05-31-2019, 06:30 | #121 (permalink) |
No Life Poster Join Date: Apr 2017 Location: earth
Member: 2711085 Status: Offline Thanks Meter: 183 | mya15 8.1.0 frp ok 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! |
The Following 2 Users Say Thank You to FullFlash™ For This Useful Post: |
05-31-2019, 07:33 | #124 (permalink) |
Freak Poster Join Date: Aug 2011 Location: Uganda Age: 42
Member: 1640892 Status: Offline Sonork: 100.1651734 Thanks Meter: 25 | ITEL A16 DONE Card found : B5873186 , v0137 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1 Operation : Identify [ v2.00r1 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Done! Elapsed: 00:00:54 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Reset FRP 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Reset FRP 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:50 |
The Following 3 Users Say Thank You to baruga For This Useful Post: |
05-31-2019, 07:49 | #125 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Negeri Para Penipu
Member: 142211 Status: Offline Thanks Meter: 90 | Evercoss S45 Flashing Reading package ... Read package finished! Patch Level : NRD90M Display ID : EVERCOSS_S45_V10_7.0_08-11-2017 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-09-05 Build Time : 1510112642 Product Model : S45 Product Brand : EVERCOSS Product Name : EVERCOSS_S45 Product Device : EVERCOSS_S45 Product Board : sp9832a_2h11_volte Product Manfct : EVERCOSS Board Platform : sc8830 Product Info : EVERCOSS_S45 Operation : Flash Firmware [ v2.00r1 ] Setting : Update NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x29 PMTMng : Update PMT Ok! CODE : prodnv.bin ERASE : UBOOT UBOOT : u-boot-spl-16k-sign.bin CODE : l_modem.bin CODE : l_ldsp.bin CODE : l_gdsp.bin CODE : l_warm.bin CODE : pm_sys.bin CODE : wcnfdl.bin CODE : wcnmodem.bin CODE : boot-sign.img CODE : tos-sign.bin CODE : vmm-sign.bin CODE : recovery-sign.img FSIMG : system-sign.img FSIMG : userdata.img CODE : logo.bin CODE : fbootlogo.bin FSIMG : cache.img ERASE : L_RUNTIMENV1 ERASE : MISC FSIMG : persist.bin CODE : sysinfo.bin UBOOT : u-boot-sign.bin CODE : UDC_config.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:05:11 |
The Following User Says Thank You to not2link For This Useful Post: |
05-31-2019, 11:03 | #129 (permalink) | |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | Quote:
05-31-2019, 11:53 | #130 (permalink) | |
Freak Poster Join Date: Mar 2018 Location: Pakistan / Islamabad
Member: 2822559 Status: Offline Sonork: 100.1683406 Thanks Meter: 101 | Quote:
Look New Oppo A71 Is too Old Model But Unsupported Model Why Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : CB4D2CEB ID_BLOCK_L : 31C95A9077DF15F9E9668C07958C0251 ID_BLOCK_L : AB44E8118A5ADD5607C34C4E8F8809B2 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! whats is this sir QLM Last Update 2017-Dec-15 Please Update | |
05-31-2019, 11:57 | #131 (permalink) |
No Life Poster Join Date: Nov 2015 Location: DHAKA
Member: 2489690 Status: Offline Thanks Meter: 289 | Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:11 |
The Following 2 Users Say Thank You to chadzar For This Useful Post: |
05-31-2019, 13:16 | #133 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1050365 Status: Offline Thanks Meter: 210 | INTEX IP0518ND Operation : Identify [ v2.00r1 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : NRD90M Display ID : INTEX_IP0518ND_INFIE_33_V08_INDIAN Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-08-05 Build Time : 1536032989 Product Model : INTEX AQUA FulVU e5 Product Brand : INTEX Product Name : AQUA_FulVU_e5 Product Device : AQUA_FulVU_e5 Product Board : sp9850ka_1h10 Product Manfct : INTEX Board Platform : sp9850ka Product Info : INTEX_AQUA_FulVU_e5 UserData : STATE : DAMAGED Done! Elapsed: 00:01:08 Wipe Failed But FRP Reset OK. Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe failed! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:02:12 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Reset Settings [ Format FS ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe failed! Reconnect Power/Cable! Done! Elapsed: 00:00:29 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Reset FRP 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:29 |
The Following 2 Users Say Thank You to Bimal Shah For This Useful Post: |
06-01-2019, 11:11 | #134 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Algeria
Member: 2287326 Status: Offline Thanks Meter: 54 | People talk about CM2QLM I think it’s fine it’s just OPPO that hates us! This is a great update, hope it will be refined and get full featured soon, good luck! |
