10-08-2021, 19:16 | #76 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
SP2 are not designed to work with this security type yet. Most probably - will not in near time at all. | |
10-09-2021, 07:08 | #77 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Quote:
Code: Card found : **** , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_NAND_256MB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : KTU84P Ver. CodeName : REL Ver. Release : 4.4.4 Build Time : 11.05.2021 Product Manfct : SPRD Board Platform : sp7731e Product Model : SW006C Product Board : SW006C Product Info : SW006C Display ID : M560F3_00.05.25RDD_AF.00 Ver. Incmt : M560F3_00.05.25RDD_AF.00 Product Model : N1 Product Device : Sanza Product Name : Sanza Product Brand : Orange Product Manfct : CMDC FlashInfo : 128k / 2k UserData : STATE : PLAIN [UBIFS] - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:09 Operation : Read FW [ v2.14 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_NAND_256MB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : KTU84P Ver. CodeName : REL Ver. Release : 4.4.4 Build Time : 11.05.2021 Product Manfct : SPRD Board Platform : sp7731e Product Model : SW006C Product Board : SW006C Product Info : SW006C Display ID : M560F3_00.05.25RDD_AF.00 Ver. Incmt : M560F3_00.05.25RDD_AF.00 Product Model : N1 Product Device : Sanza Product Name : Sanza Product Brand : Orange Product Manfct : CMDC AndroidVer : 4 VlnrLevel : 0x01 FlashInfo : 128k / 2k SP7731E__CMDC__N1__4.4.4__M560F3_00.05.25RDD_AF.00__KTU84P__SW006C Read : prodnv.img Read : phase.cfg Read : recovery.img Fail to readout data from device! ERROR : 0000008A:8A000000FF757E00 GEN : UNKNOWN RESPONSE! >>> Error : Failed to read data! Unexpected end of data! >>> Check cable, connection and drivers! Reconnect Power/Cable! | |
10-10-2021, 09:56 | #78 (permalink) | |
InfinityBox/SP2/SPRD/ | |
10-15-2021, 08:59 | #80 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 818995 Status: Offline Thanks Meter: 75 | Card found : EAEB2EC7 , v0146 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.06 Load IDBase v8331 Ok! Operation : Identify [ v2.06 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.06 ] Mode : Reset FRP BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Wipe Ok : UserData Info : FRP reset require FlashMode! Reconnect Power/Cable! Done! Elapsed: 00:00:30 How to ix this respected's. Last edited by mandeep145; 10-15-2021 at 09:05. |
10-15-2021, 09:24 | #81 (permalink) | |
Member: 818995 Status: Offline Thanks Meter: 75 | Quote:
How to reset frp. FRP reset require FlashMode! | |
10-15-2021, 10:10 | #82 (permalink) |
Insane Poster Join Date: May 2015
Member: 2393670 Status: Offline Thanks Meter: 14 | itel A571W NOT SUPPORTED FRP this is info by diag mode ; 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : A571W-F3116-10.0-OP-V020-20210723 MemoryInfo : EMMC : 16 GB ; DRAM : 1 GB Platform Version: MOCORTM_17C_W20.21.2_P9_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W20.21.2_P9 HW Version: sc7731e_modem CMP_Time : 01-28-2021 11:10:37 MODEM TAG : MOCORTM_17C_W20.21.2_P9_Debug_FM_BASE_17C_W20.21.2 _P9_sc7731e_modem_pike2_pub PSN1 : 0618535146001155 NVMng : SecurityInfo IMEI[1] : 350829117265007 IMEI[2] : 350829117265015 WIFIMAC : 20D27629FF2C BT_MAC : 20D27629FF2B SEC : SLS:0, SKS:0, SKV:4 Done! Elapsed: 00:00:23 |
The Following User Says Thank You to kasykasy For This Useful Post: |
10-15-2021, 16:06 | #86 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Here is Infinity discussion, you can get more info here https://infinity-box.com/ | |
10-15-2021, 16:06 | #87 (permalink) | |
Make this to get it fixed https://infinity-box.com/support/?r=100155 Is it Ok now? | |
10-15-2021, 17:34 | #88 (permalink) |
Junior Member Join Date: Dec 2011 Location: Harare
Member: 1704516 Status: Offline Thanks Meter: 0 | spd unlock failed after credits deducted Card found : 5B77325C , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15. 3_P5_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748975117601 IMEI[2] : 356748975117619 WIFIMAC : 44917C0ED0D8 BT_MAC : 44917C0ED0D7 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 5, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15. 3_P5_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748975117601 IMEI[2] : 356748975117619 WIFIMAC : 44917C0ED0D8 BT_MAC : 44917C0ED0D7 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 0, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15. 3_P5_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748975117601 IMEI[2] : 356748975117619 WIFIMAC : 44917C0ED0D8 BT_MAC : 44917C0ED0D7 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 0, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15. 3_P5_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748975117601 IMEI[2] : 356748975117619 WIFIMAC : 44917C0ED0D8 BT_MAC : 44917C0ED0D7 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 0, price:5 Process... Process failed : Wrong SS - device security damaged Reconnect Power/Cable! Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15. 3_P5_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748975117601 IMEI[2] : 356748975117619 WIFIMAC : 44917C0ED0D8 BT_MAC : 44917C0ED0D7 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 0, price:5 Process... Process failed : Wrong SS - device security damaged Reconnect Power/Cable! Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15. 3_P5_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748975117601 IMEI[2] : 356748975117619 WIFIMAC : 44917C0ED0D8 BT_MAC : 44917C0ED0D7 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 0, price:5 Process... Process failed : Reconnect Power/Cable! |
10-18-2021, 10:53 | #89 (permalink) |
Major Poster Join Date: Jul 2013 Location: Zimbabwe, Chitungwiza
Member: 1977119 Status: Offline Thanks Meter: 17 | nokia c20 not unlocking, if i reconnect after 15 minutes it keeps repeating the process and saying wait 10-15 mins.. credits already deducted Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.270_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P7_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P7 HW Version: sc9863A_modem CMP_Time : 06-08-2021 11:05:19 MODEM TAG : MOCORTM_20A_W21.15.3_P7_Debug_4G_MODEM_20A_W21.15. 3_P7_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748977240021 IMEI[2] : 356748977240039 WIFIMAC : 44917C17B46F BT_MAC : 44917C17B46E SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 40, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! |
The Following User Says Thank You to batsiraidick For This Useful Post: |
