01-16-2020, 16:46 | #106 (permalink) |
Insane Poster Join Date: Dec 2012 Location: uk
Member: 1858685 Status: Offline Thanks Meter: 6 | i have a locked spd9820 alcatel 3088x i can't get the combo buttons to get in diag mode but i can make setprop sys.usb.config diag,adb (rooted) how do i get a backup nv as the tool doesn't work when phone is live and where do i uploade the nv locked and unlocked version |
01-16-2020, 19:51 | #107 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
01-16-2020, 19:52 | #108 (permalink) | |
01-17-2020, 01:18 | #109 (permalink) |
Freak Poster Join Date: Dec 2015 Age: 46
Member: 2496790 Status: Offline Thanks Meter: 11 | do you have remote control support (even in aditional payments ) cuase i can not get over the problem i face!!! the software does not recognize the phone ! at least if one of the programers of the software remember which button to use in xiaomi-in1 pls share and guide us thank you |
01-17-2020, 02:59 | #110 (permalink) | |
you can describe the problem in details here. | |
01-17-2020, 03:31 | #111 (permalink) |
Member: 2496790 Status: Offline Thanks Meter: 11 | in the CM2 SPD2 IN THE RIGHT MODEL SELECTION IN SC6500 here is the log : ***************** ***************** Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 ======= Flashing MCU Mapping file ... Mapping done Processing file : SPD6530_SPD6500_00800000_MOCOR_W13.09_FP_R5.0.2_De bug_sc6500_samsung_EiderRefresh_B110E_DS_MEA_06192 015145339_english__samsun -b110e.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! *************** *************** *************** more log Phone found! [ 210 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Error while prepare! Format error, something went wrong ****************** ****************** i have read the firmware as a bin file and write it back on a working phone but after flashing ( i saw that maybe need factory reset so i have done it and the log is up here ) and the phone does not turning on at all if i will flash with other box full firmware ( cuase i dont have pac file) it will return to work what should i do? |
01-17-2020, 04:02 | #112 (permalink) |
Member: 2496790 Status: Offline Thanks Meter: 11 | another problem xiaomi does not recognize hi sorry about too mant requests for help but it is needed !! so i am trying in spd2 to read firmware and it does not work at all every fanction with the new qin 1s does not work it says "device conected " but it can not initial protocol so i tryed to replace new cable with another new cable the it was the same problem ! note when i trying to conect the phone with vol up or both up & down ) in the device manager i can see the U2S SPD DIAG but it dissapear after 3 second so i dont know what is the reson for that . in another model B110 sc 6500fs it is the same scenario but the software can do oporation with that even long ones like reading firmware ! pls advice the logs are : "device conected " can not ini protocot " but you know what i will do it againg to show you we need to apriciate the time and efirt you doing to answer us so here : **************** **************** Card found : A03D2A7D , v0139 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04 Load IDBase v1119 Ok! Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! *************** *************** i tryed another cable the same think pls guide as what to do ? |
01-17-2020, 04:20 | #113 (permalink) | |
Member: 2496790 Status: Offline Thanks Meter: 11 | my mistake Quote:
01-17-2020, 04:20 | #114 (permalink) | |
01-17-2020, 04:37 | #116 (permalink) | |
Member: 2496790 Status: Offline Thanks Meter: 11 | solved Quote:
logs: ******* Card found : A03D2A7D , v0139 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04 Load IDBase v1119 Ok! Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.04 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.04 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : sp9820e_2h10_native-user 4.4.4 KTU84P 91 dev-keys ModemInfo : Platform Version: MOCORTM_17B_Release_W18.27.4_P1_Debug Project Version: sharkle_Feature_Phone BASE Version: FM_BASE_17B_Release_W18.27.4_P1 HW Version: sc9820e_modem CMP_Time : 07-12-2018 11:19:26 Done! Elapsed: 00:00:31 Operation : Read FW [ v2.04 ] Extra : Ignore CriticalPart Verify : Enabled 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.04 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : sp9820e_1h10_native-user 4.4.4 KTU84P 54 dev-keys MemoryInfo : EMMC : 4 MB ; DRAM : 512 MB ModemInfo : Platform Version: MOCORTM_17B_Release_W18.47.2_Debug Project Version: sharkle_Feature_Phone BASE Version: FM_BASE_17B_Release_W18.47.2 HW Version: sc9820e_modem SecInfo : IMEI[1] : 351953050069949 IMEI[2] : 351953050069949 WIFIMAC : 10DF8B0D52FF BT_MAC : 4045DA00A2F9 SEC_ID : ABCEBDA7CACFA0CECCA0CCCAA0CCCCF5F5 Done! Elapsed: 00:00:26 Operation : Read FW [ v2.04 ] Extra : Ignore CriticalPart Verify : Enabled 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read NVM [ v2.04 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! BuildInfo : sp9820e_2h10_native-user 4.4.4 KTU84P 91 dev-keys SecInfo : ABCEBDBCC6CCA0C9A0CCCBA0CECFF5F5 Platform Version: MOCORTM_17B_Release_W18.27.4_P1_Debug Project Version: sharkle_Feature_Phone BASE Version: FM_BASE_17B_Release_W18.27.4_P1 HW Version: sc9820e_modem CMP_Time : 07-12-2018 11:19:26 MODEM TAG : MOCORTM_17B_Release_W18.27.4_P1_Debug_FM_BASE_17B_ Release_W18.27.4_P1_sc9820e_modem_sharkle_Feature_ Phone SecInfo : IMEI[1] : 864982041239603 IMEI[2] : 864982041239603 WIFIMAC : 10DF8B06B333 BT_MAC : 10DF8B8C55FE NVMng : Reading NV. Please, wait ... NVMng : Backup Ok , 0x000C62B4 NVMng : Saved as : 864982041239603_ABCEBDBCC6CCA0C9A0CCCBA0CECFF5F5_d iag.nvm NVMng : Saved to : C:\InfinityBox\CM2SP2\Backup\864982041239603\ Reconnect Power/Cable! Done! Elapsed: 00:00:44 Operation : Read FW [ v2.04 ] Extra : Ignore CriticalPart Verify : Enabled 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! ******** | |
The Following User Says Thank You to GODISTHEBEST For This Useful Post: |
01-17-2020, 08:42 | #117 (permalink) |
Freak Poster Join Date: Nov 2013 Location: zimbabwe
Member: 2075865 Status: Offline Thanks Meter: 99 | Card found : E6FA2D2E , v0139 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04 Load IDBase v1119 Ok! Open : Mobicel_V4.pac VER : BP_R1.0.0 LEN : 0x5ABC5C57 CPU : y400 VER : Mobicel_V4 Reading package ... Read package finished! Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. Incmt : 27 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-04-05 Build Time : 1526976167 Product Info : y400 Product Model : V4 Product Brand : Mobicel Product Name : V4 Product Device : V4 Product Manfct : Mobicel Product Board : y400 Board Platform : sp7731e Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : True Setting : Force NVRAM : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : Mobicel_V4.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! NVRM : pike2_pubcp_nvitem.bin NVMng : Load 0x17 NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 357493091541462 IMEI[2] : 867400020316620 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF NVMng : Backup Ok , 0x00066B20 NVMng : Init DST NVMng : Rx11 : Wx10 NVMng : NVM block updated! CODE : prodnv.img ERASE : UBOOT ERASE : UBOOT_LOG UBOOT : u-boot-spl-16k-sign.bin CODE : vbmeta-sign.img CODE : SC9600_pike2_pubcp_modem.dat CODE : pike2_pubcp_deltanv.bin CODE : PIKE2_DM_DSP.bin Failed to update block! ERROR : 0000008E:00000000FF7F0000 GEN : UNKNOWN RESPONSE! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : True Setting : Force NVRAM : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : Mobicel_V4.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! NVRM : pike2_pubcp_nvitem.bin NVMng : Load 0x17 NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 357493091541462 IMEI[2] : 867400020316620 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF NVMng : Backup Ok , 0x00066B20 NVMng : Init DST NVMng : Rx11 : Wx10 Failed to update NV! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : True Setting : Force NVRAM : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : Mobicel_V4.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : Fail to enable Forced FlashWrite! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! NVRM : pike2_pubcp_nvitem.bin NVMng : Load 0x17 NVMng : Init SRC NVMng : Trying use recover mode NVMng : Trying use recover mode NVMng : Init DST NVMng : NV has been destroyed! Forced Update enabled! Repair security after! NVMng : NVM block updated! CODE : prodnv.img ERASE : UBOOT ERASE : UBOOT_LOG UBOOT : u-boot-spl-16k-sign.bin CODE : vbmeta-sign.img CODE : SC9600_pike2_pubcp_modem.dat Failed to update block! ERROR : 00007E00:007E0080FF7F0000 GEN : UNKNOWN RESPONSE! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! fix bugs on flashing, keep on failing to complete |
01-17-2020, 10:28 | #120 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | ZTE Blade L130 aka Kicka 4 VE Network Locked Here is Logs & NVM dump: https://mega.nz/#!kN4mgKoT!voT1hNyxv...qJMlrth58peQuY Code: Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04 Load IDBase v1119 Ok! Operation : Identify [ v2.04 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : VDC_ZA_P731K30V1.0.0B06 MemoryInfo : EMMC : 16 GB ; DRAM : 512 MB ModemInfo : Platform Version: MOCORTM_17C_W18.41.3_P13_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.41.3_P13 HW Version: sc7731e_modem CMP_Time : 03-04-2019 14:15:17 Done! Elapsed: 00:00:41 Operation : Read NVM [ v2.04 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! BuildInfo : VDC_ZA_P731K30V1.0.0B06 SecInfo : ABCDB9BCC7CAA0CDCEA0CCCAA0C9F5F5 Platform Version: MOCORTM_17C_W18.41.3_P13_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.41.3_P13 HW Version: sc7731e_modem CMP_Time : 03-04-2019 14:15:17 MODEM TAG : MOCORTM_17C_W18.41.3_P13_Debug_FM_BASE_17C_W18.41.3_P13_sc7731e_modem_pike2_pub SecInfo : IMEI[1] : 8614860xxxxxxxxx IMEI[2] : 8674000xxxxxxxxx WIFIMAC : 6014669E17F6 BT_MAC : 4859A477EBA7 SIMLOCK : SignedType NVMng : Reading NV. Please, wait ... NVMng : Backup Ok , 0x00066C18 NVMng : Saved as : 861486040xxxxxx_ABCDB9BCC7CAA0CDCEA0CCCAA0C9F5F5_diag.nvm NVMng : Saved to : C:\InfinityBox\CM2SP2\Backup\86148604xxxxxx\ Reconnect Power/Cable! Done! Elapsed: 00:00:56 I have mobile phone in hand |
The Following User Says Thank You to johnmadzeka1 For This Useful Post: |
