Old 09-08-2018, 19:56   #121 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by mfarazmalik View Post
CM2SCR TOOL
NOT OPEN .
DONGLe firmware version .v0136
dongle firmware version is outdated
download donglemanger from support and update firmware.
,after update donglemanger , dongle upto date
Hello,
What is your dongle support validity date ?
How to check - http://www.infinity-box.com/doc/?r=17
If support is expired please contact to any seller and renew support.
Old 09-12-2018, 19:07   #122 (permalink)
Crazy Poster
Member: 1674834
Thanks Meter: 6
Mr. JayDi
I just wanna ask about SCR driver isntallation, is it can use RDA driver or not? Mean just change destination folder installtion to SCR folder?
Old 09-19-2018, 10:28   #123 (permalink)
Member: 2243017
Thanks Meter: 29
mobicel astro.spd sc7731c 8.0.
pleas team add all new spd sc7731 coming with 8.0 frp remove,flash
Old 09-22-2018, 13:54   #124 (permalink)
Member: 2576731
Thanks Meter: 72
Please update spd to undroid 8 oreo support pls sc7731e not supported pls. Update
Old 09-23-2018, 19:19   #125 (permalink)
Member: 1691349
Thanks Meter: 22
Originally Posted by InfinitySupport View Post
Hello,
Dear master
Same here I facing this issue
And my support is working fine
I have update firmware
After it same as same....
Old 09-26-2018, 08:22   #126 (permalink)
Member: 1741973
Thanks Meter: 115
Infinity support error? cant download today
http://www.infinity-box.com/support/?r=12
Old 09-26-2018, 09:11   #127 (permalink)
Member: 2499103
Thanks Meter: 60
qmobile l8i formate success with scr 6533.
here is log
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.44.2
InternalVersion: g8bec5c4c
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:22
Reconnect Power/Cable!
The Following 2 Users Say Thank You to mimarijaz71 For This Useful Post:
Old 09-26-2018, 16:46   #128 (permalink)
saifulhaq28's Avatar
Member: 1902758
Sonork: 100.1680534
Thanks Meter: 153
Flash File Need Urgent. how can i found this model in support area?
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 34 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004E35575A4D4201435FB8B8B06D
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMZW5
[eMMC] : FLASH_CID : 1501004E35575A4D4201435FB8B8B06D
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x4F368B49DC57C2F4A6FBA8B24D0143C2
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : alps
ProdName : rtech72_we_72_kk
ProdModel : rtech72_we_72_kk
Device : rtech72_we_72_kk
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.KK1.MP6.V1
Done!
Elapsed: 00:00:15
Old 09-26-2018, 21:44   #129 (permalink)
Member: 148515
Thanks Meter: 19,534
Hi,
I don't see any problem. Clear your browser cache and try once again.
result ?
Old 09-27-2018, 07:28   #130 (permalink)
skynumber's Avatar
Member: 872681
Sonork: 1680923
Thanks Meter: 52
Originally Posted by YellowBoss View Post
Infinity Chinese Miracle II SCR/SPD-RDA v1.03: New models and features
Supported CPU list:
Spreadtrum: SC6530, SC6531, SC6531(A/C), SC6531E, SC6533, SC6533G
RDA Mirco: RDA8851 rev A,B,C,L,CL
RDA Micro: RDA8826
RDA Mirco RDA8851 rev A,B,C,L,CL/RDA8826
Flashing protocol updated
Updated LOD tools ( flashing / customizing )
Spreadtrum SC6533/G:
Protocol updated
Support for REV2 bootrom mode activated
FW reading revised
Spreadtrum SC6530/6531/A/C/E:
Revised Repair security feature
Flashing revised
-> Activated "Format FFS" during BINARY dump writing
-> Use that feature, if device not allow make direct format ( some C/E revision devices )
User code read revised - activated 2nd mode : from DUMP
-> Press and hold LEFT SHIFT key, while starting ReadUsercode code operation. Select desired dump file to read code.
Activated AUTO fixer for memory dumps
Internal loaders updated
Spreadtrum other:
Protocol updated
PAC handling revised
Improved Flashing procedure for SC7701/SC7702 devices
Improved Flashing procedure for SC6825/SC8825 devices
Known issues[*]/warnings[!]/info[I]:
1. [I] AUTO fixer for memory dumps
-> That feature will AUTOMATICALLY FIX dumps from devices with "abnormal" flash and memory layout ( issue found on number of devices 16MB flash with 8MB layout )
-> Just select binary dump in flashing tab or any other operation, which require file select.
2. [*] In some cases Format FFS may fail on E and C rev
-> Read Flash Dump, write it back. During Dump writing SW will ask you about FormatFFS.
Download link
Upload file to Support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
dear sir i have infinity for next 2 year support
after my activation of 2 year support the infinity team announced next SM tool as paid tool,
and not seen any update for a long time from infinity team for MTK, SPD, LGS, QLM, RAD, RKT and SM Tools
just updating only SM tool which is paid tool,
so what is Benefit for me of the two years support?
Old 10-02-2018, 08:30   #131 (permalink)
Member: 839673
Sonork: pastorshaggy
Thanks Meter: 66
is there ime repair in this version
Old 10-02-2018, 08:52   #132 (permalink)
Member: 2868260
Link to download cm2
Old 10-02-2018, 09:27   #133 (permalink)
Member: 1677653
Thanks Meter: 2,769
Index of pub/software/
Old 10-04-2018, 00:06   #134 (permalink)
Member: 1998000
Hello Infinity Team,please add the spd sc9850k chipset
Old 10-04-2018, 03:22   #135 (permalink)
Member: 1677653
Thanks Meter: 2,769
When u select sc9830 what is the error u got?
Post log from infinity cm2
Page generated in 0.28640 seconds with 9 queries
