01-07-2020, 17:53 | #181 (permalink) | |
Are you sure your file is not crypted ? | |
01-07-2020, 20:22 | #183 (permalink) | |
Install latest one (1.03 for today) and try again. What is the result ? | |
01-09-2020, 03:37 | #184 (permalink) |
Junior Member Join Date: May 2010
Member: 1304636 Status: Offline Sonork: [email protected] Thanks Meter: 0 | any body extract phonebook text and vcard v3 from this dump thanks in advance |
01-13-2020, 14:35 | #186 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | E-Tachi E6 Lcd Not Available In Market important Contacts Backup Done |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
01-13-2020, 16:20 | #187 (permalink) | |
Freak Poster Join Date: Jan 2018
Member: 2798902 Status: Offline Thanks Meter: 11 | Quote:
SAMSUNG Tablet T-210 eMMC: KLM8G1WEMB-9031 CPU: 1.2Ghz Dual-Core ARM Cortex-A9 Z3X EasyJtag EMMC File Manager v 1.17-CPP Rel at 05/08/2018 started.. EasyAPI version: [2100] Easy FileSystem version: [05082018] SQLite Engine version: [3.24.0] Fsck API version: [05082018] Ese API version: [05082018] Z3X Card Serial: [AA0B645A] EasyJtag PLUS Box Found at [COM4] EasyJtag Box Firmware: [2.48] Generation: PIT [SAMS] Box Voltage set to: [2800] mV Scanner Thread Created. Setup HiPower CLK: [OFF] Connecting To EasyJtag Box: [2800mV/42MHz/8BIT] EasyJtag Box Found! Result: [0/OK] EasyJtag S/N: [7DB56B2E5A89A284] EasyJtag Firm: [2.48] Box Bus Width = 8 BIT Box Hardware = EasyJtag 2nd Generation Search EMMC Chip... Testing Box Interface PIN CLK : 129 mV - Pin UnConnected PIN CMD : 131 mV - Pin UnConnected PIN DAT0: 131 mV - Pin UnConnected PIN DAT1: 133 mV - Pin UnConnected PIN DAT2: 134 mV - Pin UnConnected PIN DAT3: 133 mV - Pin UnConnected PIN DAT4: 133 mV - Pin UnConnected PIN DAT5: 131 mV - Pin UnConnected PIN DAT6: 134 mV - Pin UnConnected PIN DAT7: 134 mV - Pin UnConnected Test End EMMC Chip Found! [0/OK] EMMC CID: [15010038574D423352006E3842EF615B] EMMC CSD: [D02701320F5903FFF6DBFFEF8E40400D] EMMC VENDOR: [SAMSUNG] EMMC NAME: [8WMB3R] EMMC ROM1 Size: [15269888 Block(s)/7456 MB] EMMC ROM2/3 Size: [8192 Block(s)/4096 KB] EMMC RPMB Size: [1024 Block(s)/512 KB] Switch To ROM1 Part: [0/OK] Scanning Data From EMMC. Please wait.. Search PIT Table.. Found PIT Table at 0x00004400 [PIT]: Partitions Count: 20] PIT: PBL [000000000000/000000040000] SIZE: 256,00 KB PIT: PIT [000000004400/000000002000] SIZE: 8,00 KB PIT: MD5HDR [000000006400/0000003F9C00] SIZE: 3,98 MB PIT: MRD [000000400000/000000100000] SIZE: 1,00 MB PIT: MRD_BK [000000500000/000000100000] SIZE: 1,00 MB PIT: BOTA0 [000000600000/000000400000] SIZE: 4,00 MB PIT: SBL2 [000000A00000/000000400000] SIZE: 4,00 MB PIT: SBL [000000E00000/000000400000] SIZE: 4,00 MB PIT: EFS [000001200000/000000C00000] SIZE: 12,00 MB PIT: PARAM [000001E00000/000000800000] SIZE: 8,00 MB PIT: MODEM [000002600000/000000C00000] SIZE: 12,00 MB PIT: KERNEL [000003200000/000000C00000] SIZE: 12,00 MB PIT: RECOVERY [000003E00000/000000C00000] SIZE: 12,00 MB PIT: MISC [000004A00000/000000A00000] SIZE: 10,00 MB PIT: NVM [000005400000/000001000000] SIZE: 16,00 MB PIT: MEP [000006400000/000000400000] SIZE: 4,00 MB PIT: SYSTEM [000006800000/000059E00000] SIZE: 1,40 GB PIT: CACHE [000060600000/00000C800000] SIZE: 200,00 MB PIT: HIDDEN [00006CE00000/00000C800000] SIZE: 200,00 MB PIT: USER [000079600000/000158600000] SIZE: 5,38 GB Partition #9 mount as [/efs] -> [12,00 MB] Partition #17 mount as [/system] -> [1,40 GB] Partition #18 mount as [/cache] -> [200,00 MB] Partition #19 mount as [/preload] -> [200,00 MB] Partition #20 mount as [/data] -> [5,38 GB] EmptyCheck: Done Scanner Thread Terminated, Elapsed: [00:00:11:323] Found 20 Partition(s).. Scan Done. Init Engine... Resetting EasyJtag Box. Wait.. Reader Engine Initialized.. [0/OK] Generation: PIT [SAMS] Bus Mode: [8BIT] Operation Done. [Init Engine], Elapsed: [00:00:00:940] Sure v1.03 , I'll try again and I'll indicate it here. | |
The Following User Says Thank You to GabrielCh For This Useful Post: |
01-15-2020, 14:33 | #188 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have a problem with file structure recognition by Data Explorer please post here operation log text and link to file (use f.e. mega). We will check files that can not be recognized. |
01-16-2020, 13:00 | #190 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
As you know Data Explorer is completely new software created by new programmers and it has no any relation with old software, so in some time discount option will be removed to avoid confusion. | |
01-29-2020, 23:42 | #194 (permalink) |
Product Supporter Join Date: Jun 2010 Location: Infinity Team support
Member: 1330296 Status: Offline Thanks Meter: 1,137 | yes. but actually it's some kind of special software and if we will see at this software carefully we can see that it's price is really miserable in compare with functions that it can give to users. also if somebody want to test his backup files it's possible to uplod files somewhere and post links in this thread. After that supporter can test files with software and report is file structure supported by software or not. |
The Following 2 Users Say Thank You to Infinity-BEST For This Useful Post: |
02-03-2020, 06:54 | #195 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Data Explorer v1.04 - SPD functions improved, Heuristic engine updated Data extraction based on full reconstruction of file system - SMS message extraction for SPD released. Multipart SMS messages are supported - Heuristic engine updated - more data can be found/extracted from the unknown dumps - GUI improvements - Minor bugs fixed Download link is in post #1 in current thread |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
