GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.07 - UltraReading & New Features (https://forum.gsmhosting.com/vbb/f296/infinity-chinese-miracle-2-sp2-spd-unisoc-v2-07-ultrareading-new-features-2895316/)
man power 09-07-2020 15:30
Nice and wonderful update
Gsm-Boss. 09-07-2020 16:17
nice
Service
BugFix [Identify] : FS state detection may fail for legacy SPD line, fixed
Changed [Identify] : SelfLearn / Automatic DB update during "Identify" rebuild
Changed [Identify] : Support detection of AES and RSA-enabled auth in devices/loaders
Changed [Identify] : Support correct BASE <-> DEVICE verification for optimal loader selection
BugFix [Read Privacy] : Privacy Lock reading on some devices may fail , fixed
NewFeature [Read Privacy] : Mobile AntiTheft password reading ( another version of "privacy lock" )
BugFix [Format FS] : Fixed Format FS in DiagMode for Android 10 and modern Android 9 devices
trust4eve83 09-07-2020 17:32
its aasking update dongle firmware
https://ibb.co/SwLZ14Z
=== DongleManager [Infinity] v1.80 [2020-09-07 17:16:21] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 00010A551FDD4082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): F18D0A55
Firmware version: 0144.02
=== Process started: 2020-09-07 17:16:23 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
but still aasking for update pls halp me what to do
YellowBoss 09-07-2020 18:05
Reading...
Hello,
Probably your dongle support period is expired.
How to check - https://www.infinity-box.com/doc/?r=17
If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/
djj007 09-07-2020 18:07
Always love to see infinity new update
KrzychuG 09-07-2020 18:52
Firmware Reader
Changed : Complete FWReader rebuild to cover most count of different devices, existing on market *
!* Almost all Flashing issues has been fixed, FWRead repeat required for problematic cases/models!
Changed : UltraReading option activated ! *
!* Now reading of UniSoc devices 3-5 times faster, than before
- approx 20 mins instead of 70 for SC9853i (2.2 GiB) comparing to older releases
- approx 12 mins instead of 40 for SC9832E (2.5 GiB) comparing to older releases
- approx 20 mins instead of 60 for SC9863 (4.4 GiB) comparing to older releases
- approx 15 mins instead of 50 for SC7731 (1.5 GiB) comparing to older releases
Does this finally allow to read whole storage chip, including userdata partiotion or that's still an issue with SPD/Unisoc chipsets?
eyobaaa 09-07-2020 19:40
Stunning update i like you infinity team but why not using usb 3.0? Please find another way
Best Regards | Bayaaa
malka4u 09-07-2020 19:42
Originally Posted by Yusuf Lawal (Post 14207666)
If not JAYDI SIR, WHO COULD BE?
WORLD BEST CODER.....
Yes .
But you are not quite following jaydi., Dzirt, cm2
Better keep quite . This topic is about cm2sp2 . Dont post off topic.
YellowBoss 09-07-2020 20:38
USB3 is not so stable, you may get many errors during read/write if you are using USB3
so I suggest you never use any USB hub and try to use USB2 port if possible
izatullah.andar 09-08-2020 04:38
please help how to chack cpu of spd .
i always chack one by one option don.t know
what cpu is in phone
for example. sc7731. sc7731e
ahmer5050 09-08-2020 07:34
read info in Daig Mode.
All Information will b show.
umerusman78 09-08-2020 09:33
nokia c1 reset done.
Operation : Format FS / Reset Settings [ v2.07 ]
Mode : Reset FRP
BootMode : SVC
1. Power off device, wait 10-15 seconds
2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
Wipe Ok : UserData
- > INFO : FRP reset require FlashMode!
Reconnect Power/Cable!
Done!
Elapsed: 00:00:47
JayDi 09-08-2020 11:37
Hello.
Probably, that will be separate option for Data Explorer.
hamidou092 09-08-2020 11:51
Itel p36 w6501 frp unlock and wipe userdata not supported.
Oyetunde Semiu 09-08-2020 11:54
Post here operation log results ...........
Page generated in 0.34724 seconds with 5 queries
