04-26-2022, 12:32 | #227 (permalink) |
Freak Poster Join Date: Oct 2020 Location: The city of Nag Hammadi Age: 33
Member: 2969908 Status: Offline Thanks Meter: 50 | Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 39C88F44F34D680C9086D143238C3682 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : C981BF510EBADEB2B061FB3D3C7097DBBFE0EC9C11E45B3557 F681C095E78705 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 13014E47314A39523810134C010358BD EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395238 : PRV : 0x10 EMMC: VEN : MICRON : G1J9R8 EMMC: SNN : 323748099 ( 0x134C0103 ) , MF : 5/2021 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 13014E47314A39523810134C010358BD EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395238 : PRV : 0x10 EMMC: VEN : MICRON : G1J9R8 EMMC: SNN : 323748099 ( 0x134C0103 ) , MF : 5/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : AC7DBE9054C988E7AB7510C5A56C9391 DA : USB : HIGH-SPEED Boot done! SmartInfo : Failed to detect! Info : Device is not supported yet! >>> Send log and report.log (if exists) to support! Include device info also! Reconnect Power/Cable! Oppo Reno7 Pro 5G |
04-29-2022, 12:00 | #228 (permalink) |
Freak Poster Join Date: Mar 2016 Location: Alexandra ,Johannesburg
Member: 2549090 Status: Offline Sonork: JIJO ALEX Thanks Meter: 9 | Mobicel X4 Fails to Identify Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : True ; EMMC_PART : False ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:25 |
04-29-2022, 12:02 | #229 (permalink) |
Member: 2549090 Status: Offline Sonork: JIJO ALEX Thanks Meter: 9 | Operation : Read FW [ v2.14 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : True ; EMMC_PART : False ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! >>> Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! >>> Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
05-05-2022, 21:06 | #230 (permalink) |
Junior Member Join Date: Jul 2015 Location: Nigeria
Member: 2435886 Status: Offline Thanks Meter: 1 | PLEASE REFUND CREDITS INFINITY BOX CHARGE 10 CREDITS FOR UNLOCKING DEVICE PLEASE REPLY ME Card found : 5B715C61 , v0152 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.610_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P17_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P17 HW Version: sc9863A_modem CMP_Time : 10-29-2021 20:11:24 MODEM TAG : MOCORTM_20A_W21.15.3_P17_Debug_4G_MODEM_20A_W21.15 .3_P17_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748979725607 IMEI[2] : 356748979725615 WIFIMAC : 44917C23767D BT_MAC : 44917C23767C SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 25, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.610_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P17_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P17 HW Version: sc9863A_modem CMP_Time : 10-29-2021 20:11:24 MODEM TAG : MOCORTM_20A_W21.15.3_P17_Debug_4G_MODEM_20A_W21.15 .3_P17_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748979725607 IMEI[2] : 356748979725615 WIFIMAC : 44917C23767D BT_MAC : 44917C23767C SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 20, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:41 |
05-20-2022, 10:50 | #232 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | No problem friend, get it here https://infinity-box.com/service/ |
05-20-2022, 10:54 | #233 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Quote:
You must always check your account before post fake info. | |
05-20-2022, 10:55 | #234 (permalink) | |
05-20-2022, 10:56 | #235 (permalink) | |
05-20-2022, 10:57 | #236 (permalink) | |
06-01-2022, 22:38 | #240 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,051 | Error in removing FRP of Realme C21Y RMX3263 in Flash MODE Code: Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : C21Y_RMX3263_RMX3261_RMX3262 Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Code: Operation : Identify [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : SVC Card found : 33171D07 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Wipe Ok : UserData >>> INFO : FRP reset require FlashMode! Reconnect Power/Cable! Done! Elapsed: 00:00:23 xerraco |
