02-13-2010, 08:36 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: My Lappy Age: 37
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | Airtel fgd9000 unlocking here is first method details with eprom files http://www.sendspace.com/file/l6t5m2 [2/13/2010 12:53:04 PM Loading data, wait... [Infinity Box] MModule v3.14 smart-card: connected S/N: 1424:0112 Wait... Done Device: Airtel-Cordless-FGD8900 COM1 [VCP0] selected module v3.14 Device: Airtel-Cordless-FGD8900 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" Warning ! After unlock process finished make this: 1. be sure that there is NO any SIM card in phone 2. press phone "Power" button and power-On phone 3. press phone "Power" button and power-Off phone 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems ! 5. now you can power-On phone with SIM card Do you understand instruction and want to continue ? unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00380000/00080000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Airtel-Cordless-FGD8900__ffs... file saved: C:\Program Files\InfinityBox\MModule\Airtel-Cordless-FGD8900__ffs_20100213-125514.B0E.bin flash: EC22A000000000:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ...... required data found flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: area 1 (pass 1) required data found flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: area 1 (pass 2) .......... area 1 patch applied Ok Special operation Done ====> Write ... flash: EC22A000000000:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 8 sec Remove/Install battery now ! |
02-13-2010, 08:39 | #2 (permalink) |
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | and here is second method logs COM1 [VCP0] selected module v3.14 Device: Airtel-Cordless-FGD8900 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" Warning ! After unlock process finished make this: 1. be sure that there is NO any SIM card in phone 2. press phone "Power" button and power-On phone 3. press phone "Power" button and power-Off phone 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems ! 5. now you can power-On phone with SIM card Do you understand instruction and want to continue ? unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00380000/00080000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC22A000000000:18E59F00000000 Backup required data Done ====> Patch required data ... ...... lock area found ...... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................ error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: lock-area-1 flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: lock-area-2 Write Done ====> Finalization ... Finalization Done Finished, time used: 50 sec Remove/Install battery now ! so me waiting here your respone Thanks!!!! SHEIKH |
02-14-2010, 17:40 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, FGD9000 model is not the same as FGD8900. I sufggest you never make this kind of tests in future. If you want to see FGD9000 supported - read full flash from FGD9000 with ChineseMiracle software and send full flash backup (or link) to [email protected] Also, what is FGD9000 pinout ? |
02-15-2010, 07:41 | #4 (permalink) | |
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | About FGD9000 Quote:
So I Think Its C2500 Pinout Because When I Used C2500 Cable With This Model Its Connected. And About Flah File Back I will Give You As Soon As Possible. Thanks!!!!!!!!!!!!!! SHEIKH | |
02-16-2010, 04:07 | #7 (permalink) |
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | boss how could u ask me like that kid question(sure) its my work that i doing my work with open eyes so for ur kind info its fgd9000 airtel (beetel) cordless phone. |
02-16-2010, 10:37 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | why I ask: FGD8900 firmware version : 05A.W05.24.43_8900.IN.AT.B.23.34_T8X00_HW_Jul-14-2006_En_Es_Pt FGD9000 firmware version : 05A.W05.24.43_8900.IN.AT.B.23.54_T8X00_HW_Oct-16-2006_En_Es_Pt as you can see it's hard to find difference in both. anyway, now I am sure that your file is from FGD9000, I'll give you more information some time later |
02-16-2010, 15:06 | #9 (permalink) | |
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | surprised Quote:
by the way i still waiting . | |
02-20-2011, 10:41 | #12 (permalink) |
Freak Poster Join Date: Aug 2006 Location: india
Member: 337100 Status: Offline Sonork: 100.1606722 Thanks Meter: 75 | sir i have one set airtel fgd-8900 after unlock by infinity box.... after unlock it will be off when put sim card...... whats the problem i confused?????? |
02-20-2011, 13:02 | #13 (permalink) | |
1. Are you sure that you follow unlock instruction exactly ? 2. try to make 112/emergency call without sim card. What is the results ? | |
fgd 8900 airtel codless unlock | zipzap_kill | Infinity-Box | 29 | 05-08-2013 12:47 |
24 Feb 2007: "Hero of India" in action: Airtel FGD8900 unlock... | InfinitySupport | Infinity-Box | 23 | 05-23-2011 10:48 |
12/02/08 : ET-BoX v1.58 Released - Added Airtel FGD9000, ZTE A12 & Samsung C260m C266 | .:ET-BoX.net:. | ET-BoX | 11 | 02-16-2008 06:33 |
c140 &s 404 airtel can't unlock. | nirbhay | Infinity-Box | 1 | 08-10-2007 15:06 |
