02-05-2024, 21:21 | #1 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Vanuatu/ Philippines Age: 43
Member: 2418465 Status: Offline Thanks Meter: 23 | blackview bv6600 pro frp lock [done] S/N: 002Eccccccc v0159 Chinese Miracle II - MT2 Service Tool v2.52 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\LinuxP\Downloads\Compressed\ Backup files: C:\Program Files (x86)\CM2MT2\backup\ Backup files: 8 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 76 DA profiles... Ok libusb: v1.2.7.3 Init environment... Ok Load IDBase v915508 Ok boot-pack is not installed or outdated Check for updates [CM2MT2]... You have latest version [2.52] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Wrong Username or Password Be sure you have set valid Username and Password in [Settings|Account] DA selected: Blackview | A7-MT6580 | MTK_AllInOne_DA_SP.bin Operation: Identify Device [ v2.52 ] Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71 Mode: FLASH Port: Both [ B + P ] [+] High-Speed [+] Auto-EMI [+] FireFly-Over-DA extended protocol [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... User break User break: 00:00:24 Reconnect Power/Cable now DA selected: 0_rare | MT6570_FACTORY | MTK_AllInOne_DA.bin DA selected: 0_base | base_v2316 | MTK_AllInOne_DA.1d5fdec4.bin Operation: Identify Device [ v2.52 ] Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71 Mode: FLASH Port: Both [ B + P ] [+] High-Speed [+] Auto-EMI [+] FireFly-Over-DA extended protocol [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM77) MODE [0]: PRELOADER PORT; PORT: 77 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 0E4C7589F21D1CF54EC9283584B0B6ACEA60B3542F1B0BB34F A57DF6DC7FEBD3 PTFN: MediaTek USB Port_V1632 (COM18) MODE [0]: BOOTROM; PORT: 18 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: A841CE53365077B678262FD73E4B1BE6 BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 0E4C7589F21D1CF54EC9283584B0B6ACEA60B3542F1B0BB34F A57DF6DC7FEBD3 FireFly: Init Start Auth... Ok Continue Auth... Ok Start... Ok Init Core... Ok FireFly: Running: v06.05.06 on MT6765 EMMC init passed Stored: C:\Program Files (x86)\CM2MT2\backup\ext_csd\MT6765__Samsung_DP6DAB _5.1_extcsd_05022024.bin EMMC CID: 15010044503644414202D312021A7745 crc Ok Ven: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 3541172762 [0xD312021A] MM/YY: 7/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CSD: D02701320F5903FFF6DBFFEF8E40400D TEMP_WRITE_PROTECT: Off PERM_WRITE_PROTECT: Off EXTCSD: rev1.8 EMMC 5.1 [CONFIG]: 0x50 0x02 0x01 [PARTITION_CONFIG]: 0x50 [BOOT_BUS_WIDTH]: 0x02 [RST_N_FUNCTION]: 0x01 [PART_S_COMPLETED]: Off [SIZE]: Market: 64 GB [SIZE]: Actual: 0xE8F800000 [ 58.24 Gb ] [EOL]: EOL status: Normal (Less than 80% reserved blocks used) [EOL_A]: SLC status: 0% - 10% used [EOL_B]: MLC status: 0% - 10% used USB: HIGH-SPEED Boot done FireFly Analyze PMT... Ok PMT: PGPT [0x64] Records: 46 Get slot info... b Select info source... boot_b [2000000] Ok SW: Blackview/BV6600Pro/BV6600Pro:11/RP1A.200720.011/1668513298:user/release-keys Product Brand: Blackview Product Device: BV6600Pro Product Model: BV6600Pro Product Name: BV6600Pro Patch Level: RP1A.200720.011 Display ID: BV6600Pro_NEU_ZN128G_V1.0_20221115V13 SW Version: 1668513298 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-10-05 Build Time: 15-Nov-22 12:03:55 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: BV6600Pro SW: full_k65v1_64_bsp-user 11 RP1A.200720.011 p1k61v164bspP45 release-keys Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: Blackview Strategy: [none|generic] Firmware ID: MT6765_Blackview_BV6600Pro_OSv11_BV6600Pro_NEU_ZN1 28G_V1.0_20221115V13_RP1A.200720.011_BV6600Pro Verify firmware [MT6765_Blackview_BV6600Pro_OSv11_BV6600Pro_NEU_ZN1 28G_V1.0_20221115V13_RP1A.200720.011_BV6600Pro]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xB8 Size: 0x0AC883 State: Ok WiFi MAC: AA006E742F76 BlTh MAC: 4A2C468C7B13 IMEI[1]: 351804660367285 IMEI[2]: 351804660367293 Verify config values... Ok Loaders Ok Backup to C:\Program Files (x86)\CM2MT2\backup\MT6765__A841CE53365077B678262F D73E4B1BE6\ Items to check: 20 Read [16] NVRAM Read [7] NVDATA Read [15] PROINFO Read [6] NVCFG Read [10] PROTECT1 Read [1] PGPT Read [13] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\Program Files (x86)\CM2MT2\backup\MT6765__A841CE53365077B678262F D73E4B1BE6\ Cleanup... Ok Verify C:\Program Files (x86)\CM2MT2\backup\MT6765__A841CE53365077B678262F D73E4B1BE6.7z Verified Analyze preloader... EMI: MT6765 preloader_k65v1_64_bsp.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444D42 Samsung DH6DMB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 13014E53304A394438 Micron S0J9D8 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 13014E53304A394B38 Micron S0J9K8 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 450100444134303634 Sandisk DA4064 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 11. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 12. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 13. eMMC DDR3 ID: 13014E53304A394638 Micron S0J9F8 RAM: 4.00 Gb 14. eMMC DDR3 ID: 13014E53304A394E38 Micron S0J9N8 RAM: 4.00 Gb 15. eMMC DDR3 ID: 150100524331344D42 Samsung RC14MB RAM: 4.00 Gb 16. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb 17. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 18. eMMC DDR3 ID: 150100524836344D42 Samsung RH64MB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 20. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 4.00 Gb Preloader saved: C:\Program Files (x86)\CM2MT2\backup\preloader\preloader_k65v1_64_b sp.bin Verify C:\Program Files (x86)\CM2MT2\backup\preloader\preloader_k65v1_64_b sp.bin [615e97a3]... Exist Probe FRP... On Probe MDM... Can not load data from server Be sure you have set valid Username and Password in [Settings|Account] Probe network config... State: Default Reset port... Done: 00:04:45 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71 [-] Wipe [-] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM18) MODE [0]: BOOTROM; PORT: 18 Waiting for BOOT ACK... BROM: Init... Fail to init protocol Disconnect battery and cable - Check USB drivers - Change cable - Change USB port - Do not use USB-hub - Select another base|model|DA - Try again Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71 [-] Wipe [-] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM77) MODE [0]: PRELOADER PORT; PORT: 77 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 0E4C7589F21D1CF54EC9283584B0B6ACEA60B3542F1B0BB34F A57DF6DC7FEBD3 PTFN: MediaTek USB Port_V1632 (COM18) MODE [0]: BOOTROM; PORT: 18 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: A841CE53365077B678262FD73E4B1BE6 BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 0E4C7589F21D1CF54EC9283584B0B6ACEA60B3542F1B0BB34F A57DF6DC7FEBD3 FireFly: Init Start Auth... Ok Continue Auth... Ok Start... Ok Init Core... Ok FireFly: Running: v06.05.06 on MT6765 EMMC init passed Stored: C:\Program Files (x86)\CM2MT2\backup\ext_csd\MT6765__Samsung_DP6DAB _5.1_extcsd_06022024.bin EMMC CID: 15010044503644414202D312021A7745 crc Ok Ven: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 3541172762 [0xD312021A] MM/YY: 7/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CSD: D02701320F5903FFF6DBFFEF8E40400D TEMP_WRITE_PROTECT: Off PERM_WRITE_PROTECT: Off EXTCSD: rev1.8 EMMC 5.1 [CONFIG]: 0x50 0x02 0x01 [PARTITION_CONFIG]: 0x50 [BOOT_BUS_WIDTH]: 0x02 [RST_N_FUNCTION]: 0x01 [PART_S_COMPLETED]: Off [SIZE]: Market: 64 GB [SIZE]: Actual: 0xE8F800000 [ 58.24 Gb ] [EOL]: EOL status: Normal (Less than 80% reserved blocks used) [EOL_A]: SLC status: 0% - 10% used [EOL_B]: MLC status: 0% - 10% used USB: HIGH-SPEED Boot done FireFly Analyze PMT... Ok PMT: PGPT [0x64] Records: 46 Get slot info... b Select info source... boot_b [2000000] Ok SW: Blackview/BV6600Pro/BV6600Pro:11/RP1A.200720.011/1668513298:user/release-keys Product Brand: Blackview Product Device: BV6600Pro Product Model: BV6600Pro Product Name: BV6600Pro Patch Level: RP1A.200720.011 Display ID: BV6600Pro_NEU_ZN128G_V1.0_20221115V13 SW Version: 1668513298 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-10-05 Build Time: 15-Nov-22 12:03:55 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: BV6600Pro SW: full_k65v1_64_bsp-user 11 RP1A.200720.011 p1k61v164bspP45 release-keys Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: Blackview Strategy: [none|generic] SmartInfo: Android Ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup exist: C:\Program Files (x86)\CM2MT2\backup\MT6765__A841CE53365077B678262F D73E4B1BE6 Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:59 Reconnect Power/Cable now |
The Following User Says Thank You to professorjazz For This Useful Post: |
