Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #46 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,746 | Qmobile i6 metal one new reset frp done by cm2 ![]() Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1 Operation : Identify [ v2.00r1 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : MRA58K release-keys Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-11-05 Build Time : 1481797898 Board Platform : sc8830 Product Model : QMobile i6 Metal ONE Product Brand : QMobile Product Name : i6_Metal_ONE Product Device : i6_Metal_ONE_new Product Info : i6_Metal_ONE Product Board : i6_Metal_ONE Product Manfct : QMobile UserData : STATE : DAMAGED Done! Elapsed: 00:00:47 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:38 |
The Following 6 Users Say Thank You to A.G.Shahid For This Useful Post: |
![]() | #48 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2015 Location: Dhaka Bangladesh
Member: 2333595 Status: Offline Sonork: wwwsonork.com Thanks Meter: 120 | symphony V98 SC7731E 8.0.1 RESET FRP DONE CM2 SPD 2.00r1 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Reset FRP 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:26 ![]() ![]() |
The Following 6 Users Say Thank You to welcome1234 For This Useful Post: |
![]() | #50 (permalink) |
Junior Member ![]() Join Date: Jun 2014 Location: Idiroko IPLG Ogun St Nigeria
Member: 2208114 Status: Offline Thanks Meter: 5 | I don't have any SPD device with privacy protection password issue now but incase |
The Following User Says Thank You to 5diamond For This Useful Post: |
![]() | #51 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Thanks Meter: 1,118 | True Smarrt 4G Max 4.0" Flashing done! Code: Operation : Flash Firmware [ v2.00r1 ] Setting : Update NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x26 PMTMng : Update PMT Ok! CODE : prodnv.img ERASE : UBOOT UBOOT : u-boot-spl-16k-sign.bin CODE : SC9600_sharkls_3593_CUST_Simlock_Caron-sign.dat CODE : LTE_DSP-sign.bin CODE : SHARKL_DM_DSP-sign.bin CODE : SC9600_sharkl_wphy_5mod_volte_zc-sign.bin CODE : PM_sharkls_arm7-sign.bin CODE : fdl1_wcn.bin CODE : EXEC_KERNEL_IMAGE0.bin CODE : boot-sign.img CODE : recovery-sign.img FSIMG : system.img FSIMG : userdata.img CODE : 480x800_logo.bmp CODE : 480x800_logo.bmp(1) FSIMG : cache.img ERASE : L_RUNTIMENV1 ERASE : MISC FSIMG : persist.img CODE : sysinfo.img UBOOT : u-boot-sign.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:07:02 |
The Following 3 Users Say Thank You to ddilshod93 For This Useful Post: |
![]() | #52 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: iran tehran 021
Member: 2643931 Status: Offline Sonork: ****** Thanks Meter: 220 | Special thanks to Mr. JD and Infinity Team I am as an Iranian I'm proud of you I really do not know how it is Thank you and your team Only the imei part and the password removal(Without deleting information)do not work properly |
The Following 2 Users Say Thank You to afghanistanmob For This Useful Post: |
![]() | #60 (permalink) |
Junior Member Join Date: Dec 2017 Location: Kampala
Member: 2793249 Status: Offline Thanks Meter: 7 | Infinity team always comes up with a great update😉😉 all the time i refused to buy those frp dongles because i knew infinity works so hard Words First ever |
The Following 2 Users Say Thank You to mack.gady For This Useful Post: |
