Old 06-11-2018, 14:41   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Infinity Chinese Miracle II SCR/SPD-RDA v1.03: New models and features
Supported CPU list:
Spreadtrum: SC6530, SC6531, SC6531(A/C), SC6531E, SC6533, SC6533G
RDA Mirco: RDA8851 rev A,B,C,L,CL
RDA Micro: RDA8826
RDA Mirco RDA8851 rev A,B,C,L,CL/RDA8826
Flashing protocol updated
Updated LOD tools ( flashing / customizing )
Spreadtrum SC6533/G:
Protocol updated
Support for REV2 bootrom mode activated
FW reading revised
Spreadtrum SC6530/6531/A/C/E:
Revised Repair security feature
Flashing revised
-> Activated "Format FFS" during BINARY dump writing
-> Use that feature, if device not allow make direct format ( some C/E revision devices )
User code read revised - activated 2nd mode : from DUMP
-> Press and hold LEFT SHIFT key, while starting ReadUsercode code operation. Select desired dump file to read code.
Activated AUTO fixer for memory dumps
Internal loaders updated
Spreadtrum other:
Protocol updated
PAC handling revised
Improved Flashing procedure for SC7701/SC7702 devices
Improved Flashing procedure for SC6825/SC8825 devices
Known issues[*]/warnings[!]/info[I]:
1. [I] AUTO fixer for memory dumps
-> That feature will AUTOMATICALLY FIX dumps from devices with "abnormal" flash and memory layout ( issue found on number of devices 16MB flash with 8MB layout )
-> Just select binary dump in flashing tab or any other operation, which require file select.
2. [*] In some cases Format FFS may fail on E and C rev
-> Read Flash Dump, write it back. During Dump writing SW will ask you about FormatFFS.
Download link
Upload file to Support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
The Following 65 Users Say Thank You to YellowBoss For This Useful Post:
Old 06-11-2018, 15:00   #2 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
Good Update Infinity Team
The Following 3 Users Say Thank You to nahidroman For This Useful Post:
Old 06-11-2018, 15:06   #3 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
needed firmware updates but no update on dongle firmware updater
Old 06-11-2018, 15:11   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Missing in Update logs: Firmware version: 0137.02 is required to use this update.
Thanks team for this great update.
The Following 2 Users Say Thank You to Kirumira For This Useful Post:
Old 06-11-2018, 15:17   #5 (permalink)
Member: 2048880
Thanks Meter: 63
dongle frimware is outdate please update whit dongle manager
but dongle manager say your dongle is updated to latest version (0136)
The Following User Says Thank You to rezakeshavarza For This Useful Post:
Old 06-11-2018, 15:38   #6 (permalink)
Member: 138234
Thanks Meter: 79
DongleManager [Infinity] v1.72
Firmware version: 0136.02
=== Process started: 11/06/2018 15:26:30 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
where's the problem please ?
The Following User Says Thank You to MBtech For This Useful Post:
Old 06-11-2018, 15:44   #7 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Hello,
@MBtech
Check dongle support Expiry date.
How to check here https://www.infinity-box.com/doc.php?id=17
If Expired contact your
Nearest Resellers for Support Renewal.
Old 06-11-2018, 15:46   #8 (permalink)
Member: 694980
Thanks Meter: 91
I can not use this version.
How to solve this problem
Old 06-11-2018, 15:49   #9 (permalink)
Member: 1677653
Thanks Meter: 2,769
Time to renew your support.
The Following 2 Users Say Thank You to Yusuf Lawal For This Useful Post:
Old 06-11-2018, 15:53   #10 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
The Following 3 Users Say Thank You to Kirumira For This Useful Post:
Old 06-11-2018, 16:00   #11 (permalink)
SR9
SR9's Avatar
Member: 957066
Sonork: 100.1658197
Thanks Meter: 642
Thanks for this great update team.....
Old 06-11-2018, 16:54   #12 (permalink)
Member: 694980
Thanks Meter: 91
do I have to pay for new CM2 activation?
Old 06-11-2018, 17:01   #13 (permalink)
Member: 1677653
Thanks Meter: 2,769
Hello,
Estimted price - https://www.infinity-box.com/price.php
Please contact to nearest seller for details - https://www.infinity-box.com/buy/
Old 06-11-2018, 17:03   #14 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
NO, Just Renew support 1 or 2years depends on you.
Price here https://www.infinity-box.com/price.php
Old 06-11-2018, 17:04   #15 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
@Kirumira, device recovered now?
My test samples seems as Ok.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.21639 seconds with 9 queries
