09-05-2020, 07:49 | #16 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Code: Operation : Identify [ v2.07 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : Philips Product Device : S266 Product Model : Xenium S266 Product Name : S266_RU Patch Level : QP1A.190711.020 Display ID : Philips_S266_2024_V03_RU Ver. Incmt : 23310 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-06-05 Build Time : 10.06.2020 Product Info : S266_RU Product Board : sp9863a_1h10 Board Platform : sp9863a Product Manfct : Philips NVMng : SecurityInfo IMEI[1] : 86xxxxxxxxxxxxxxx IMEI[2] : 86xxxxxxxxxxxxxxx IMEI[3] : 86xxxxxxxxxxxxxxx SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_18B_W20.21.5_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W20.21.5 HW Version: sc9863A_modem CMP_Time : 05-22-2020 09:14:00 MODEM TAG : MOCORTM_18B_W20.21.5_Debug_FM_BASE_18B_W20.21.5_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:02:00 Code: FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True |
The Following 9 Users Say Thank You to JayDi For This Useful Post: |
09-05-2020, 07:51 | #17 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | PrivacyLock reading fixed and working as should : Code: Operation : Read PrivacyLock [ v2.07 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! PASSWORD : 7zzzzzz6 CONTACTS : +9zzzzzzzzzzz7 Reconnect Power/Cable! Done! Elapsed: 00:00:26 |
The Following 8 Users Say Thank You to JayDi For This Useful Post: |
09-07-2020, 12:36 | #28 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | Mi One Write Flash Failed Mi One V3 Failed to write flash what is the problem . Battery is full charged . Cable is good but not able to flash this phone . Phone state at hang on logo also try with whole format flash even try with older ver of cm sp2 2.6 but same error Card found : BC555F6F , v0145 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.07 Load IDBase v8331 Ok! Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : J106G_Mione_V3_B15_V001_20191207 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-07-01 Build Time : 1575700551 Product Brand : MIONE Product Name : sp7731g_1h10_hd_oversea Product Device : sp7731g_1h10 Product Board : sp7731gea_hdr Product Manfct : MIONE Board Platform : sc8830 Product Info : sp7731g_1h10 Product Model : Mione V3 SECSolution : LEGACY [SS] Operation : Flash Firmware [ v2.07 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update failed! ERROR : 00000084:84000000FF7B7E00 SYS : OPERATION FAILED! Error : Flashing failed! Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process Reconnect Power/Cable! Operation : Identify [ v2.07 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.07 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731G_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Platform Version: MOCORTM_14B_MP_7731G_W17.22.4_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_W17.22.4 MMI Version: sc7731g_modem HW Version: sc7731g_CP0_modem CMP_Time : 05-31-2017 21:23:59 MODEM TAG : MOCORTM_14B_MP_7731G_W17.22.4_Debug_TM_BASE_W17.22 .4_sc7731g_CP0_modem_sc7731g_CP0_modem_sc7731g_mod em UserData : STATE : PLAIN [EXTFS] - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:56 Operation : Flash Firmware [ v2.07 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True Setting : WholeFLASH FORMAT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Flash Firmware [ v2.07 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True Setting : WholeFLASH FORMAT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731G_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! ERASE : FORMAT WHOLE FLASH ... ERASE : FORMAT FLASH Completed! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update failed! ERROR : 00000084:84000000FF7B7E00 SYS : OPERATION FAILED! Error : Flashing failed! Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process Reconnect Power/Cable! |
