Old 09-07-2020, 14:30   #31 (permalink)
Member: 2128067
Thanks Meter: 14
Nice and wonderful update
Old 09-07-2020, 15:17   #32 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 434
nice
Service
BugFix [Identify] : FS state detection may fail for legacy SPD line, fixed
Changed [Identify] : SelfLearn / Automatic DB update during "Identify" rebuild
Changed [Identify] : Support detection of AES and RSA-enabled auth in devices/loaders
Changed [Identify] : Support correct BASE <-> DEVICE verification for optimal loader selection
BugFix [Read Privacy] : Privacy Lock reading on some devices may fail , fixed
NewFeature [Read Privacy] : Mobile AntiTheft password reading ( another version of "privacy lock" )
BugFix [Format FS] : Fixed Format FS in DiagMode for Android 10 and modern Android 9 devices
Old 09-07-2020, 16:32   #33 (permalink)
trust4eve83's Avatar
Member: 1269056
Thanks Meter: 1,085
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.07
its aasking update dongle firmware
=== DongleManager [Infinity] v1.80 [2020-09-07 17:16:21] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 00010A551FDD4082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): F18D0A55
Firmware version: 0144.02
=== Process started: 2020-09-07 17:16:23 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
but still aasking for update pls halp me what to do
Old 09-07-2020, 17:05   #34 (permalink)
Member: 1043909
Thanks Meter: 54,528
Reading...
Hello,
Probably your dongle support period is expired.
How to check - https://www.infinity-box.com/doc/?r=17
If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 09-07-2020, 17:07   #35 (permalink)
Member: 2643730
Thanks Meter: 701
Always love to see infinity new update
Old 09-07-2020, 17:52   #36 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 158
Firmware Reader
Changed : Complete FWReader rebuild to cover most count of different devices, existing on market *
!* Almost all Flashing issues has been fixed, FWRead repeat required for problematic cases/models!
Changed : UltraReading option activated ! *
!* Now reading of UniSoc devices 3-5 times faster, than before
- approx 20 mins instead of 70 for SC9853i (2.2 GiB) comparing to older releases
- approx 12 mins instead of 40 for SC9832E (2.5 GiB) comparing to older releases
- approx 20 mins instead of 60 for SC9863 (4.4 GiB) comparing to older releases
- approx 15 mins instead of 50 for SC7731 (1.5 GiB) comparing to older releases
Does this finally allow to read whole storage chip, including userdata partiotion or that's still an issue with SPD/Unisoc chipsets?
Old 09-07-2020, 18:40   #37 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 253
Stunning update i like you infinity team but why not using usb 3.0? Please find another way
Best Regards | Bayaaa
Old 09-07-2020, 18:42   #38 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 854
Originally Posted by Yusuf Lawal View Post
If not JAYDI SIR, WHO COULD BE?
WORLD BEST CODER.....
Yes .
But you are not quite following jaydi., Dzirt, cm2
Better keep quite . This topic is about cm2sp2 . Dont post off topic.
Old 09-07-2020, 19:38   #39 (permalink)
Member: 1043909
USB3 is not so stable, you may get many errors during read/write if you are using USB3
so I suggest you never use any USB hub and try to use USB2 port if possible
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 09-08-2020, 03:38   #40 (permalink)
Member: 2138272
Sonork: 100.1650629
Thanks Meter: 36
please help how to chack cpu of spd .
i always chack one by one option don.t know
what cpu is in phone
for example. sc7731. sc7731e
Old 09-08-2020, 06:34   #41 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 615
read info in Daig Mode.
All Information will b show.
The Following 2 Users Say Thank You to ahmer5050 For This Useful Post:
Old 09-08-2020, 08:33   #42 (permalink)
Member: 1524022
Sonork: 100.1608738
Thanks Meter: 38
nokia c1 reset done.
Operation : Format FS / Reset Settings [ v2.07 ]
Mode : Reset FRP
BootMode : SVC
1. Power off device, wait 10-15 seconds
2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
Wipe Ok : UserData
- > INFO : FRP reset require FlashMode!
Reconnect Power/Cable!
Done!
Elapsed: 00:00:47
The Following User Says Thank You to umerusman78 For This Useful Post:
Old 09-08-2020, 10:37   #43 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 17,237
Hello.
Probably, that will be separate option for Data Explorer.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 09-08-2020, 10:51   #44 (permalink)
Member: 2669142
Itel p36 w6501 frp unlock and wipe userdata not supported.
Old 09-08-2020, 10:54   #45 (permalink)
Member: 2812901
Thanks Meter: 436
Post here operation log results ...........
Page generated in 0.23416 seconds with 7 queries
