09-08-2008, 05:57 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: North India Age: 43
Member: 156414 Status: Offline Thanks Meter: 60 | infinity not working |
09-09-2008, 15:39 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. double check COM port selection 2. double check your cable If you still have a problem post here more detailed information what is phone model name etc. |
09-17-2008, 06:54 | #3 (permalink) |
Member: 156414 Status: Offline Thanks Meter: 60 | sir, i will check all ... i check cables, com. everything.and also try with diffrent phone models. but same problem. now i think this is infinity hardware problem. please help me. after purchase i will only 5 or 6 time use my infinity box.. please help me sir... |
09-17-2008, 07:39 | #4 (permalink) | |
No Life Poster Join Date: May 2006 Location: ..::INDIA::..
Member: 279604 Status: Offline Sonork: 100.1582858 Thanks Meter: 198 | Quote:
09-17-2008, 13:05 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @frnd_4_gsm your advice is NOT smart @sms-india Why you ignore my previous message ?Read message #2 in current thread and post here detailed information what you have tried to do, what phones you already done, what phone you can not connect. If you did not post here detailed explanation and if you will try to replace working box at your resellers you will be unable to replace box because you must explain box history yo us and to resellers befopre any replacement etc. The best way for you: post here honest explanation what yopu have tried to do and lets try to solve the problem, fix your mistakes. |
09-18-2008, 11:37 | #6 (permalink) |
Member: 156414 Status: Offline Thanks Meter: 60 | when my infinity is working , i try to sim unlock motorola c117,118,138,139, and its done. and i use cable name is Panasonic X60/ motorola T191. if my phone will not connect . then i try diffrent method of connection. like.... default version/method version 3/ method version 4. and and will will unlock successfull. now i will try thease all thing with same phone type. when its not done then i try my same cable on my friend's infinity box. there it will done. and i also try one more thing. that is i connect my infinity box on usb port , and i use another moto t191 cable on my com port box, ( named NET2000) then its working. then phone is connected and phone will unlock succesfully.i think now you understand my problem. thanx in advance |
09-18-2008, 20:46 | #7 (permalink) | |||
This means that your Infinity-Box is working. It's correct cable type. I don't understand this. Please, explain. Quote:
This means that your Infinity-Box is working. Quote:
C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_unlock_Moto-C139_TracFone-8.8.17_C113-C118-C123_2.2.83_and_newest.htm | |||
09-19-2008, 16:31 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Please, read my previous post. To be honest I don't think that your box is damaged, I think that you have a problems with one phone only. I suggest you to check box with other phones. |
09-20-2008, 08:08 | #12 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | brother check with another brand set like lg kg110 ,benq a38 any china mtk phone and also post screen shot and log of c117 and other brand phone too(for more info to supporter)but always removing box serial no if your box is defective and with warranty then you must cover warranty from your reseller but if box is ok and you are doing something wrong or cable or setting problem if you take final step to send back your reseller then this is time consuming and some time expensive too for nothing. as i think your detail is not enough for supporter to help you ,,so don't worry so high just try to post more detail to solve your problem faster l |
The Following User Says Thank You to TURNING POINT For This Useful Post: |
09-20-2008, 08:08 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @sms-india It's looks like endless loop. Please, read current thread from begin, check all my messages and advice. After you will give answers to all my questions we will be able to help you, in other case you are just spend time in useless "halp me" without any real move to success. |
12-17-2008, 08:39 | #14 (permalink) |
Member: 156414 Status: Offline Thanks Meter: 60 | my problem is solved. i change FTDI ic in my infinity slim plus box. and now my box is working fine........infinity product manager unsuccesfull to solve my problem. (sorry to say that) Last edited by sms-india; 12-17-2008 at 08:45. |
12-17-2008, 18:47 | #15 (permalink) | |
My advice for future: always make HONEST problem description ! If you have damaged your box it was your fault (due to you have used box incorrectly) and you have damaged box hardware. Also I hope next time you will be more honest with your problem explanation or at least you will be able to make "search" in this forum. Just make search in this forum for "FT232" and you will see that The Great Infinity-Box has The best support that ever was possible. Also this thread is a good example that users must think very good if they want to ask for help and that problems should be explained so detailed as possible, Please, do not blame our supporters without any reasons, at first think about yourself and about your own words and knowledge, I am sure this gives you exellent results ! | |
my infinity not working in downloading | stereonation71 | Infinity-Box | 6 | 02-28-2014 06:40 |
infinity box not working plz help infinity team | Y2ksalman | Infinity-Box | 21 | 01-18-2011 00:51 |
new infinity not work | Salem_Gsm | Infinity-Box | 2 | 12-24-2007 20:30 |
Support for infinity not work for me since 4 moths ago,no good solution from support | crossings | Infinity-Box | 6 | 06-11-2007 17:44 |
