04-07-2022, 23:48 | #1 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Pakistan
Member: 2243606 Status: Offline Thanks Meter: 9 | OPPO A16 CPH2269 Flash Failed Error : Fail to init protocol! here is identify log Card found : FAA1239E , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 2EFA82AE79BCFD18F06F0A8D6604646D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 04BC4150043DBB93BC8B94B17A9822B9E30976FDF4D7284C40 30DD73EA6E637F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 15010044503644424202240DCA79B857 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 604883577 ( 0x240DCA79 ) , MF : 11/2021 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 15010044503644424202240DCA79B857 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 604883577 ( 0x240DCA79 ) , MF : 11/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2F24DB0926A8E1E89E9260E55006E9A2 DA : USB : HIGH-SPEED Boot done! Product Board : oppo6765 Board Platform : mt6765 Product Brand : alps Product Device : oppo6765 Product Manfct : alps Product Model : oppo6765 Product Name : vnd_oppo6765 Device UID : MT6765__CPH2269_export_PRD_11_A.09_202112201056557 0 USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : OPPO6765_20375_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R 3_TC16_SP_V1_P34 NVRAM : 0xA108C35F NVRAM : State : Ok! INFO : WiFi MAC : 401035733206 INFO : BlTh MAC : 000046000001 Backup sensetive data [ 18 ] Backup path : Backup\MT6765__2EFA82AE79BCFD18F06F0A8D6604646D\ [35] Read : NVRAM [14] Read : NVDATA [22] Read : PROINFO [36] Read : LK [13] Read : NVCFG [17] Read : PROTECT1 [1] Read : PGPT [20] Read : PERSIST [0] Read : PRELOADER [7] Read : OPPORESERVE3 [8] Read : OPPO_CUSTOM Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Done! Elapsed: 00:01:37 And Here is flashing error log. Operation : Write Flash [ v2.34 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Enabled Safe UserData : Disabled Flash Format : Disabled Files :25 [FL] : Set : preloader_oppo6765.bin [FL] : Set : recovery.img [FL] : Set : opporeserve2.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : cdt_engineering.img [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : gz.img [FL] : Set : gz.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : dtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : super.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x171DF210C [ 5.78 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 2EFA82AE79BCFD18F06F0A8D6604646D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 04BC4150043DBB93BC8B94B17A9822B9E30976FDF4D7284C40 30DD73EA6E637F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 15010044503644424202240DCA79B857 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 604883577 ( 0x240DCA79 ) , MF : 11/2021 EMI : DEV : MT6765 EMI : SRC : preloader_oppo6765.bin EMI : CNT : 0007 EMI : [00] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100445836384D42 : VEN : SAMSUNG | DEV : DX68MB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
05-16-2022, 07:20 | #3 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | EMMC: CID : 15010044503644424202240DCA79B857 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 604883577 ( 0x240DCA79 ) , MF : 11/2021 EMI : [00] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100445836384D42 : VEN : SAMSUNG | DEV : DX68MB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] emmc not matched |
