Old 06-12-2019, 19:44   #46 (permalink)
IQA_SHAHEEN's Avatar
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
please mr jaydi check my problem
http://forum.gsmhosting.com/vbb/f296/spd-9830a-2525482/
regards
iqa_shaheen
Old 06-13-2019, 09:35   #47 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 755
regards
iqa_shaheen
Hello,
Why dont u try with SPD2,, if any error plz post logs,,
Old 06-13-2019, 09:43   #48 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 210
Originally Posted by alma3dl View Post
dear supporter this update support huawei y336 u02 spd c468b106 unlock network??
i flashed it and got simlock or network locked
please help there are some mobile with this information and with this problem
how do you flash this huawei i tried many ways but not successful y360-u02
Old 06-13-2019, 21:56   #49 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
SP2 Module (Issue Report)
Hi I Just Try To Select Manual Loader In GUI
(When I Select .Pac Its Working) But When U Try To Select FDL Loaders In FLD2 U Can't Select File Even After Browse N Select Not Show In GUI I Try To Boot (Identify) It Try To Take Boot From Internal Loader(From Selected Tab)
Kindly Check If You Found Something To Fix ..Fix In Next Release
TinyUpload.com - best file hosting solution, with no limits, totaly free
Loader Link Attached....
I Am Having Few Queries Too...
As I Check SPD Module N SP2 Module Both Use .FG Loader File Type Can I Use SP2 Loader In SPD Module But I Think It Only Show File Save In Config Will Not Work If I Paste There File Or It Will Work...?
If Not Then Can U Make 1 Small Program Which Add SP2 Module .FG Loader To Old Module (In Custom Boot Option Model Wise List Show After Add)
Like Open Loader Add Tool GUI Select Loader Input Brand Name N Model It Will Add Loader To Database N Copy File To Folder....
If Possible Kindly Add .XML File Type Support For Flashing, Loader Select Etc.
The Following User Says Thank You to hitech care For This Useful Post:
Old 06-13-2019, 22:00   #50 (permalink)
Member: 1834832
Thanks Meter: 1,450
User Report (Read Info Indluding Secutiry OS 8.1.0):);)
Operation : Identify [ v2.00r2 ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Device info :
Patch Level    : OPM2.171019.012
Display ID     : A23-SU335-8.1-IN-V019-20190313
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2019-03-05
Build Time     : 1552421253
Product Model  : itel A23
Product Brand  : Itel
Product Name   : SU335
Product Device : itel-A23
Product Manfct : ITEL MOBILE LIMITED
Product Info   : itel A23
Product Board  : sp9832e_1h10_32b
Board Platform : sp9832e
SecInfo :
IMEI[1] : 911639XXXXXXXX
IMEI[2] : 9116392XXXXXXX
IMEI[3] : 86740002XXXXXX
WIFIMAC : FFFFFFFFFFFF
BT_MAC  : FFFFFFFFFFFF
UserData : STATE : ENCRYPTION
Done!
Elapsed: 00:00:59
Old 06-14-2019, 12:36   #51 (permalink)
Member: 2649950
Thanks Meter: 33
InfinityBox CM2SPD not run after install InfinityBox CM2SP2. Tried to uninstall/reinstall, but it dosent work. How to fix?
Old 06-14-2019, 13:34   #52 (permalink)
Member: 974244
Thanks Meter: 50
Card found : E3B1B8F3 , v0137
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1
Operation : Identify [ v2.00r1 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Sedning Init Boot ...
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Sedning Flash Boot ...
Boot sent!
Kick FLASH FDL ...
Boot Done!
Done!
Elapsed: 00:00:47
Operation : Format FS / Reset Settings [ v2.00r1 ]
Mode : Reset FRP
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Reconnect Power/Cable!
Done!
Elapsed: 00:00:47
Mode : Reset Settings [ Format FS ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Done!
Elapsed: 00:00:44
The Following 2 Users Say Thank You to philantropist For This Useful Post:
Old 06-16-2019, 06:37   #53 (permalink)
Member: 2822775
how to on imei option in sp2 any one can help me???
Old 06-16-2019, 12:12   #54 (permalink)
Member: 2812901
Thanks Meter: 494
Next update !!!!!!!!!!!!!!!
Old 06-16-2019, 16:01   #55 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,815
firmware read not working
Old 06-17-2019, 12:01   #56 (permalink)
Member: 2514459
how to read FW with this software please ?????????
Old 06-18-2019, 11:26   #57 (permalink)
Member: 1087145
Thanks Meter: 164
True SMART 4G GEN C 5.5/OSAndroid 7/CPUSpreadtrum SC9850k/ HDD16 GB/RAM2 GB
Card found : E1101AD2 , v0137
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r2
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_2GB_RS
Boot sent!
Kick FDL ...
ERROR : FDL NOT started!
Error : Fail to boot FDL!
Unsupported device with selected fdl! Change settings!
Old 06-21-2019, 06:23   #58 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 837
Very Good Update .
Plz Add Write FW in Readed File in CM2 SPD Formate .
Thanks.
Old 06-25-2019, 11:08   #59 (permalink)
Member: 2856614
Sonork: 100.650600
Thanks Meter: 252
cm2 great. please 2.0 read option add
Old 06-26-2019, 15:47   #60 (permalink)
Member: 2263412
Thanks Meter: 90
plz plz Team How to unlock this???
or enable unlock button...
Card found : 1994436A , v0137
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Display ID : Movitel_M8416_01SIM_V02_20190306_1011
Ver. CodeName : REL
Sec. Patch : 2019-02-05
Build Time : 1551839680
Product Model : M8416
Product Brand : Movitel
Product Name : M8416
Product Device : M8416
Product Board : sp7731e_fs286
Product Manfct : Fortune Ship
Product Info : sp7731e_fs286
Board Platform : sp7731e
SecInfo :
IMEI[1] : 869227040052085
IMEI[2] : 867400020316620
IMEI[3] : 867400020316638
UserData : STATE : DAMAGED
Done!
Elapsed: 00:01:53
Page generated in 0.19310 seconds with 9 queries
