11-05-2010, 18:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: earth
Member: 992568 Status: Offline Sonork: kulit Thanks Meter: 231 | infinity com1 what is the used??? to all users of infinity box specially to infinity team can you tell me what is the used of this com1 port the only i know is the usb port but this one where and when can i used this port what kinds or connection do i use thnks everybody hpoe you will tell what is this. |
11-05-2010, 18:22 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | You can connect cable to any COM port (f.e. COM1). then you can select any port (f.e. COM1) in Infinity-Box software and unlock/flash phones via COM1 or any other port. |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
11-06-2010, 11:15 | #3 (permalink) | |
Member: 992568 Status: Offline Sonork: kulit Thanks Meter: 231 | Quote:
or what cable do i used for this or how do i connect properly i donot understand sir i have here ufs and ub box setool there are usb port so i truly dont know how to connect pls show me the cable that i used for or connection to do thnks and advanced merixmas to u | |
11-07-2010, 22:47 | #4 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
What COM port you want to use ? Do you want to use COM1 port (built-in into PC motherboard) or do you want to use some kind of usb/rs232 converters (like unibox etc.) ? | |
11-11-2010, 14:49 | #5 (permalink) | |
both of them sir COM1 port (built-in into PC motherboard) and usb/rs232 converters (like unibox etc.) the reason why i want to use that both is because some of unit is have cable in other box but some is in infinity cable let me give you and example sir. nokia model 6300 cable support in uni box so if this unit is china you must be used infinity for flashing and formatting did you get it boss what did i mean. another in sony model cable supported by infinity instead to modified again the cable its better to used infinity as interface. and also for this COM1 port (built-in into PC motherboard) how can we use this or how and for what is the porposed of that connection and to be used thnk you sir | |
11-12-2010, 12:37 | #6 (permalink) |
No Life Poster Join Date: Sep 2007 Location: MUMBAI
Member: 583454 Status: Offline Thanks Meter: 80 | i think u r confused about infinity output 1 is usb to rj45 out put and other is com1 to rj45 out put . right ?? 1. usb output is for normal use and u can use uni cables with that and for this u need to select com port no. of ur infinity box which u can see in device manager 2.for com1 out put u need to attach an extension from pc inbuilt com1 to infinity com1 input now if u connect infinity rj45 cable in com output u have to select com1 in infinity software both will work same except in some models we need to attach phones in com1 like F3c cdma and haier c1000 for succesfull flashing we can use infinity com1 out put but usually usb to rj45 output works ok good luck |
The Following User Says Thank You to waqarN70 For This Useful Post: |
11-12-2010, 15:06 | #7 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | this ma help you pc in built com port can not be directly used with cell phones because logic level voltage are different.pc com port signals swings between +/- 12v and cell phone works at TTL levels.here is simple vintage circuit to shift pc comport to ttl level and use with phone. |
The Following User Says Thank You to baldev For This Useful Post: |
11-12-2010, 15:40 | #8 (permalink) | |
can i used also the same rj45 im also thinking if i used both rj45 usb and com1 that you will see in the front of that box my porpuse here is also to know the faction all of them port and also to avoid destroying cable to modified to use in another unit again so in that way we are do repair in easily way without sacrificing another cable hope you can teach me sir in onetime again | |
11-12-2010, 15:42 | #9 (permalink) |
Member: 583454 Status: Offline Thanks Meter: 80 | no modification needed same cable of infinity works in both rj45 and u pls use left rj45 always as i already told u in 99% mobiles infinty usb com works gr8 only 2 or 3 mobile require com1 so for that models u need to connect pc com1 to infinity then right rj45 to phone |
11-12-2010, 15:48 | #10 (permalink) | |
Member: 153805 Status: Offline Thanks Meter: 325 | Quote:
The Following 2 Users Say Thank You to baldev For This Useful Post: |
11-12-2010, 15:59 | #12 (permalink) |
Member: 583454 Status: Offline Thanks Meter: 80 | see if we use com1 or com2 output com 1 from pc should be connected to infinty directly Last edited by waqarN70; 11-12-2010 at 16:05. |
The Following 2 Users Say Thank You to waqarN70 For This Useful Post: |
11-12-2010, 16:09 | #13 (permalink) | |
9 pin socket at the back of infinity box is connected to 9pin male plug at mother board.You can make cable with 9pin male and female plugs easily available at electronic spare shops. | |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
