Old 08-01-2020, 07:14   #1 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
mmx Q440 dead after flash now ask Auth file
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.14
Load IDBase v714142 Ok!
Update configuration ...
Update Ok!
Operation : Identify [ v2.14 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM10)
MODE : BOOTROM
PORT : 10
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCC00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2012 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00007017 : DA SEND ERROR!
  ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE!
  INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type!
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
before flash its hang on logo and need custome DA
now it cant flash with any DA and ask for auth
here flash log
Operation : Write Flash [ v2.14 ]
Repartition   : Enabled
Flash Verify  : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW  : Enabled
SData Backup  : Disabled
Safe UserData : Disabled
Flash Format  : Disabled
Files :11
[FL] : Set : preloader_spro6737t_65_n.bin
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : recovery.img
[FL] : Set : logo.bin
[FL] : Set : secro.img
[FL] : Set : trustzone.bin
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0xC2CD044C [ 3.04 GB ]
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM8)
MODE : PRELOADER PORT
PORT : 8
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : BROM|BL  : 0xFF|0x01
BROM : PRELOADER PORT
MODE : 0_base : BASE_v2012 | Manual : Enabled
AGENT : da_swsec.bin
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 7001004548414345410125EB5B56D5EB
DAInf: 4 : 2 : 155
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 7001004548414345410125EB5B5665EB
        EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x3A5000000 [ 14.58 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        DRAM: 0x80000000 [ 2.00 GB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCC00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 6B98D6873641716D83528E5A1FF17AEB
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
[FL] : HW verification passed!
SEC_DL : True (CUST)
SEC_DL : SECURE USB DL ENABLED
SEC_ID : 0x61666337613830363937396132393834
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000000080000
Erase : 0x0000000001C80000 : 0x0000000008E80000
Erase : 0x000000000B800000 : 0x0000000398740000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader code ...
ERR : 0xC0030007
ERR : INVALID PARAMETERS
ERR : 0x00000000|0x00000000
Error : Flashing failed!
>>> Seems as something wrong with device! Check battery charge and device state!
here read info before flash
PORT : 8
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
     DA : DRAM ready!
        EMMC:
Boot done!
Patch Level    : NRD90M
Display ID     : MMX_Q440_000_0116_V5.0_130818
Ver. CodeName  : REL
Ver. Release   : 7.0
Sec. Patch     : 2018-08-05
Build Time     : 1534129181
Product Model  : Micromax Q440
Product Brand  : Micromax
Product Name   : Q440
Product Device : Q440
Product Board  : Q440
Product Manfct : Micromax
Board Platform : mt6737t
Product Info   : Q440
USERDATA : FILESYSTEM : EXT4  with FDE ( Full Disk Encryption *)
IMEI[0] : 91***********8
IMEI[1] : 91***********5
NVRAM check : Passed!
NVRAM : SEC NORMAL  [ No extra security ]
Backup sensetive data [ 10 ]
Backup path : Backup\MT6735__6B98D6873641716D83528E5A1FF17AEB\
[3] Read : NVRAM
[19] Read : NVDATA
[2] Read : PROINFO
[6] Read : LK
[4] Read : PROTECT1
[5] Read : PROTECT2
[0] Read : PRELOADER
Backup done!
Done!
Elapsed: 00:00:26
Old 08-02-2020, 09:00   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Firmware seems as not factory ones and not made by Infinity.
Old 08-02-2020, 11:05   #3 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
firmware from micromax FTP
and
problem for me now it not take boot from any that custome DA which MMX FTP have and also not with any DA and preloader scater
same Custome DA work with Preloader port when set alive
now with dead it also ask auth
here DA file if you want check
https://drive.google.com/file/d/1ZzY...ew?usp=sharing
Old 08-02-2020, 11:08   #4 (permalink)
JayDi's Avatar
Member: 462970
Should it? Not.
Need BR da or da+auth for boot it. Will download and check that fw.
Old 08-02-2020, 11:22   #5 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Should it? Not.
exactly now it need DA for BR mode or DA + Auth
in tecno we face same problem but with OG tool we recover set and in OG tecno tool not ask for auth
but for this MMX i not found any tool like tha
and if i try various Auth it not sutaible
if something found you sir plz help us
Old 08-02-2020, 14:29   #6 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Hi Friend Is This Q440 From CG... Q440 Having 2 Varient 1 Normal 2nd Q440 With Customised Firmware Sanchar Kranti CG Q440..Which One Is Yours As Per Log Its CG Q440 Model Conform This I Will Give U Next Steps To Follow
Old 08-02-2020, 14:44   #7 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
thx bro
on back side written on sticker
H/W ver V5.0
SW ver MMX_000_0116_V5.0_130818
and when i ask Service Center they say its CG phone ( you know )
they gave me file
MMX_Q440_000_0117_V5.0_270818.rar
with DA da_swsec.rar
with tool SP_Flash_Tool_v5.1820_Win.rar
but unfortunately i got same error on that file also
if you have something for me plz help
Old 08-03-2020, 15:05   #8 (permalink)
Member: 1834832
Thanks Meter: 1,450
thx bro
H/W ver V5.0
they gave me file
Never Flash This Phone With Any Box..This Phone having A ****y IC Kingstone Which Dead Mostly While Any Operation As Phone Having Custom Firmware N Security U Can't Rebuilt Security ..In Infinity Its Supported With Earlier Ver V2.05 Or I Think Lower 2.04 After New Sw Release It Not Support N Failed In Flash Even In Format Too...I Forget To Report This Issue As After This Issue Arrive I Mostly Flash With SP Flash Tool Only For This Model..In Firmware Folder U Will Found Da_Pl.bin Try With This DA File If Same Issue Then May Be EMCP Issue..This Handset Rare Alive After Brick With Any Tool So Beware Better Write Only System Userdata N Cahce In Future For This Model...
The Following User Says Thank You to hitech care For This Useful Post:
Old 08-03-2020, 15:27   #9 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
thx for info , also test DA_pl.bin and not sucsess and for emmc damage i am sure its alive
may be need play with jtag
Old 08-03-2020, 15:27   #10 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Page generated in 0.23284 seconds with 8 queries
