02-02-2024, 21:21 | #16 (permalink) |
Insane Poster Join Date: Apr 2011 Location: Romania
Member: 1555576 Status: Offline Thanks Meter: 11 | Code: Wait... S/N: Chinese Miracle II - SP3 Service Tool v2.21 Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... SP3 boot-pack v1.03 2024-01-27 Ok Ready Selected: T606 [Boot FireFly] [FF] protocol may be SLOW, for flash Read/Write use [FDL] Operation: Connect [T606 Boot FireFly] [v2.21] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM214) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok crc? fault 0x71 0x8E | BSL_PHONE_WAIT_INPUT_TIMEOUT Storage is not initialized or not supported Loader exec Fail Canceled Finished 25 sec Selected: motorola moto-E13 [Boot FireFly] [FF] protocol may be SLOW, for flash Read/Write use [FDL] Selected: motorola moto-E32-global [Boot FireFly] [FF] protocol may be SLOW, for flash Read/Write use [FDL] Operation: Connect [T606 Boot FireFly] [v2.21] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM214) vid 0x1782 pid 0x4D00 crc? boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok crc? fault 0x71 0x8E | BSL_PHONE_WAIT_INPUT_TIMEOUT Storage is not initialized or not supported Loader exec Fail Canceled |
02-02-2024, 21:47 | #17 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,993 | Quote:
02-03-2024, 11:21 | #19 (permalink) | |
Member: 1555576 Status: Offline Thanks Meter: 11 | Quote:
The Following User Says Thank You to cristi33 For This Useful Post: |
02-03-2024, 12:35 | #20 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,058 | Realme C30s Format + FRP Code: Selected: realme RMX3690 [Boot FireFly] [FF] protocol may be SLOW, for flash Read/Write use [FDL] Operation: Connect [sc9863a Boot FireFly] [v2.22a1 (beta)] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM15) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok crc? Loader exec Ok Dev UID: 32bdea5994e15e130b16ca41192a1db33cb08b9a71d52224bc9d872ac020e41c get storage info... EMMC cid: D6010341334135353112C76AC32DA923 crc Ok Vendor: Foresee OEM: 259 ID: 413341353531 [A3A551] PRV: 0x12 Serial: 3345662765 0xC76AC32D MM/YY: 10/2022 CSD: D0FFFF329F5903FFFFFFFFEF964000FF temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 ERASE_GROUP_DEF: 0x 0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 SIZE: 0x00400000 4.00 Mb WP_GRP_SIZE: 0x00800000 8.00 Mb RPMB size: 0x01000000 16.00 Mb SIZE: Market 32 Gb SIZE: Actual 0x73A000000 28.91 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 50% - 60% used EOL_B: MLC status: Not defined read extcsd... Ok extcsd backup exist, skip: C:\InfinityBox\CM2SP3\backup\ext_csd\sc9863_32bdea5994e15e13_extcsd_00D6-Foresee_A3A551_5.1_2024-02-03.bin Verify config values... Ok get partitions... Partitions: 73 items Loaded 73 Connected get slots... slot: a get sw info... probe boot... [vendor_boot_a] Patch Level: SP1A.210812.016 Display ID: RMX3690_12.A.39 SW OTA Version: RMX3690_12.A.39_0390_202212301644 SW Version: 202212301610 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2022-11-05 Build Time: 12/30/2022 9:02:05 AM Product Info: milan SW: milan_Natv-user 12 SP1A.210812.016 169 release-keys Product Device: RE58AB Product Brand: realme Product Model: milan_Natv Product Name: milan_Natv SW: realme/RMX3690/RE58AB:12/SP1A.210812.016/202212301610:user/release-keys Product Device: milan Product Manfct: realme Product Model: RMX3690 Product Name: RMX3690 Product Board: milan Board Platform: sp9863a Android Ver: 12; UserDataFS: 0x03 [f2fs]; CacheFS: 0x02 [ext4|8+] Tag: realme-milan-natv-rmx3690-re58ab Strategy: [none|generic] Firmware ID: SP9863A_realme_milan_Natv_OSv12_RMX3690_12.A.39_SP1A.210812.016_milan Read Device-ID... IMEI[0]: 868082062187629 IMEI[1]: 868082062187611 IMEI[2]: 867400020316638 IMEI[3]: 867400020316646 BT MAC: f8:5e:0b:ae:cc:f7 WF MAC: f8:5e:0b:ae:bd:57 Backup 8 items to: C:\InfinityBox\CM2SP3\backup\sc9863_32bdea5994e15e13\ Read [1/8] prodnv 10.00 Mb Ok Read [2/8] miscdata 1024.00 Kb Ok Read [3/8] uboot_a 3.00 Mb Ok Read [4/8] uboot_b 3.00 Mb Ok Read [5/8] l_fixnv1_a 2.00 Mb Ok Read [6/8] l_fixnv2_a 2.00 Mb Ok Read [7/8] l_fixnv1_b 2.00 Mb Ok Read [8/8] l_fixnv2_b 2.00 Mb Ok Done 8 files Compress: C:\InfinityBox\CM2SP3\backup\sc9863_32bdea5994e15e13\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\sc9863_32bdea5994e15e13.7z Verified [fe910407] Finished 1 min 42 sec Operation: Reset Settings / Format FS [sc9863a Boot FireFly] [v2.22a1 (beta)] WARNING: Reset may delete ALL USER DATA! Continue? Yes [+] Wipe [+] Userdata [+] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sc9863_32bdea5994e15e13\ Stage: Wipe... Reading... Ok Writing... Ok Stage: FRP... Looking for items... 1 item(s) found [1] Writing... Ok Completed Stage: Userdata... [1] Format... Ok 1 sec [2] Format... Ok 2 sec [3] Format... Ok 15 sec Completed Stage: Smart... [17] Format... Ok [18] Format... Ok Completed Finished 26 sec User break |
The Following User Says Thank You to xerraco For This Useful Post: |
02-03-2024, 15:17 | #22 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,993 | If you have PAC file try to use it as loader. How to select PAC https://forum.infinity-box.com/viewtopic.php?t=28616 |
