes and fixes
Info :
Android 10 enabled devices : SC7731E, SC9832E, SC9863
FastFlash enabled devices : SC9832E, SC9863
InfinityBox_install_CM2SP2_v2.06_Mega.nz Link
The Following 6 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 08-12-2020, 11:03   #2 (permalink)
Member: 1043909
Thanks Meter: 60,921
Yes here is it - https://forum.gsmhosting.com/vbb/f29...flash-2885291/
The Following User Says Thank You to YellowBoss For This Useful Post:
Page generated in 0.12049 seconds with 8 queries
