Old 06-04-2020, 21:41   #151 (permalink)
Member: 1043909
Thanks Meter: 54,523
Originally Posted by ranakamran View Post
hey sir how can i unlock the sim lock with android version 8.1.0 sprd with cm2 spd please help me
hey sir please post here software operation log tex and your phone details
Old 06-07-2020, 18:13   #152 (permalink)
Member: 2557274
Thanks Meter: 15
Add plz
Hi team, can add support for ZTE v10 Vita, Unlock , only can with furious
Old 06-07-2020, 20:56   #153 (permalink)
Member: 148515
Thanks Meter: 16,784
Hi friend, copy/paste here Infinity software operation log text
Old 06-13-2020, 12:22   #154 (permalink)
Member: 2075865
Thanks Meter: 15
privacy lock option shows access violation error each time i want to reed code on this version, but when i use older version 2.02 it works fine. The phone was itel A33, can you check and fix the bug in next update. Also we need SP lock activated on new spd android phones like Aspire 5, zte l130 and nokia TA-1165 with level 4 security, no tool is able to unlock these type of phones at the moment. Its becoming a challenge these days we have heaps and heaps of these SP locked phones without solutions. ... through online credits, but Infinity is my best tool i believe in you, i will rather wait for your permanent solution.
Old 06-20-2020, 17:57   #155 (permalink)
Member: 1954072
Sonork: lekaz
Thanks Meter: 3
Infinity team be serious on SPD atleast you could have enabled a simple sim unlock ... sim unlock via diagnostic mode. Spd module is the only unique thing you have on reading fw than others boxes
Old 06-21-2020, 00:55   #156 (permalink)
Member: 1043909
@lekaz
friend be serious, your advertizing methods just make us smile. And you live in free world, you are free to buy any tool that you want.
good luck !
Old 06-21-2020, 00:56   #157 (permalink)
Member: 1043909
pls always post software operation logs, it's the only way we can see the problem (if any).
Old 06-21-2020, 09:36   #158 (permalink)
Member: 1954072
Sonork: lekaz
Thanks Meter: 3
Originally Posted by YellowBoss View Post
@lekaz
good luck !
No friend am not advertising am a heavy user of cm2 as a customer if you could have simlock tab enabled even though diag mode.. there was no need for me to be using the mentioned tool, please take it into consideration
Old 06-21-2020, 09:42   #159 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 17,233
Every our module have unique features. So, when we done other things, sure, they will be enabled too.
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-21-2020, 22:20   #160 (permalink)
Member: 1954072
Sonork: lekaz
Thanks Meter: 3
Cool
Waiting patiently as years are going
Old 06-21-2020, 22:38   #161 (permalink)
Member: 2902140
Thanks Meter: 2
I have the same problem
Read Privacy Itel A33
[IMG][/IMG]
Old 06-21-2020, 22:55   #162 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 2,338
[IMG][/IMG]
Use v2.04, team will fix bug in next update.
Old 06-23-2020, 16:15   #163 (permalink)
Member: 1636627
Thanks Meter: 22
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05
Load IDBase v42913 Ok!
Open : SPD_PROG.xml
Reading package ...
Read package finished!
Created by Infinity-Box (c) 2020
Chinese Miracle II : Spreadtrum / UniSoc Service Module
Device Info file : _Android_info.txt
Patch Level : MRA58K
Display ID : Series_A_A10_Android_8.1_V01_2019-10-09
Ver. Incmt : root-103233
Ver. CodeName : REL
Ver. Release : 8.1
Sec. Patch : 2016-07-01
Build Time : 1570610972
Product Brand : Series A
Product Name : A10
Product Device : A10
Product Board : sp7731gea_hdr
Product Manfct : Series A
Board Platform : sc8830
Product Info : A10
Product Model : A10
Operation : Flash Firmware [ v2.05 ]
Setting : Update NVRAM : False
Setting : Force NVRAM : False
Setting : SlowSparse Fix : True
Setting : Update PMT : True
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : INFINITY FW PACKAGE
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
PMTMng : Load PMT
PMTMng : 0x20
PMTMng : Update failed!
ERROR : 00000084:84000000FF7B7E00
SYS : OPERATION FAILED!
Error : Flashing failed!
Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process
Reconnect Power/Cable!
hello sir i have one invens phone s7731G and i readed firmware from working phone but whn i write same readed firmware i get error. can u please tell me what is the issue
The Following User Says Thank You to babu786 For This Useful Post:
Old 07-02-2020, 09:21   #164 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 142
VGOTel Smart 5 SC9863A Android 9 read firmware done.
But very slow speed:
Operation : Read FW [ v2.05 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 2000000
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Patch Level    : PPR1.180610.011
Display ID     : Smart_5_V07_20190520_1114
Display ID     : Smart_5_V10_20190918_1603
Ver. Incmt     : 20190520
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-09-05
Build Time     : 1568789583
Product Model  : Smart 5
Product Brand  : VGOTEL
Product Name   : Smart_5
Product Device : Smart_5
Product Manfct : VGOTEL
Product Info   : Smart_5
Product Board  : sp9863a_1h10
Board Platform : sp9863a
AndroidVer : 9
VlnrLevel : 0x02
SP9863A__VGOTEL__Smart_5__9__Smart_5_V10_20190918_1603__PPR1.180610.011__Smart_5
Read : u-boot.bin
Read : sml.bin
Read : tos.bin
Read : vbmeta.img
Read : dtb.img
Read : dtbo.img
Read : ldsp_l.bin
Read : gdsp_l.bin
Read : modem_l.bin
Read : nvitem_l.bin
Read : modem_wcn.img
Read : gnssmodem.bin
Read : gnssbdmodem.bin
Read : pm_sys.bin
Read : boot.img
Read : recovery.img
Make : persist.img
Read : boot_logo.bmp
Read : fastboot_logo.bmp
Read : system.img
Read : vendor.img
Read : otp_product.img
ExtSparse : Compression ratio : 1%
Make : userdata.img
Make : cache.img
Read : prodnv.img
ExtSparse : Compression ratio : 19%
Read : phase.cfg
Read : u-boot-spl.bin
Waiting for device ...
ADB : Device found!
ADB : Connected!
ADB : Prepare Ok!
Cookies!
Found vodka!
Found bear!
Firmware size : 0x112EF11FC ( 4.30 GiB )
Android Info saved : _Android_info.txt
Done!
Elapsed: 01:11:51
Because of no ExtSparse for System partition, firmware size also increased a lot.
3.75 GB only System.img
The Following User Says Thank You to fahadboss For This Useful Post:
Old 07-02-2020, 10:10   #165 (permalink)
JayDi's Avatar
Member: 462970
Open : SPD_PROG.xml
Reading package ...
Ver. CodeName  : REL
Ver. Release   : 8.1
Product Name   : A10
Product Info   : A10
Product Model  : A10
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
PMTMng : Load PMT
PMTMng : 0x20
That may happen sometimes, try select FW then change generic boot to your chip and try again.
Make sure battery charged.
If device not power on - try also make complete format and then flash.
Page generated in 0.43793 seconds with 8 queries
