Old 11-02-2015, 06:22   #1 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
QMobile V5 Too much data! Break! Send report to support
Chinese Miracle II  [MTK module] v 1.35
Operation : Remove Viruses [SmartAV] [ v1.35 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 4B000115303055388757034DF1903080
DA Stat : v3.2 on BBID : 0x86
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : M00U8
[eMMC] : FLASH_CID : 1501004B385530304D035787803090F1
[eMMC] : FLASH_EXT : 00200000/00020000
[eMMC] : FLASH_LEN : 0x00000003A3E00000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 269
AVVerify : Too much data! Break! Send report to support
Error! Check previous message for more info!
Check battery, cable, charge! Before try again, check result!
Operation Failed
Elapsed: 00:00:31
Reconnect Power/Cable!
Old 11-02-2015, 11:28   #2 (permalink)
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
45 viewed ....... But no answer from any person
Old 11-02-2015, 11:39   #3 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
READ FLASH FILE IN SCATTER FORMAT
POST ITS LINK HERE AND WAIT FOR Mr.JayDi TO CHECK
WBR
sahil2000ind
Old 11-02-2015, 14:22   #4 (permalink)
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
WBR
sahil2000ind
no need to read or upload. problem solved by flash factory file.
Old 11-03-2015, 09:20   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
So, for why then you make that thread? Say "not work"? Help? It change nothing at all. Just wasted time and forum space.
Old 11-03-2015, 09:41   #6 (permalink)
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
No Mr.Jaydi
I make Thread because of problem! Your software Not work. Why? this is why make thread.
about help... this is not solution to read file and send to you. its very difficult to upload firmware because of BroadBand.
about wast space? you reply here for what? to wast space aswel
I search new phone then read flash file and write to faulty phone.
Old 11-03-2015, 10:52   #7 (permalink)
BISMILLAH MOBILES's Avatar
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
@Hafiz ArslanAli will you please upload the flash file for users help?
Old 11-03-2015, 10:55   #8 (permalink)
JayDi's Avatar
Member: 462970
No Mr.Jaydi
Because such "users" just waste my time.
Old 11-03-2015, 11:03   #9 (permalink)
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
i think now we waste space.
also MR.Jaydi don't reply those who waste your time. about my post. when i post my problem solved and you read it then you don't have to reply any thing, its my opinion.
Close topis!
br i am facing broadband speed problem. but i try to upload tonight.
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post:
Old 11-03-2015, 11:15   #10 (permalink)
Member: 2364508
Thanks Meter: 15
he he
You should join N A S A program.
Dont estimate your self better then other.
All are doing their own jobs.
Page generated in 0.21907 seconds with 8 queries
