Old 01-23-2021, 07:01   #361 (permalink)
Member: 772214
Thanks Meter: 6
Originally Posted by Khizar-Hayat View Post
https://www.youtube.com/watch?v=lRzdqXMNDK4
Old 01-23-2021, 07:32   #362 (permalink)
Member: 634326
Sonork: 01911289141
Thanks Meter: 15
my cm2 update but my cm2 mtk2 & spd 2 ver 2.09 not open what is problm anybody help me
Old 01-23-2021, 23:12   #363 (permalink)
Member: 1043909
Thanks Meter: 56,546
solution https://www.infinity-box.com/support/?r=100127
Old 02-09-2021, 16:35   #364 (permalink)
..:: i-MAX ::..'s Avatar
Member: 94762
Thanks Meter: 110
how to extract data from Redmi 9 ?
i have read user-data with MT2
Operation : Memory Tool Init [ v2.18 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM20)
MODE : PRELOADER PORT
PORT : 20
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Talbot
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000007
BROM : SecMode : SBC+SLA+SDA
BROM : BROM|BL : 0xFF|0x03
BROM : PRELOADER PORT
MODE : Xiaomi : Helio [G70][G80] | Manual : Disabled
BROM : SOCID : E5E739BC46C11725BF1B3648E53E078CF7F5AF660FE7FEA28F D464CFDAAC1982
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6768
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00080000 [ 512,00 KB ]
DRAM: 0x100000000 [ 4,00 GB ]
EMMC: 150100444436384D4202417CCA1137C3
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DD68MB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00400000 [ 4,00 MB ]
USER : 0x747C00000 [ 29,12 GB ]
CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000
RNID : 991AD87AC2BAF48EED81279520462993
DA : USB : HIGH-SPEED
Boot done!
Set default path : C:\InfinityBox\CM2MT2\phdata\
Ready!
Operation : Read Memory
Reading selected partitions [1]
[0] Read partition : USERDATA
Saved to : C:\InfinityBox\CM2MT2\phdata\USERDATA.bin
Operation finished!
but explorer not do anything
Operation : Extract Data MTK [v1.11]
Source: Dump MTK
Loading file : USERDATA.bin ...
Finish.
Old 02-09-2021, 22:52   #365 (permalink)
Member: 148515
Thanks Meter: 17,748
PORT : 20
BROM : Init BROM
BROM init passed!
CODE : Talbot
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Ready!
Operation finished!
Source: Dump MTK
Finish.
If data can not be extracted it means this file is not supported yet.
Old 02-10-2021, 03:25   #366 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 18,764
PORT : 20
BROM : Init BROM
BROM init passed!
     CODE : Talbot
BROM : SOCID : E5E739BC46C11725BF1B3648E53E078CF7F5AF660FE7FEA28FD464CFDAAC1982
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        EMMC:
Boot done!
Ready!
Operation finished!
Source: Dump MTK
Finish.
MemoryTool allow you caheck USERDATA state before read or do anything with it.
Extract-able partition status ( can be expand by clicking ">" before partition name ) will be FILESYSTEM, not BINARY.
Old 02-10-2021, 09:48   #367 (permalink)
Member: 94762
Thanks Meter: 110
Old 03-01-2021, 21:24   #368 (permalink)
Member: 1043909
BQ-3595 tested with Infinity Data Explorer and found supported.
Operation : Extract Data SPD [v1.09]
Source: Dump SPD653x
Loading file : KG975B_ZXT_Z3501_31H_PCB10_AW9656_HVGA_YmEWT_BQ_20200313.bin ... OK
Searching FileSystem ... OK
*** FileSystem found at: [007C0000]  size: [00040000]
*** Memory Info : [00008000][00000008]
Extracting FileSystem ...
 *** Stage #1
Searching additional data ...
*** IMEI[0]: ...
*** IMEI[1]: ...
*** Sec Code : 1234 [NOT ACTIVE]
Searching required data ...
*** Contacts Found
*** Messages Found
Extracting contacts... *** Extracted 279 contact(s)
TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\KG975B_ZXT_Z3501_31H_PCB10_AW9656_HVGA_YmEWT_BQ_20200313_01_03_2021_21_20\
VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\KG975B_ZXT_Z3501_31H_PCB10_AW9656_HVGA_YmEWT_BQ_20200313_01_03_2021_21_20\
HTML saved to - C:\InfinityBox\DataExplorer\ReadOut\KG975B_ZXT_Z3501_31H_PCB10_AW9656_HVGA_YmEWT_BQ_20200313_01_03_2021_21_20\
Extracting messages... *** Extracted 44 message(s)
Finish.
Old 03-03-2021, 16:41   #369 (permalink)
Member: 29155
Thanks Meter: 15
Please help to extract contacts from philips X623 dump.
Panua ContenExtractor can't help me
https://disk.yandex.ru/d/fv-hlU4w6W6IwQ
Old 03-03-2021, 22:40   #370 (permalink)
Member: 148515
Philips-X623 tested with Infinity Data Explorer and found supported.
You can order Infinity Data Explorer software activation from any seller https://www.infinity-box.com/buy/
Operation : Extract Data from MTK Dump [v1.09]
Loading file : philips X623_M6236A_1150_01_V35V005.bin ... OK
Detected NAND Type
Analyzing NAND Dump ... OK
*** Nand Info : [00000800][00000040][00000040][00000400]
*** FileSystem found at: [04000000]  size: [04000000]
 *** Stage #1
 *** Stage #2
Checking FileSystem image ... OK
*** IMEI[0]: ...251
*** IMEI[1]: ...584
*** Sec Code not Found :(
*** Names Found
*** Numbers Found
*** Messages Found
*** PhoneBook size: 2000 contact(s)
*** Extracted 146 contact(s)
TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\philips X623_M6236A_1150_01_V35V005_03_03_2021_22_37\
VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\philips X623_M6236A_1150_01_V35V005_03_03_2021_22_37\
HTML saved to - C:\InfinityBox\DataExplorer\ReadOut\philips X623_M6236A_1150_01_V35V005_03_03_2021_22_37\
*** Extracted 93 message(s)
Finish.
Old 04-06-2021, 01:16   #371 (permalink)
Member: 2028047
Thanks Meter: 13
Hi bro! Why have they not wanted to include in their programs the treatment of dumps of the eMMC type (.BIN Files) even at this point, taking into account that the fashion of today is the JTAG and eMMC ISP with many programs and Boxes?
Old 04-06-2021, 16:04   #372 (permalink)
Member: 1043909
More files formats support is under development at the moment.
If you want to analyze partition images with well0known structure, f,e, fat or ext4 probably you can google for a free tools. Infinity Data Explorer is little bit specifit to mobile phones images.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.19979 seconds with 8 queries
