GSMSERVER GSM Shop
Old 05-02-2020, 19:11   #61 (permalink)
Member: 2576731
Thanks Meter: 4
To me the Pic 2 happen if I open two times the cm2sp2/cm2mtk2/scr but now I'm not rushing just click and weat
Old 05-02-2020, 19:23   #62 (permalink)
Crazy Poster
Member: 2927861
Thanks Meter: 6
greetings
Whenever I install an antivirus the infinity modules do not open, what do I do? because i can't use my pc without antivirus.
Old 05-02-2020, 19:26   #63 (permalink)
Member: 1043909
Thanks Meter: 54,048
Originally Posted by Khadaff_papillo View Post
greetings
Answered in other thread. Please check it
Old 05-02-2020, 19:27   #64 (permalink)
Member: 1043909
Originally Posted by MNA89 View Post
HELLO INFINITY TEAM GREETING! I WOULD LIKE TO SHARE A PAINFUL BUG OF INFINITY UPDATE NOW A DAYS PLEASE CHECK BELOW MY ALL ERROR DETAIL !
BEFORE IT WAS HAPPEN ON LATEST UPDATE CM2 SCR 1.06 MODULE UNTIL NOW THERE IS NO SOLUTION ! AND NOW THIS ERROR IM GETTING ON SAME cm2spd2 2.05 UPDATE.
THERE IS NO SIGN OF ANY VIRUS
ALREADY INSTALLED FRESH WINDOW 10 ENTERPRISE 64 BIT
1ST OF ALL CHECK DONGLE FIRMWARE DETAIL:
Box/Dongle found: Infinity-Box/Dongle
Serial No (S/N): XXXXXXX
Firmware version: 0143.02
=> Activations:
- 00: Infinity-Box/Dongle v0143
NOW WHEN I INSTALLED CM2 SP2 (2.05) VERSION AND I GET THESE ERROR
ERROR NO# 1
https://imgur.com/Fs6dmZs
after press Ok The Open Module like this
error # 2
https://imgur.com/GvKzRJE
every thing empty in this module!
before i was getting same issue on cm2 scr 1.06 module but for mine 1.05 module working Ok and Also Previous version of cm2sp2 2.04 working Fine Only The new updates Are very Very such a Painful becoz if i got these error so its mean i cannot use new modules !
Addational Deatil:
System Info :
https://imgur.com/rbn59CA
other thread has an answer, please check it
Old 05-02-2020, 19:28   #65 (permalink)
Member: 1043909
Originally Posted by khalillll View Post
Yes, I found it
fault : 35 octets ( E R R O R : P R I V I L E G E )...
i delete it and turn off kaspersky , then reinstall cm2spd2 2.05 again...
the same problem..
what is "same problem" ?
Old 05-02-2020, 19:30   #66 (permalink)
Member: 1043909
sorry. but this is not update; this is real problem.
good luck.
sorry but it looks like your antivirus gives a problem. good luck and try to disable antivirus
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 05-02-2020, 19:35   #67 (permalink)
Member: 1043909
i did this :
other pc , without old installation and without antivirus
the same results.. logo infinity then no things
Do you have fault.bin file in folder with software at this PC ?
Old 05-02-2020, 19:37   #68 (permalink)
Member: 1043909
Yes, I found it
the same problem..
You should disable kaspersky and run Infinity software As Administrator
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 05-02-2020, 19:39   #69 (permalink)
Member: 1043909
Disable antivirus and run Infinity software As Administrator
result ?
Old 05-02-2020, 21:59   #70 (permalink)
nduka's Avatar
Member: 1943439
Sonork: 100.1669578
Thanks Meter: 197
All my setup and exe opens except this spd2 new version
I uninstalled and installed previous one still not opening
The exe works fine before I update card and open
My dongle keeps on blinking light as if it wanted to open at the
End light goes off
Old 05-02-2020, 22:25   #71 (permalink)
Member: 2948043
Thanks Meter: 2
hi ...
now; i know exactly my problem.
firstly, cm2spd 2.05 / cm2scr 1.06 does not open because the protection is active . just need uninstall it (spd/scr) + delete folder + then restart system, after that install it again .... and before run it you need add to exclusions.. only.
2nd pc, new system + without antivirus, but the problem in the ( deep freeze).. cm2spd 2.05 / cm2scr 1.06 will not open with it.
thank you infinity team.
The Following User Says Thank You to khalillll For This Useful Post:
Old 05-02-2020, 22:35   #72 (permalink)
Member: 1043909
End light goes off
Do you have fault.bin file in folder with Infinity software ?
Old 05-02-2020, 22:37   #73 (permalink)
Member: 1043909
Do you have fault.bin file in forlder with Infinity software at that 2nd PC ?
Old 05-02-2020, 22:49   #74 (permalink)
Member: 2948043
Thanks Meter: 2
yes ....................(
Old 05-02-2020, 23:15   #75 (permalink)
Member: 2948043
Thanks Meter: 2
Confirmed .
If the system is protected by deep freeze
cm2spd 2.05 / scr 1.06 will not open.
The error file (fault.bin = 35 octets) is created .
good luck.
Page generated in 0.17765 seconds with 8 queries
