05-23-2022, 19:07 | #166 (permalink) | |
Please un-tick diag and use flash mode | |
06-22-2022, 09:03 | #167 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : L6502-F3208-10.0-IN-V020-20201012_1434_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : Access denied: {"Message":"Access denied `00D25BA064` order"} >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
06-22-2022, 09:43 | #168 (permalink) | |
read https://infinity-box.com/service/ | |
06-22-2022, 12:59 | #170 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | solution is here https://infinity-box.com/service/ |
10-07-2022, 22:41 | #173 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | I tried to identify, it worked but when I try to reset frp is says it's done but is still locked. I don't have acces to the computer I tried to show you the log. |
04-08-2023, 09:28 | #175 (permalink) |
Junior Member Join Date: Nov 2013 Location: Узбе&# Age: 36
Member: 2073073 Status: Offline Thanks Meter: 0 | Device Connected! BootVersion : SPRD3 Boot : INF : INFINIX MOBILITY LIMITED : X6816C-GL Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : Access denied: ^^Username `03F6A3A26A` Wrong username or password Product 908 declined Support expired 2023-01-30 please renew it >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
