Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #32 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2013 Location: zimbabwe
Member: 2075865 Status: Offline Thanks Meter: 99 | still returning server error(FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable!) disabled all firewall and antivirus... |
![]() | #34 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: private
Member: 1043909 Status: Online Thanks Meter: 60,450 | Quote:
Also if you can keep phone with you - keep it for some time for the fture tests. And send a mial to [email protected] - we will try to contact you back if it will be something new to try | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
![]() | #35 (permalink) | |
Member: 2075865 Status: Offline Thanks Meter: 99 | Quote:
![]() | #37 (permalink) |
Member: 2075865 Status: Offline Thanks Meter: 99 | Operation : Flash Firmware [ v2.13 ] Setting : Update NVRAM : True Setting : Force NVRAM : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : W6502-F3108-10.0-OP-V028-20210304_1620_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x28 PMTMng : Update PMT Ok! NVRM : pike2_pubcp_PLD_base_nv_nvitem.bin NVMng : Load 0x17 NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 350729342520921 IMEI[2] : 350729342520939 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 NVMng : Backup Ok , 0x00066B28 NVMng : Init DST NVMng : Rx11 : Wx10 NVMng : NVM block updated! Prepare target ... Prepare Ok! CODE : logo.bmp ERASE : UBOOT FSIMG : cache.img CODE : cover.img CODE : dtbo.img CODE : SC9600_pike2_pubcp_PLD_base_nv_modem.dat CODE : tos-sign.bin CODE : boot.img ERASE : W_RUNTIMENV1 CODE : recovery.img ERASE : SYSDUMPDB FSIMG : socko.img CODE : sml-sign.bin CODE : vbmeta_vendor.img CODE : delta_nv.bin FSIMG : itel.img ERASE : METADATA CODE : pike2_cm4.bin CODE : PIKE2_DM_DSP.bin CODE : logo.bmp(1) CODE : vbmeta-sign.img ERASE : MISC FSIMG : userdata.img UBOOT : u-boot-spl-16k-sign.bin ERASE : UBOOT_LOG CODE : PM_pike2_cm4_v2.bin FSIMG : super.img UBOOT : u-boot-sign.bin FSIMG : odmko.img CODE : prodnv.img CODE : gnssbdmodem.bin FSIMG : persist.img CODE : gnssmodem.bin CODE : vbmeta_system.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:02:29 Thanks Sir Jay Di as you can see on logs, it worked like a charm!!!!. Keep the good work team. You always offer world first solution like no other in GSM. Itel W6501 |
The Following 4 Users Say Thank You to kngoya For This Useful Post: |
![]() | #39 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,744 | Quote:
If possible to drop test software in my pm too. Thanks in advance. | |
![]() | #40 (permalink) | |
![]() | #41 (permalink) | |
Member: 1677653 Status: Offline Thanks Meter: 2,744 | Itel p36 [w6501] write firmware done Quote: Setting : Update NVRAM : True Setting : Force NVRAM : False Setting : Update PMT : False 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : W6501-F3111-9.0-OP-V034-20210406_1105_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVRM : pike2_pubcp_PLD_base_nv_nvitem.bin NVMng : Load 0x17 NVMng : Init SRC NVMng : Trying use recover mode NVMng : Security DAMAGED! NVMng : Backup Ok , 0x00100000 NVMng : Trying use recover mode NVMng : Init DST NVMng : NV has been destroyed! Forced Update disabled! Skip NVM flashing! Prepare target ... Prepare Ok! ERASE : UBOOT CODE : prodnv.img CODE : sml-sign.bin CODE : dtb.img CODE : gnssmodem.bin FSIMG : vendor.img FSIMG : cache.img ERASE : W_RUNTIMENV1 ERASE : UBOOT_LOG CODE : tos-sign.bin CODE : gnssbdmodem.bin FSIMG : userdata.img CODE : PIKE2_DM_DSP.bin UBOOT : u-boot-spl-16k-sign.bin CODE : vbmeta-sign.img CODE : logo.bmp(1) CODE : SC9600_pike2_pubcp_PLD_base_nv_modem.dat FSIMG : system.img CODE : PM_pike2_cm4.bin FSIMG : persist.img FSIMG : product.img CODE : dtbo.img CODE : pike2_cm4.bin CODE : logo.bmp CODE : cover.img CODE : delta_nv.bin CODE : boot.img CODE : recovery.img ERASE : MISC UBOOT : u-boot-sign.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:06:22 | |
The Following 3 Users Say Thank You to Yusuf Lawal For This Useful Post: |
