07-15-2017, 01:15 | #46 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Philippines
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 87 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 87 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 87 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : pike_xx08 Model Brand : SPRD Model Device: Bolt3 AndrVersion : 6.0 BaseBand CPU: SP7731CEA Project Ver : W419h_V1.0_170413 Model Ext : Bolt3 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W17.13.6_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2036 MiB Saved to : D:\Fone\Phone Firmware\Digicom\Digicom Bolt3_SP[SC773X]eMMC[And6.x]\SP7731CEA_Bolt3_6.0_W419h_V1.0_170413_Bolt3\ Done! Elapsed: 00:08:15 Reconnect Power/Cable! |
07-15-2017, 06:47 | #47 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Wht is the state of baseband,,, if u have firmware write flash with tick nvm update then try again imei repair | |
07-16-2017, 18:56 | #50 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | Infinity Team Please Add SPD 6820/8810 CPU Hi Infinity Team/Coder, Infinity Team Please Add SPD 6820/8810 CPU Many users also me face problem flash SPD CPU 6820/8810 with another Box and also research downloader and result handset Dead and when we restore backup or fresh readed PAC file we get error system file size error etc this reason we need must ths update And I hope all infinity users agree with me I hope you add soon as possible Best Regards Inifinity lovers since 2009 Sent from my iPhone using Tapatalk |
The Following 3 Users Say Thank You to sachu2002 For This Useful Post: |
07-17-2017, 13:55 | #51 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2134278 Status: Offline Thanks Meter: 19 | Serial No (S/N): Firmware version: 0135.02 === Process started: 17-Jul-17 18:54:20 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
07-18-2017, 17:24 | #52 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Molakalmuru (KARNATAKA) {INDIA
Member: 1891452 Status: Offline Thanks Meter: 29 | Team still software is hanging while flash file backup reading But flash file backup reading success in spd v1.22 So team plz solve this issue Flash file reading Problem giving in spd v1.23, v1.24, v1.25, v1.26 v1.27 |
07-19-2017, 18:17 | #55 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | hotwav cosmos c5 spd7731 flash error Quote:
07-20-2017, 07:33 | #56 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Itel A41 Frp done Code: Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : itel_A41 Model Brand : Itel Model Device: itel_A41 AndrVersion : 6.0 BaseBand CPU: ITEL_A41 CompileDate : 3/3/2017 1:54:57 PM Project Ver : A41-U268-6.0-IN-V008-20170303 Model Ext : itel A41 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:33 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012FCF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:25 |
07-21-2017, 08:31 | #57 (permalink) | |
Member: 1891452 Status: Offline Thanks Meter: 29 | Quote:
Team plz answer me how to solve this issue | |
07-22-2017, 19:42 | #59 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Need follow software instruction and NOT disconnect cable and power. Just follow SW instruction. | ||
