09-05-2009, 07:21 | #1 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 533912 Status: Offline Thanks Meter: 115 | infinity pin finder searching adapter at COM4... too many retries can't find adapter searching adapter at COM1... too many retries can't find adapter searching adapter at COM4... too many retries can't find adapter too many retries done |
09-05-2009, 11:20 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | First check in your device manager to see if it's detected or not,run dongle manager and read info to check if your pinfinder is already activated and updated for you infinity SN,better to remove all other smart-card based tools to avoid card malfunctioning ... test and report here. |
09-05-2009, 11:49 | #4 (permalink) |
Member: 533912 Status: Offline Thanks Meter: 115 | its activated....................perfect,, Dongle serial No (S/N): xxxxxxxx Firmware version: 0112.02 Smart-card status: activated "UK edition" status: Off Last launched application: 001F v.0282 Additional activated modules: - 04: Pin-Finder Adapter Support area: http://www.infinity-box.com - Username: xxxxxxx- Password: xxxxxxx Dongle parameters checksum: 68AE18 |
09-05-2009, 15:27 | #5 (permalink) |
Member: 115172 Status: Offline Thanks Meter: 212 | If you need pinfinder for chinese phones it's better to use spiderman coz it's quite exceptional but for other platforms infinitry pinfinder rocks ... |
09-05-2009, 16:33 | #6 (permalink) | |
Did you checked voltage at your unibox pin-1 ? What is volatge value ? What was happened that PinFinder stop to work ? | |
09-05-2009, 18:01 | #7 (permalink) |
Member: 533912 Status: Offline Thanks Meter: 115 | how to check voltage.........infinity box or pinfinder.............how to solve this problem plz help infinity team before this box working perfect.................its 4 switch socket 1. 0n..off 2.comport 3.f-bus rx-tx 4.m-bus rts ,cts...........which com to check voltage.......... |
09-07-2009, 08:53 | #11 (permalink) |
Member: 533912 Status: Offline Thanks Meter: 115 | before its working perfect normal mode...............yesteyday its has detect pinfinder and worked and i repair 2 mobile... today i check now its some problem whats procedure to repair this problem,,,,,,,,,,,,plz infinity help and solve my problem........... |
09-07-2009, 21:11 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i cant say remotely what could be a reason for such behavior. if you sure that you doing all correctly, same way as before- then only way is exchange it under warranty conditions. contact your reseller for this |
can spiderman used instead of infinity pin finder for infinity box | sajin6660 | Infinity-Box | 8 | 03-14-2010 09:18 |
infinity pin finder can't detect spredtrum cpu pin out perfectly | md.giousuddinso | Infinity-Box | 6 | 10-05-2009 19:08 |
can find bleu 245x pin out using infinity pin finder. | sinikrishna | Infinity-Box | 1 | 01-08-2009 12:59 |
help me for infinity pin finder not actvataed | subhdra | Infinity-Box | 2 | 04-19-2008 09:52 |
Infinity Pin Finder Want Update | sunnyarora | Infinity-Box | 1 | 03-21-2008 10:33 |
