Club M300 hang on Logo Done:) Code: Settings : SmartFormat is On |
Hello really best team but we very ineed the big intersting about the best tool in world of nokia and mtk ..etc so we hoppe to make the dongle work all mtk (all andriod system) even orignal samsung can be flashing with the dongle. and .I hoppe this message can be effectively. the best team infinity. |
Symphony E75 write flash dune ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 t TeSync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 % Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7715_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_sc7715_wcn_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:04:41 Reconnect Power/Cable! Finish at : [7/8/2015 / 6:09:46 PM] |
Spice MI-362 read Pattern done- Code: Loading : 7715_4.4.2_C936W_XLL_Spice_Mi-362_EMCP2x2_V09_20140925.pac |
Lava iris 414 flashing done- Code: Operation : Flash [ v1.02 ] |
Karbonn A81 Flashing Done. Spreadtrum SC7715 With eMMC - World First!!! Operation : Check/Read Info [ v1.02 ] Code: 1. Remove battery. Insert battery back Operation : Flash [ v1.02 ] Code: ======= Flash Note : Karbonn A81 Have Two Types Of Hardware Version : One Is With 256MB RAM + 2GB ROM & The Second One Is With 512MB RAM + 4GB ROM. Above Cellphone Is The First One With 256MB RAM + 2GB ROM. Flashing Procedure : Press & Hold Volume Down Key Then Insert Normal USB Cable Then Insert Battery. |
Hello. Just try one-by-one , or use Google to fast search. All take 1-2 minutes at all without opening the phone. |
intex life 2 spd 7730 pattern read success Card found: S/N A0C2:0128 Chinese Miracle II [SPD module] v 1.02 Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/SC7731 loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : v120_kew_281 Model Brand : Intex Model Device: v120_kew_281 AndrVersion : 4.4.2 BaseBand CPU: V120_KEW_281 CompileDate : 1428487956 Project Ver : KOT49H 14B_test-keys Model Ext : Aqua Life II Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/SC7731 loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 8457 Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
M-HORSE smartphone s51 Phone password done Quote:
1: Open InfinityBox CM2SPD tool 2: Go to settings tab and select CPU: [SP7715]NAND[Generic 3: Go to Service tab, tic Read in Boot and press Check info Button 4: Remove battery from phone and put back hold boot keys (volume up & down) at same time then insert micro usb cable, If spd sc2 drivers are installed propely pone will give boot info. Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Reading PatternLock ... PatternLock Not Set! Elapsed: 00:02:54:) 5: Last step on that service tab Press Format Fs/Reset Phone and Remove battery from phone and put back hold boot keys (volume up & down) at same time then insert micro usb cable then Done Operation : Format File System [ v1.02 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! Big Thanks To Inifinity Team:):):):) |
Lava Iris X1 Beat read Pattern and NV done- Read Pattern lock- Code: Loading : Lava_iris_X1_Beats_S112_20150411.pac Code: Operation : Read NV [ v1.02 ] |
but friends can anyone please help me on how to read pac file from spd phones ???.the so called chinese boxes are just full of crap.i have tried all but none can read a perfect pac. |
In fact - there is not so easy do that correctly. I plan activate "PAC" reading for some platforms in few near version, will work like it work in CM2MTK module - connect phone, press button , get result. Without root and rest long and strange stuff. |
