Infinity Dongle Unknown Smart Card Problem (Windows 10) I tried every drivers but still dongle gets detected as unknown dongle and when I read dongle it gives error and in dongle update software it not detected. |
Error from card read Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) |
Hello, Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader |
Already Did all those things. |
text of error message ? |
=== Process started: 7/16/2020 16:45:27 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
What of your thread should we use to write replies ? |
I posted there because we both are facing same issue thats it. I want to know is this error has to do with Unknown Card in device manager? |
And yes, you can continue to hide card serial numbers, no problem. Supporters can wait, no problem. |
btw, "Unknown Card" in device manager is not an issue. "Smart-Card" device do not need any drivers. Now you should explain the whole story, what was happened with your card, what you have tried to do etc. |
I am using it after 3 month earlier it worked fine but now software only shows No Dongle detected. and card read gives and error. Update dongle is also not working. |
text of error message ? probably you can use copy/paste and provide more details than before |
Card-Reader: Gemalto e-gate Smart Card 0 ATR: 3B759400006202020201 Card Manager: SerialNumber: 0003#### ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 0017 Serial Number: 00039#### Batch Identifier: 0000 Module Fabricator: 1942 Module Packaging Date: 0017 IC Card Manufacturer: 1943 IC Em******* Date: 0017 Pre Personalizer: 1944 Pre Personalization Date: 0017 Pre Personalization Equipment Identifier: 0000C118 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 000392CE00001942 Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) this id from cardid. I have put hashtags in serial number |
- Disconnect all other Boxes and Dongles from PC - Connect ONLY one Infinity Box/Dongle to PC |
Supporters have unlimited patience skills |
