05-23-2021, 19:58 | #121 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
06-06-2021, 15:50 | #126 (permalink) |
Freak Poster Join Date: Jun 2003 Location: zimbab Age: 46
Member: 32705 Status: Offline Thanks Meter: 66 | Operation : SP Unlock [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 358041430161861 IMEI[2] : 358041430661860 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:2 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:01:11 |
The Following User Says Thank You to neville For This Useful Post: |
06-07-2021, 07:45 | #127 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | New version released: Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.12 - New repair level activated https://infinity-box.com/support/?r=100152 |
07-31-2021, 17:42 | #128 (permalink) |
Junior Member Join Date: Jan 2017 Location: south africa
Member: 2675958 Status: Offline Thanks Meter: 0 | Card found : EBF8AB73 , v0149 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.13 ] Mode : Default [ Reset Settings + FRP ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.13 ] Mode : Default [ Reset Settings + FRP ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Wipe failed! >>> INFO : FRP reset require FlashMode! Reconnect Power/Cable! Done! Elapsed: 00:00:19 trying to remove pasSword on Nokia TA-1264 |
09-04-2021, 08:50 | #135 (permalink) |
Insane Poster Join Date: Nov 2007 Location: india, kakinada
Member: 627678 Status: Offline Thanks Meter: 14 | Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS_LOW Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! And also I had tried another boot's . But not get Unisoc UMS9117 boot info (Nokia TA 1289) |
