11-22-2017, 15:37 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: RWP Pakistan
Member: 420821 Status: Offline Sonork: 100.1603493 Thanks Meter: 731 | 2nd tag-al00 dead by cm2 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! now phone cnt power on |
11-22-2017, 15:46 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | According to your Sw logs,NOTHING was done to your phone. Code: Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! |
11-22-2017, 16:18 | #5 (permalink) |
Member: 420821 Status: Offline Sonork: 100.1603493 Thanks Meter: 731 | User selected Preloader file : preloader_hq6753_66t_b2b_l1.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100513331334D42 , Name : Q313MB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 13014E52314A39364E , Name : R1J96N , Vendor : 13 , [NOT_IN_BASE] FlashID [4] CID : 110100303136473332 , Name : 016G32 , Vendor : 11 , [TOSHIBA] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333133F1080642A19147CA Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM313 [eMMC] : FLASH_CID : 150100513331334D420608F1CA47C2A1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB7884B7A5120439695B4FA0F8C6DC8F3 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 179A BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100513331334D42 , Name : Q313MB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 13014E52314A39364E , Name : R1J96N , Vendor : 13 , [NOT_IN_BASE] FlashID [4] CID : 110100303136473332 , Name : 016G32 , Vendor : 11 , [TOSHIBA] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Init Failed! HW error or incompatible image? Try make "Flash Erase" first! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
12-11-2017, 18:30 | #12 (permalink) |
Member: 420821 Status: Offline Sonork: 100.1603493 Thanks Meter: 731 | yes i know toooooooooo http://forum.gsmhosting.com/vbb/f296...-dead-2146205/ http://forum.gsmhosting.com/vbb/f296...d-cm2-2159355/ http://forum.gsmhosting.com/vbb/f296...nlock-2099447/ u need more? no comments again............... http://forum.gsmhosting.com/vbb/f296...47/index4.html Last edited by gul_hassan528; 12-11-2017 at 18:37. |
12-11-2017, 22:47 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | phone can not be damaged by READ operation. no comments ......................... do not post fake links, "frp" and "read" are two different operations ! no comments again ......................... so charge battery and check phone hardware before say "phone dead after reading" |
12-12-2017, 05:11 | #14 (permalink) | |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Quote:
12-12-2017, 10:03 | #15 (permalink) | |
Member: 420821 Status: Offline Sonork: 100.1603493 Thanks Meter: 731 | Quote:
http://forum.gsmhosting.com/vbb/f296...-dead-2146205/ Last edited by gul_hassan528; 12-12-2017 at 10:08. | |
The Following User Says Thank You to gul_hassan528 For This Useful Post: |
