error android 11 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : PR651H-F6317-11.0-OP-V043-20210729.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : Access denied: {"Message":"Access denied `aminu` auth"} >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
Itel w6501 (s15 pro) not supported but i selected the model Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
Realme C11 2021 RMX3231 imei repair error Quote:
Itel w6501 (s15 pro) not supported Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! READ INFO BY DIAG MODE 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : W6501-F3111-9.0-OP2-V022-20210402 MemoryInfo : EMMC : 32 GB ; DRAM : 2 GB Platform Version: MOCORTM_17C_ITEL_RLS2_W19.28.5_P8_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_ITEL_RLS2_W19.28.5_P8 HW Version: sc7731e_modem CMP_Time : 08-28-2020 00:46:28 MODEM TAG : MOCORTM_17C_ITEL_RLS2_W19.28.5_P8_Debug_FM_BASE_17 C_ITEL_RLS2_W19.28.5_P8_sc7731e_modem_pike2_pub PSN1 : 0569635066013067 NVMng : SecurityInfo IMEI[1] : 353812116667909 IMEI[2] : 353812116667917 WIFIMAC : 40D25F6F5399 BT_MAC : 40D25F6F5398 SEC : SLS:0, SKS:0, SKV:4 Done! Elapsed: 00:00:24 |
https://mega.nz/file/Q1RySLKR#brA3tJ...pp7O60KLrLjM6A |
zte blade a7 2019 imei repair problem after repair no network and block Operation : Repair Security [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : ZTE : ZTE_BLADE_A5_A7_[2019] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 359835081210466 IMEI[2] : 359835081210466 IMEI[3] : 867400020316638 SEC : SLS:2, SKS:0, SKV:0 New SecInfo : IMEI[1] : 359835081210466 IMEI[2] : 359835086210461 IMEI[3] : 359835081210466 >>> Info : Signed device, security repair may lead to break device! NVMng : Item updated! NVMng : Post-Process Ok! Done! Elapsed: 00:02:00 |
pls am having issue with my cm2 dongle. it brings card misconfigurations. Username: 00FDC5A942 |
Thanks Team for good update . |
Also no network? |
after repair full block |
