Old 01-16-2020, 16:46   #106 (permalink)
Member: 1858685
Thanks Meter: 6
please explain more about nvitems
i have a locked spd9820 alcatel 3088x
i can't get the combo buttons to get in diag mode but i can make setprop sys.usb.config diag,adb (rooted)
how do i get a backup nv as the tool doesn't work when phone is live
and where do i uploade the nv locked and unlocked version
Old 01-16-2020, 19:51   #107 (permalink)
Member: 148515
Thanks Meter: 19,534
Originally Posted by GODISTHEBEST View Post
and this thread is for spd only or also for spd2 ?
pls kindly help!
also in spd v 1.27 there is no sc9820e! only 9820!!! so were is the update for xiaomi qin 1 that you wrote !
also in the 2.04 version there is indid the 9820e but the sofrware can not recognize the phone!
i have install the adb and fasboot driver i have open usb debuging ! i dont know which button to push down scroll or up ! ( it is responding in downscroll and i can see (spd u2 drivers ) but it really quick disappear from the device manager so .. i dont know what to do ?
BTW one that is buying support it means that he can ask here questions ?
and what is the difrance between infinity forum ( that i still did not register ) o gsm forum in infinity section ?
yes sure you can ask questions in any forum you like and if you see 9820e in cm2sp2 you can use it.
Old 01-16-2020, 19:52   #108 (permalink)
Member: 148515
sorry I did not understand about combo buttons. What do you mean ?
Old 01-17-2020, 01:18   #109 (permalink)
Member: 2496790
Thanks Meter: 11
do you have remote control support (even in aditional payments ) cuase i can not get over the problem i face!!! the software does not recognize the phone ! at least if one of the programers of the software remember which button to use in xiaomi-in1 pls share and guide us thank you
Old 01-17-2020, 02:59   #110 (permalink)
Member: 130995
Thanks Meter: 35,227
there is no any kind of remote support (even in aditional payments ).
you can describe the problem in details here.
Old 01-17-2020, 03:31   #111 (permalink)
Member: 2496790
Thanks Meter: 11
in the CM2 SPD2 IN THE RIGHT MODEL SELECTION IN SC6500 here is the log :
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6530 , FDLStat : 00C0
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
======= Flashing MCU
Mapping file ...
Mapping done
Processing file : SPD6530_SPD6500_00800000_MOCOR_W13.09_FP_R5.0.2_De bug_sc6500_samsung_EiderRefresh_B110E_DS_MEA_06192 015145339_english__samsun -b110e.bin
Init ok, send data
Flashing Done!
Info : In some cases after flash required make "Format Fs / Reset Phone"
Done!
*************** more log
Phone found! [ 210 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Error while prepare!
Format error, something went wrong
i have read the firmware as a bin file and write it back on a working phone but after flashing ( i saw that maybe need factory reset so i have done it and the log is up here )
and the phone does not turning on at all
if i will flash with other box full firmware ( cuase i dont have pac file) it will return to work
what should i do?
Old 01-17-2020, 04:02   #112 (permalink)
Member: 2496790
Thanks Meter: 11
another problem xiaomi does not recognize
hi sorry about too mant requests for help but it is needed !!
so i am trying in spd2 to read firmware and it does not work at all every fanction with the new qin 1s does not work it says "device conected " but it can not initial protocol
so i tryed to replace new cable with another new cable the it was the same problem !
note when i trying to conect the phone with vol up or both up & down ) in the device manager i can see the U2S SPD DIAG but it dissapear after 3 second so i dont know what is the reson for that . in another model B110 sc 6500fs it is the same scenario but the software can do oporation with that even long ones like reading firmware !
pls advice the logs are : "device conected " can not ini protocot " but you know what i will do it againg to show you
we need to apriciate the time and efirt you doing to answer us so here :
Card found : A03D2A7D , v0139
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04
Load IDBase v1119 Ok!
Operation : Identify [ v2.04 ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
ERROR : Protocol HandShake failed!
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
Reconnect Power/Cable!
BootMode : FLASH
Wait for device ...
Device Connected!
i tryed another cable the same think
pls guide as what to do ?
Old 01-17-2020, 04:20   #113 (permalink)
Member: 2496790
Thanks Meter: 11
my mistake
BootMode : FLASH
Wait for device ...
Device Connected!
BootMode : FLASH
Wait for device ...
Device Connected!
i could not edit or delete the post it this problem solved!!
Old 01-17-2020, 04:20   #114 (permalink)
Member: 2496790
Thanks Meter: 11
my mistake
BootMode : FLASH
Wait for device ...
Device Connected!
BootMode : FLASH
Wait for device ...
Device Connected!
Old 01-17-2020, 04:22   #115 (permalink)
Member: 2496790
Thanks Meter: 11
my mistake
did not read enough the instruction
Old 01-17-2020, 04:37   #116 (permalink)
Member: 2496790
Thanks Meter: 11
solved
BootMode : FLASH
Wait for device ...
Device Connected!
BootMode : FLASH
Wait for device ...
Device Connected!
problem solved now i can even read nv data and identify the device but i can read the firmware with and without L. SHIFT
logs:
BootMode : FLASH
Wait for device ...
Device Connected!
BootMode : FLASH
Wait for device ...
Device Connected!
BootMode : FLASH
Wait for device ...
Device Connected!
BootMode : FLASH
Wait for device ...
Device Connected!
BootMode : SVC
2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- )
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Device not found!
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
SOC GEN : UniSoc ( E-family and Modern )
BuildInfo : sp9820e_2h10_native-user 4.4.4 KTU84P 91 dev-keys
ModemInfo :
Platform Version: MOCORTM_17B_Release_W18.27.4_P1_Debug
Project Version: sharkle_Feature_Phone
BASE Version: FM_BASE_17B_Release_W18.27.4_P1
HW Version: sc9820e_modem
CMP_Time : 07-12-2018 11:19:26
Done!
Elapsed: 00:00:31
Operation : Read FW [ v2.04 ]
Extra : Ignore CriticalPart Verify : Enabled
Wait for device ...
Device Connected!
Wait for device ...
Device Connected!
Wait for device ...
Device Connected!
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
BuildInfo : sp9820e_1h10_native-user 4.4.4 KTU84P 54 dev-keys
MemoryInfo : EMMC : 4 MB ; DRAM : 512 MB
ModemInfo :
Platform Version: MOCORTM_17B_Release_W18.47.2_Debug
BASE Version: FM_BASE_17B_Release_W18.47.2
SecInfo :
IMEI[1] : 351953050069949
IMEI[2] : 351953050069949
WIFIMAC : 10DF8B0D52FF
BT_MAC : 4045DA00A2F9
SEC_ID : ABCEBDA7CACFA0CECCA0CCCAA0CCCCF5F5
Done!
Elapsed: 00:00:26
Wait for device ...
Device Connected!
Wait for device ...
Device Connected!
Operation : Read NVM [ v2.04 ]
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
SecInfo : ABCEBDBCC6CCA0C9A0CCCBA0CECFF5F5
MODEM TAG : MOCORTM_17B_Release_W18.27.4_P1_Debug_FM_BASE_17B_ Release_W18.27.4_P1_sc9820e_modem_sharkle_Feature_ Phone
SecInfo :
IMEI[1] : 864982041239603
IMEI[2] : 864982041239603
WIFIMAC : 10DF8B06B333
BT_MAC : 10DF8B8C55FE
NVMng : Reading NV. Please, wait ...
NVMng : Backup Ok , 0x000C62B4
NVMng : Saved as : 864982041239603_ABCEBDBCC6CCA0C9A0CCCBA0CECFF5F5_d iag.nvm
NVMng : Saved to : C:\InfinityBox\CM2SP2\Backup\864982041239603\
Done!
Elapsed: 00:00:44
Wait for device ...
Device Connected!
The Following User Says Thank You to GODISTHEBEST For This Useful Post:
Old 01-17-2020, 08:42   #117 (permalink)
Member: 2075865
Thanks Meter: 99
Card found : E6FA2D2E , v0139
Open : Mobicel_V4.pac
VER : BP_R1.0.0
LEN : 0x5ABC5C57
CPU : y400
VER : Mobicel_V4
Reading package ...
Read package finished!
Patch Level : OPM2.171019.012
Display ID : OPM2.171019.012 release-keys
Ver. Incmt : 27
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-04-05
Build Time : 1526976167
Product Info : y400
Product Model : V4
Product Brand : Mobicel
Product Name : V4
Product Device : V4
Product Manfct : Mobicel
Product Board : y400
Board Platform : sp7731e
Operation : Flash Firmware [ v2.04 ]
Setting : Update NVRAM : True
Setting : Force NVRAM : True
Setting : Update PMT : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : PAC : Mobicel_V4.pac
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
PMTMng : Load PMT
PMTMng : 0x20
PMTMng : Update PMT Ok!
NVRM : pike2_pubcp_nvitem.bin
NVMng : Load 0x17
NVMng : Init SRC
NVMng : SecurityInfo
IMEI[1] : 357493091541462
IMEI[2] : 867400020316620
IMEI[3] : 867400020316638
WIFIMAC : FFFFFFFFFFFF
BT_MAC : FFFFFFFFFFFF
NVMng : Backup Ok , 0x00066B20
NVMng : Init DST
NVMng : Rx11 : Wx10
NVMng : NVM block updated!
CODE : prodnv.img
ERASE : UBOOT
ERASE : UBOOT_LOG
UBOOT : u-boot-spl-16k-sign.bin
CODE : vbmeta-sign.img
CODE : SC9600_pike2_pubcp_modem.dat
CODE : pike2_pubcp_deltanv.bin
CODE : PIKE2_DM_DSP.bin
Failed to update block!
ERROR : 0000008E:00000000FF7F0000
GEN : UNKNOWN RESPONSE!
Error : Flashing failed!
Check previous message for more info!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
PMTMng : Load PMT
PMTMng : 0x20
NVMng : Load 0x17
NVMng : Init SRC
NVMng : Init DST
NVMng : Rx11 : Wx10
Failed to update NV!
INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
ProtoEx : Fail to enable Forced FlashWrite!
Boot Done!
PMTMng : Load PMT
PMTMng : 0x20
NVMng : Load 0x17
NVMng : Init SRC
NVMng : Trying use recover mode
NVMng : Init DST
NVMng : NV has been destroyed! Forced Update enabled! Repair security after!
CODE : prodnv.img
ERASE : UBOOT
ERASE : UBOOT_LOG
ERROR : 00007E00:007E0080FF7F0000
fix bugs on flashing, keep on failing to complete
Old 01-17-2020, 09:35   #118 (permalink)
Member: 1740980
Sonork: st72
Thanks Meter: 14
please help team.
thanks
Old 01-17-2020, 09:47   #119 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
Infinity best team if possible add spd unlock . . sc9832e cpu
Old 01-17-2020, 10:28   #120 (permalink)
johnmadzeka1's Avatar
Member: 2377686
Sonork: 100.1668474
Thanks Meter: 315
Exclamation ZTE Blade L130 aka Kicka 4 VE Network Locked
Here is Logs & NVM dump:
https://mega.nz/#!kN4mgKoT!voT1hNyxv...qJMlrth58peQuY
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
BuildInfo : VDC_ZA_P731K30V1.0.0B06
MemoryInfo : EMMC :  16 GB  ;  DRAM : 512 MB
ModemInfo :
Platform Version: MOCORTM_17C_W18.41.3_P13_Debug
Project Version:   pike2_pub
BASE  Version:    FM_BASE_17C_W18.41.3_P13
HW Version:        sc7731e_modem
CMP_Time : 03-04-2019 14:15:17
Done!
Elapsed: 00:00:41
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
SecInfo   : ABCDB9BCC7CAA0CDCEA0CCCAA0C9F5F5
MODEM TAG : MOCORTM_17C_W18.41.3_P13_Debug_FM_BASE_17C_W18.41.3_P13_sc7731e_modem_pike2_pub
SecInfo :
IMEI[1] : 8614860xxxxxxxxx
IMEI[2] : 8674000xxxxxxxxx
WIFIMAC : 6014669E17F6
BT_MAC  : 4859A477EBA7
SIMLOCK  : SignedType
NVMng  : Backup Ok , 0x00066C18
NVMng  : Saved as : 861486040xxxxxx_ABCDB9BCC7CAA0CDCEA0CCCAA0C9F5F5_diag.nvm
NVMng  : Saved to : C:\InfinityBox\CM2SP2\Backup\86148604xxxxxx\
Done!
Elapsed: 00:00:56
I have mobile phone in hand
The Following User Says Thank You to johnmadzeka1 For This Useful Post:
Page generated in 0.35308 seconds with 8 queries
