Old 06-07-2021, 07:40   #1 (permalink)
Member: 148515
Thanks Meter: 19,347
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.12 - New repair level activated
As ordinary, unique functions and methods released
CM2SP2 with SPD unlock enabled
List of SPD unlock supported models
Core
Changed: FlashCore protocol updated (R25)
Changed: New DL-core support (v10 at Infinity notation)
NewSOC: SC9820e [RS/0S] with NAND supported
Changed: Diag protocol updated
Flasher
Changed: Protocol updated
Changed: FlashCore rebuild
- Reworked FlashErase
- Reworked support of fully erased or semi-damaged modern devices Android 8/9/10/11 (SC9820e, SC7731e, SC9832e, SC9863, SC9850), it is possible to repair these devices from any state (in case of working HW)
- Reworked NVRecovery procedure
- Android version change ( Downgrade/Upgrade ) now work more correct
Firmware reader
Changed: Android 10 specific changes
Changed: KaiOs specific changes
Changed: Initial Android 11 support
Changed: UltraRead protocol updated
Changed: Fixed "Encryption Unsucessfull" errors on some devices after flash
SPUnlock
Changed: Android 11 SPunlock and Repair confirmed and working
Changed: UniSoc Tiger T310 initial SPUnlock/Repair support
Changed: Changed unlock procedure for some devices
Changed: Allow check status/continue unlock on zero balance
Almost all existing on market devices for SP-Unlock and Repair are supported, Android 10 / 11 "security" as well
Model DB
Changed: New generic loaders included for 9820E with NAND
Other
Changed: Many other different changes and fixes
Download link #1
Download link #2
Download link #3
Password for files: 12345678
Infinity-Box as nobody else since year 2005
The Following 69 Users Say Thank You to InfinityHelp For This Useful Post:
Old 06-07-2021, 08:06   #2 (permalink)
limonbogra's Avatar
Member: 2856614
Sonork: 100.650600
Thanks Meter: 240
good update tnx cm2 team
Old 06-07-2021, 08:10   #3 (permalink)
UM4
Member: 2781773
Thanks Meter: 136
Thanks good update team.
Old 06-07-2021, 08:14   #4 (permalink)
Member: 2058613
Thanks Meter: 24
Always On top.......... CM2 is Best team ever
Old 06-07-2021, 08:18   #5 (permalink)
Member: 2171001
Thanks Meter: 193
good update keep it up
Old 06-07-2021, 08:38   #6 (permalink)
Member: 391871
Thanks Meter: 15
good update thanks cm2 team
Old 06-07-2021, 08:44   #7 (permalink)
Member: 1948608
Thanks Meter: 1,743
Request...!Add-Enable Flash Mode for Nokia Unisoc like C1/C2, read/ write/ repair to SP2 or BEST2...
The Following 9 Users Say Thank You to -Mosin- For This Useful Post:
Old 06-07-2021, 09:19   #8 (permalink)
Member: 2534995
Thanks Meter: 88
Best of the Best team
Old 06-07-2021, 09:24   #9 (permalink)
Member: 2711874
Sonork: 100.650600
Thanks Meter: 462
Always good update infinity cm2 TEAM
Old 06-07-2021, 09:48   #10 (permalink)
Member: 148515
[BEST] is under deep rebuild now, in some time it should be released with the new features.
The Following 14 Users Say Thank You to InfinityHelp For This Useful Post:
Old 06-07-2021, 09:56   #11 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 478
plz add cm2 firmware to pac file and resat screen lock without data lost
thanx you
Old 06-07-2021, 10:03   #12 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,343
thanx you
Hello.
PAC not need, because SP2 can read and flash FW without any problems.
Till now no one made any similar to our solution, except "noise" , based on newest loaders with pmt_read cmd enabled.
Forensic are going in DataExplorer module.
SPD forensic inside.
The Following 12 Users Say Thank You to JayDi For This Useful Post:
Old 06-07-2021, 10:30   #13 (permalink)
Member: 2982113
Sonork: 100.1657924
Thanks Meter: 3
Always Good Update Infinity CM2
Old 06-07-2021, 10:31   #14 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 927
can you make Xiaomi Tool Please
The Following User Says Thank You to Gsm-Boss. For This Useful Post:
Old 06-07-2021, 10:45   #15 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,552
Wink
Work regarding many features is in progress
What features You need?
Page generated in 0.19336 seconds with 8 queries
