Old 11-24-2019, 19:25   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Infinity Data Explorer software
Dear Friends,
Here is an information about Data Explorer software.
This software is a tool that helps to extract user's data from full flash file that you can read from phone with Infnity software (or other tools that can build plain bin file as output).
In this thread we will post news and information about this software functions.
This software is a completely new separate and independent product that has no any relation with previous projects.
This means you should buy an Data Explorer Activation from your seller if you want to use this software.
Data Explorer Activation available for the next Infinity Products:
- Infinity-Box/Dongle
- Infinity [BEST]
- Infinity CDMA-Tool
- Infinity Content Extractor Dongle
Download HERE
If you have any kind of requests about feature and supported models please post it here. We hope to get detailed technical information about features/devices but not only "need update" text.
Before make an order please check supported memory types and features carefully!
If you are not sure you can upload your image sample and supporters will check is it supported or not yet.
How to activate:
- Contact to any seller https://infinity-box.com/buy/
- Send your dongle S/N to seller and order Infinity Data Explorer software activation
- Wait order completed and update dongle firmware with Infinity DongleManager
Video tutorial Arabic: https://www.youtube.com/watch?v=lRzdqXMNDK4
Infinity Data Explorer v1.11 - MTK, SPD updated and more improvements
- MTK module updated - added Call List extraction for some models
- SPD firmware structure detection improved, important algos and methods updated
- Minor bugs fixed
Infinity Data Explorer v1.10 - MTK, SPD updated and more improvements
- MTK module updated (Added all files extraction)
- SPD module improved and updated
- FileSystem library updated (Full support all FAT versions)
- Added Function - Save FileSystem (as per users request)
- v1.08/v1.09 SPD detection failure bug fixed
- Minor bugs fixed
Infinity Data Explorer v1.09 - MTK, SPD, RDA updated and more improvements
- MTK module improved - more device supported
- SPD module updated - SPD66x0 support released
- RDA module updated - more Code pages supported
- GUI updated and improved
- Minor bugs fixed
Infinity Data Explorer v1.08 - Search Engine updated, SPD improvements and more
- SPRD engine rebuilded
- contacts save method updated
- long SMS parse method updated
- HTML export released (via templates)
- gui: log autoclear option before new operation
- gui: pop-up menus for log (clear and save options)
- folder with date/time creation for Converter
- Minor bugs fixed
Infinity Data Explorer v1.07 - SPRD engine rebuilded and more
- Minor bugs fixed
Infinity Data Explorer v1.06 - Android contacts/sms support and more
- Contacts and accounts reconstrucion from Android storage contacts2.db
- SMS messages reconstrucion from Android storage mmssms.db
- Data storage engine rebuilded
- TXT file storage format updated
- Minor bugs fixed
Update 04 Nov 2020:
From v2.08 of SP2 module, users with active DataExplorer module may readout UserData from Android SPD/UniSoc devices.
Due to platform restrictions, those device user data recovery are lead to complete disassemble/desolder FlashIc for dump anything from it.
Now that possible without any additional moves and with just USB cable.
Make sure you have made Identify first, then try check/Dump userdata, if it need to be extrcacted from device.
Even with enabled encryption flags in device, it can be not encrypted by a fact.
KaiOs , Mocor5, Android 4-6 devices are not encrypted almost at all.
  • example identify :
  • example dumping :
  • check image :
The Following 86 Users Say Thank You to YellowBoss For This Useful Post:
Old 11-24-2019, 19:31   #2 (permalink)
Member: 1043909
Infinity-Box Data Explorer v1.00 - Initial Release
- Data extraction based on full reconstruction of file system
- Initial features
1. Phonebook records extraction from dump
2. Phonebook records export to TXT, VCF formats
3. Memory type auto detection (Manual selection also supported)
4. File system parameters (sector size, header type) auto detection (Manual selection also supported)
- Supported devices:
MTK with NOR flash types, in most cases based on CPU types like MT625x, MT626x, and some MT622x
Here is a example of software result for full flash image with firmware version B6101_PRESTIGIO_PFP1242_DUO_PCB01
The Following 33 Users Say Thank You to YellowBoss For This Useful Post:
Old 11-24-2019, 21:15   #3 (permalink)
mouhane's Avatar
Member: 2178934
Thanks Meter: 1,288
What about other MTK cpu dumps ... will be supported in future ?
Extract userdata will be Great and worth the activation
The Following 7 Users Say Thank You to mouhane For This Useful Post:
Old 11-24-2019, 22:01   #4 (permalink)
ACiD FLaSHeR's Avatar
Member: 2748254
Thanks Meter: 87
Hello Team!
You Make Good Progress! This is Excellent Soft For BackUp Data!
Today Ill buy Infinity Dongles Also BB5!
The Following 3 Users Say Thank You to ACiD FLaSHeR For This Useful Post:
Old 11-24-2019, 23:43   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
I suggest you never wait any future promises (because many people chect users with future promises).
My advice is - you should buy software that can give you something today but not tomorrow. So if software make something that you need right now - you can order activation from seller.
If you want to see more functions in this software best way is - write exact phone details, attach links to flash files etc. and team will work in that direction.
The Following 25 Users Say Thank You to InfinityHelp For This Useful Post:
Old 11-25-2019, 01:32   #6 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
It recover data after formated phone also?
The Following 2 Users Say Thank You to malka4u For This Useful Post:
Old 11-25-2019, 02:55   #7 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
Wow
Content extractor reloaded 🙂
Let me find my dongle !
Regards,
The Following 4 Users Say Thank You to ~AKSingh~ For This Useful Post:
Old 11-25-2019, 04:03   #8 (permalink)
Member: 2603633
Sonork: family
Thanks Meter: 214
Great work .....team....
Nokia 206 Content reloaded ... ?
The Following 2 Users Say Thank You to haseebkakar For This Useful Post:
Old 11-25-2019, 04:53   #9 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
still not understand about this update and nan seen each error
The Following 3 Users Say Thank You to ihsan.khan.gsm For This Useful Post:
Old 11-25-2019, 05:08   #10 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 517
- Initial features
need de activation how can do
The Following User Says Thank You to SAJONDUTTA For This Useful Post:
Old 11-25-2019, 05:18   #11 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
old wine (CED) in new bottel (data extractor)
The Following 9 Users Say Thank You to avtarkaint For This Useful Post:
Old 11-25-2019, 06:17   #12 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
its a separate project, you can active it with your any infinity products
The Following 4 Users Say Thank You to srinibas For This Useful Post:
Old 11-25-2019, 06:37   #13 (permalink)
Khizar-Hayat's Avatar
Member: 2522841
Thanks Meter: 61
Error
The Following 4 Users Say Thank You to Khizar-Hayat For This Useful Post:
Old 11-25-2019, 06:40   #14 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
It will be good if you can post exact model names, firmware version name.
And also it will be good if users can provide links to flash images so programmers can analyze it and see how to get data from that images.
Hey Friend I Am Asking Something Different ..Is There Any Way To Read Dump In This Tool Too..Spsly For Samsung Swift N Infinion Series...AS This Tool Only Work With Dump But There Is No Option For Dump As No Box N Tool Support Dumping Samsung Old Feature Phone..I Read Update Thread Now It Show Support MTK Phones I Think Only Right Now...Seems Need To Wait For Future Update...
The Following 4 Users Say Thank You to hitech care For This Useful Post:
Old 11-25-2019, 06:49   #15 (permalink)
Crazy Poster
Member: 2506112
Thanks Meter: 7
i have the same problem i have cm2
dongle
The Following 2 Users Say Thank You to deejayshark002 For This Useful Post:
Page generated in 0.27695 seconds with 9 queries
