Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #31 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2017 Location: GOLD SINDH
Member: 2705849 Status: Offline Thanks Meter: 474 | |
![]() | #35 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: QQ id 2593032292
Member: 189673 Status: Offline Sonork: 100.1592062 Thanks Meter: 344 | Quote:
![]() E241s Spreadtrum SC9820E help me how to connect this phone i want to format this phone .... i am having error Code: Operation : Identify [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! | |
![]() | #36 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 462970 Status: Offline Thanks Meter: 18,742 | Quote:
It can be Call button, or Mic button , or 5 button or 0 button. According log you just insert cable in device, it is diag one. Since it KaiOs - you can format it in diagMode too. But interest to read FW from it too, since device is rare. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
![]() | #38 (permalink) |
Member: 189673 Status: Offline Sonork: 100.1592062 Thanks Meter: 344 | Operation : Format FS / Reset Settings [ v2.09 ] Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Reconnect Power/Cable! Done! Elapsed: 00:00:26 |
The Following 2 Users Say Thank You to sameera For This Useful Post: |
![]() | #39 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks Meter: 17,695 | @cheeni @alpona_su Thank you for your good advices but you must read thread title before make posts. Once again thank you for your kind understanding and future reading ! P.S. Offtopic posts was deleted Last edited by InfinityHelp; 11-18-2020 at 13:27. |
![]() | #40 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 17,695 | Quote:
It was happened because your phone battery was empty and you did not connected phone to cable and you forgot to connect cable to PC USB port. Also maybe your PC was powered off and whole city had no electricity last days. Probably it was aliens near your table. Who knows... Please always post software operation log text. Without log text we have no ideas. | |
![]() | #41 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,431 | Vgo tel ocean 6 full flash done by cm2 sp2 2.09 VGO TEL OCEAN 6 FULL FLAS DONE BY CM2 SP2 2.09 Card found : 73CA70CC , v0146 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.09 Load IDBase v8331 Ok! Operation : Identify [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : NRD90M Display ID : VGOTEL_OCEAN_6_V05_15112017 Ver. Incmt : 1507716513 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-10-05 Build Time : 14.11.2017 Product Model : Ocean 6 Product Brand : VGOTEL Product Name : VGOTEL_OCEAN_6 Product Device : VGOTEL_OCEAN_6 Product Board : sp7731cea Product Manfct : VGOTEL Board Platform : sc8830 Product Info : sp7731c_1h10 Platform Version: MOCORTM_W17.14.5_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W17.14.5 MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 04-07-2017 14:07:41 MODEM TAG : MOCORTM_W17.14.5_Debug_TM_BASE_W17.14.5_sc7731C_CP 0_modem_sc7731C_CP0_modem_sc7731C_modem - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:07 Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : NRD90M Display ID : VGOTEL_OCEAN_6_V05_15112017 Ver. Incmt : 1507716513 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-10-05 Build Time : 14.11.2017 Product Model : Ocean 6 Product Brand : VGOTEL Product Name : VGOTEL_OCEAN_6 Product Device : VGOTEL_OCEAN_6 Product Board : sp7731cea Product Manfct : VGOTEL Board Platform : sc8830 Product Info : sp7731c_1h10 SECSolution : LEGACY [SS] Operation : Flash Firmware [ v2.09 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x19 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : wmodem.bin CODE : wdsp.bin CODE : modem_wcn.img CODE : boot_logo.bmp CODE : fastboot_logo.bmp CODE : boot.img FSIMG : system.img FSIMG : persist.img CODE : tos.bin CODE : vmm.bin FSIMG : sysinfo.bin FSIMG : cache.img CODE : recovery.img FSIMG : userdata.img UBOOT : u-boot.bin UBOOT : u-boot-spl.bin ERASE : WFLASH ERASE : WCNFLASH ERASE : MISC Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:08:02 |
The Following 4 Users Say Thank You to A.G.Shahid For This Useful Post: |
![]() | #42 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: Dhaka
Member: 634326 Status: Offline Sonork: 01911289141 Thanks Meter: 15 | my cm2 active but my cm2 spd2 not open what si problem my cm2 update but cm2 spd2 v2.09 v2.07 not open what is the problem Last edited by InfinityHelp; 11-18-2020 at 14:25. |
![]() | #43 (permalink) | |
Please follow the next steps - https://www.infinity-box.com/support/?r=100127 Result ? | |
![]() | #45 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2012 Location: Malawi, Africa
Member: 1814195 Status: Offline Thanks Meter: 17 | Quote:
